Question about Garden
We purchased a Heritage ceiling fan from our local K-mart about two weeks ago, we installed it today and it makes a VERY loud noise in the engine when we turn the fan on... We went through the trouble shooting shooting guide and still is making the noise. We tried the phone number listed on the 25yr warranty and conviently this number is "no longer in service". Do you know a number I could contact this company at? The number I have is:1-888-561-1873...This number is NOT the correct one. Please help!!!! I would return it to K-mart, but unfortunately they are going out of buisness.
    Master:
  • 403 Answers
Sorry but the company went out of business years ago. The only thing you can do is let it run, The heat from movement will warm the grease and dispers it. The unit is " kinda ceased " do to lack of sales, because there very low end.
Posted on Mar 11, 2011
Testimonial: "Thank you VERY much for your advice. We will try letting the fan run, hopefully this will help/ Again, THANKS!!!"
Can i buy a replacement glass cover for a heritage h612 ceiling fan
Refer your inquiry to the purchase source or the manufacturer/distributor.
Jul 19, 2014 | Heritage (5EMW52AB) Ceiling Fan
Who makes Heritage Ceiling fans?
unfortunatly there are many manufactures that have a "heritage" model fan ... like casablanca, minka aire, concord and emerson ... even Kmart sells a fan called Heritage (not a bad fan) ... of the above, casablanca has a high end model called "heritage" and that name is likely the domanant brand .. if you can find a model number then it can be isolated better ... .
here is info on that one
Casablanca Heritage Ceiling Fan
http://www.carolinarustica.com/product.asp?pn=CB-C19624F&sid=BECOME&utm_source=Become&utm_medium=cse&utm_campaign=MerchantAdv
Apr 15, 2010 | Vacuums
98 Cherokee 4.0 VERY loud grinding
Sounds like the alternator bearings have gone away, but, you need to physically check the source of the noise. (I can't do that from here).
It also seems that you may have more than one problem going on there, possibly a bad ignition switch and also a blown fuse or bad body control module. As far as why the noise seems to be only when the engine is "freewheeling" may have a lot to do with rpm change and loading when in gear. I would go after the obvious alternator problem first, then sort out the remainder later.
Dec 21, 2009 | 1998 Jeep Cherokee
Got a 52" heritage ceiling fan from meijer and it uses e12 candalabra bulbs. Doesn't come with any and no local stores have them. What is the deal?
My local Home Depot stocks these, as does Ace Hardware.
You can also buy them online if you like (that link was just the first shopping link from googling "e12 candelabra bulbs"
Just be sure to rate my fix as "helpful" before you go shopping! :)
Aug 17, 2009 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
Ceiling fan wiring Aloha ceiling Fan Model # 29079
I have an Aloha Breeze L-Style 52" Ceiling Fan(Polished Brass), Model # 29079 Bought From Wal-Mart about 1 1/2 years ago and the fan speed switch busted and the capacitor melted. I have a new switch but can't find a new capacitor because I can't read the spec info. Looking for a place to obtain the correct capacitor for this fan so I can make necessary repairs!
May 04, 2009 | Aloha Housewares (93645) Ceiling Fan
Broken Lexan fan needs to be replaced
It is similar to the G4 but without the tech drive so is easier.
Apr 30, 2009 | Kirby Heritage II Vacuum
Light bulbs burn out
Use bulbs specifically designed for ceiling fans - they say "ceiling fan" on the package (Home Depot, Lowes both carry). The slightest regular vibration (like a fan rotating) causes normal incandescent elements to burn out within days or weeks.
If you wired black to black, white to white and green or bare to ground, you wired it right. Sometimes there are two blacks (hots) one for the light and one for the fan, but most of the time you hook the light wiring parallel to the fan wiring unless you install a remote switch.
Feb 18, 2009 | Aloha Housewares (93645) Ceiling Fan
Can you please tell me how to install my Heritage ceiling fan?
Its really easy but you need to be safe, make sure all circuits are off to the outlets you are working on. Usually everything is color coated black goes with black (hot), white goes with white, ground goes with green or copper make sure you use electrical tape to tape up, then assemble from there using istructions. Hope this helps
Nov 17, 2008 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
Heritage lancaster ceiling fan
Where can I find parts for this fan: Kids 30" ceiling fan multicolor - I need new fan blad arms
Jun 19, 2008 | Dryers
Temperature at 10 degrees
check condenser fans, if defective or running slow change it
if condenser fan is running, suspect a compressor with internal mechanichal problems, it will run but i can't guarantee how long, maybe a couple of weeks or days. if it's an copelamic compressor, it's going bad.
Apr 21, 2008 | True 49 cu. ft. / 1388 liter Commercial...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
