Question about Mag Innovision M572TVs LCD Television
My MAG LCD HD TV will not turn on, and it seems to not be getting any power. Help!
  • Mag Innovision Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck....
Posted on Mar 11, 2011
We have a 32" HD LED LCD TV (Model BVALED32). We can turn it on using button on tv, remote does not seem to work. The only thing we get is the GVA logo screen and we cannot get movie to play anymore
Try unplugging the TV for a few minutes and then plug it back in. change the batteries on the remote, too. I can't say this will work for sure. IF that does not work, you need to take it in for repair or call customer report for help.
Nov 13, 2014 | Televison & Video
Why does my MAG Innovision MA-32EF1ASP Flat Screen TV not function properly?
Have your hand ready when you turn the set on and instantly change the input to get back to the tuner in the set--some sets will shut down if hooked to a input with nothing connected.
Also if using a box connected to that input unplug box and set--wait and plug both back up to allow them to reboot.
Let me know what you find--not likely a reset will cure this but possible.
Apr 03, 2012 | Televison & Video
I am unable to get MAG Innovision 14" LCD monitor
You need laptop-type 12V, 2.5A (minimum) adapter plugged into back of VGA plug
Nov 13, 2010 | Mag Innovision lt456s 14" Flat Panel LCD...
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
MAG 780 Innovations LCD Monitor
The plug end (to the monitor) is a partial square end with three top angles. That plugs into the back of the monitor. You can see the plug socket from the underside.
Jan 29, 2009 | Mag Innovision LT776s 17" LCD Monitor
HDTV on Mag LT776s
that monitor wont produce the 1280x720 resolution. It isnt hdtv ready
Aug 07, 2008 | Mag Innovision LT776s 17" LCD Monitor
Mag lcd monitor
probably capacytor problem in the mainboard, take it to the lab it will be cheaper then buying new one
May 06, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Maginnovision LCD Monitor
You probably have a bad filter Capacitor in the power supply. Schmatics would help locate the faulty component, also you can tear it apart and look for any water intrusion. My wife cleaned the TV screen with windex and it ran down the screen and into the TV. It destroy a menu button which had to be replaced. It caused unusual simptoms.
NSSMS
Apr 04, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Mag Innovision M572TVs LCD Television Logo
664 people viewed this question
Top Mag Innovision Televison & Video Experts
kj henriksen
kj henriksen
Computer Repairing
Computer Repairing
Are you a Mag Innovision Televison and Video Expert? Answer questions, earn points and help others
