Question about Ace Hardware Ace; Table Saw with Stand
I have a $120 10"
  • Anonymous Mar 25, 2014
    I have misplaced the miter gauge and need to purchase a new one, but apparently this saw is no longer made?
    I have lost the miter gauge for this saw, apparently it's not a standard slot, so if anyone knows what it is compatable with I would appreciate the info.
    Guru:
  • 479 Answers
It's possible that the brushes may have worn out or a bad connection may have developed in them or at the brush holders. Open the motor, check the brushes and look for any overheating. One of the windings may have gone open circuit in the armature of the motor and in this case it probably isn't worth repairing.
Posted on Mar 12, 2011
Saw just quit.Reset didn`t work,are there fuses?
Are you plugged into a GFI? If so you may need to set the GFI receptacle also plug it into a different plug in and see if that works. In saying that I bought the same one and burnt out the motor in less than one hour from purchase. with not cutting any more than five pieces of pine board. They did replace the saw for me.
Apr 12, 2015 | Craftsman 10" Radial Arm Saw Table...
Need on and off switch for a Ace 2123958 table sw
I can't find any online supplier for a switch for your table saw.But is it possible for you to contact the manufacturer. I have an old bandsaw , since it 's old, it's hard to find its parts. But good thing there's an online aftermarket supplier bandsawparts.com. That's where I ordered some parts for my band saw.
Sep 16, 2013 | Craftsman 10" Table Saw
I own a Hitachi 10CFR Table Saw. My question is: Can I load a Dado Stack onto the Arbor of this table saw to create a 3/4 dado cut? I've read everything from "Yes" to "Absolutely Not"...
After doing some research, I found that hitachi only recommends up to a 1/2 dado for this machine with most of the users agreeing that it probably does not have the stability or power to run a 3/4 inch safely. Meaning you probably can run the 3/4 but at you own risk.
Mar 03, 2011 | Hitachi C10FR 10" Job-Site Table Saw 15...
I haven`t used the saw in a year, should I lubricate the motor bearings? Something is making a sqweaky sound when I turn on the saw.
Unplug the saw. Look inside the blade housing for any foreighn objects. if it is clear, shoot some oil into the bearings and work it in well.
Feb 25, 2011 | Ace Hardware Ace; Table Saw with Stand
Where can I buy a replacement motor for my craftsman 10"table saw. model number 137.2711400 2.5H.P. moter modelRM871 5000Rpm. From Chatham,On.
Sounds like WAY!!!! overloaded use of the saw. Feed your material MUCH SLOWER and you will NEVER burn out a motor.
You can get replacement from Sears parts.
Feb 18, 2011 | Craftsman 10" Table Saw
My d27105 is blowing the 13amp fuse in the plug ?
If it continue to do it the machine had a "short circuit".So inspect the machine and look for any brake cable the is touch any metal part of it.
Nov 09, 2010 | Dewalt DW746X 10" woodworker's table saw...
The saw wont cut all the way through the wood. Why?
first off what is the blade diameter and the wood thickness?? Also do you have the table adjusted for the maximum depth, It is one of the 3 items mentioned.
Jan 30, 2010 | Ace Hardware Power Glide Circular Saw with...
I have a ms 150 miter saw that a relative gave me. Blade needs to be changed but the locking mechanism is stripped. How can I remove the bolt that holds the blade in place. Also the blade turns clockwise...
Jam a piece of wood between the blade and the table to stop it from turning while loosening the bolt. Circular saws never had locking mechanisms until recent years.
Mar 15, 2009 | Saws
Ace Hardware Ace; Table Saw with Stand Logo
402 people viewed this question
Top Ace Hardware Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Ace Hardware Saw Expert? Answer questions, earn points and help others
