Question about HP Office Equipment & Supplies
HP OFFICEJET C5180 FAILS TO POWER UP OR TURN OFF
  • 604 Answers
If it fails to power up, how can it need to shut off?
Posted on Mar 11, 2011
Printer HP Photosmart C5180 Series cannot be contacted over the network
Check with HP for a Windows 7 driver for the printer. HP Ink Jets require proper drivers to work correctly. Once you have downloaded and installed the drivers try connecting again.
If you have installed the drivers and Windows 7 still refuses to "talk" to the printer, you may have to adjust your advanced network settings as well. Open up the Network and Sharing center, click on advanced sharing settings and make sure file and printer sharing is turned on. Also check "File Sharing Connections" and enable file sharing for devices that use 40 or 56 bit encryption.
If that fails to work you may need to speak with HP support for further assistance.
Feb 23, 2012 | HP Photosmart C5180 All-In-One InkJet...
My computer says there is a paper jam but there is none on the display screen. I tried opening it up but it doesn't work, my computer still says it has a paper jam. My printer is HP Officejet 4355. My...
Turn the printer off.
Disconnect the AC power.
Disconnect the "data" cable from the computer.
Reconnect the AC power.
Turn the printer on.
Press the "paper-feed" button, to try to feed a few sheets of paper through the paper.
Reconnect the "data" cable.
If this fails, take the printer to a qualified technician, for professional trouble-shooting.
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
I have a hp officejet 5610 all in one printer/fax. everything was fine until now. when i scroll to help,an error comes up "there is no computer connection refer to device documentation". i checked all...
It's may be a microsoft bug on usb 2.0...
Go to device manager \ universal serial controllers \ expand \ usb root hub properties \ power management tab \ uncheck the box abt turning off...
Feb 05, 2010 | HP Photosmart C5180 All-In-One InkJet...
Where can Iget a instruction book for HP Printer
Go to generalmanual.com, type in C5180 then click on the type of manual you want, whether it is the users maual or the setup guide, it is free.
Jan 04, 2010 | HP Officejet 5610 All-In-One InkJet...
I insert a new print cartridge and align it as asked. But the printer says it won't align. I have an HP officejet J5780 all in one. Thanks.
Several Steps to take.
If all else fails try a new or different cartridge before you get too carried away looking at the printer for the problem.
1. Turn off the printer and unplug it from the power source for approx. 30 seconds (some units take this long to bleed the power out of the unit).
2. Plug in the printer and step thru the start up procedure (turn it on what ever - not the set up program).
3. Retry the cartridge alignment procedure.
4. If alignment still fails verify that the cartridge electrical contacts are clean and the jet opening is not blocked.
5. Reinstall after cleaning and checking.
Aug 21, 2009 | HP Officejet J5780 All-In-One InkJet...
I need an XP Postscript driver for C5180. Where do I get it?
Go to HP.com and they have all the driver for your printer
Jul 09, 2009 | HP Officejet 6310 All-In-One InkJet...
How to reset the ink level on a HP C5180
You have to purchase new inks. If you have refills, it will not detect the ink levels due to the chip on the ink cartridge. When inks have been refilled, There is no way to reset the chip.
Feb 10, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hp photosmart c5180 all in one. will not turn on.
I would said that's fuse blown,fuse on power supply board located behind the machine.
Dec 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
Solution to fix prolem with machine
Line interface unit is broken beacuse of which the beeping sound comes up. It tries to intiate however fails as a result the sound comes up. Need to replace the printer.
Dec 06, 2007 | HP OfficeJet k60 All-In-One InkJet Printer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
