Question about Nintendo Wii Console
My wii console has sound but not visual checked all connections all ok it is connected by component cable please advise
    Scholar:
  • 78 Answers
Try to connect your Wii to another component input on the same TV, or to another TV. If the video works in one of those cases, then there is a problem with the TV. If not, your cable is likely broken. Try using a new component cable. If all this fails then there is a serious issue with your console that probably cannot be repaired at home.
Posted on Mar 11, 2011
No visual for Nintendo Wii, replaced cables, audio fine.
Did you hit the input button on your TV remove to select the input where the Wii is connected? If you TV allows for Component cables try getting a set of those. It's a possibility the TV connection has gone bad. Try connecting it on another tv. or some tv's have Audio connections in the front/Side/back.
Oct 12, 2013 | Nintendo Wii Console
Wii game hooked up to new Sharp LED tv. TV is color and the wii is in black and white.
Usually this is either a cable or a mode issue. First make sure that you have the correct cable connections. (Composite video cable to a component video jack is one possible cause of the problem.) Component video cables are not included with the set but will give better results. However, composite video in from the wii's composite video out should give good results.
If you are using HDMI or component video cables, then go into the Wii video menus to select the correct mode for your tv. Check your TV manual and the Wii setup guide for details on the mode (resolution, etc) you should be using.
If the problem persists, try new video cables and make sure that they are fully seated on both sides. Try switching inputs if you have several available.
I hope this helps.
Jan 22, 2011 | Nintendo Wii Console
Wii powers up doesnt have a picture or sound tv screen.
    • With the yellow, white, and red AV cables that came with your system:
      • Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs? If so,click here for complete information on doing this type of hook up.
      • If this is your first time hooking up the Wii console or have you moved it to another TV, please click here to review our step-by-step connection guide. Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
    • With the blue, green, white, and red component cables (sold separately):
      • Review our step-by-step Wii Component Cable connection guide to make sure the cables are properly inserted and that your TV is set to the proper input.
    If you have verified the connection is correct, and are still receiving a blank or black and white screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700
Dec 29, 2010 | Nintendo Wii Console
Having just installed a new Wii console I have good sound but everything is in fuzzy black and white - no colour at all. What should I do to get colour?
      • If this is your first time hooking up the Wii console or have you moved it to another TV, Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
Dec 26, 2010 | Nintendo Wii Console
I have a Samsung led tv nd need a 'component
Hello :
First check this link please : Wii+Television connection
a cable can be found on Ebay or Amazon
I hope that will help .
rate please !
Mar 21, 2010 | Nintendo Wii Console
Nintendo Wii works fine on standard tv but not on hdtv.
FOUND THE PROBLEM !!!!! The problem appears to be the Freeview somehow interfering with the Wii signal. When the aeriel lead is removed the Wii works fine, and the audio/visual signal is great. When the aeriel lead is in I have the problems. I hope this solution proves to be of use to anyone else having similar problems.
Dec 29, 2009 | Nintendo Wii Console
Can the wii be connected with hdmi cable
As was said, there is no HDMI cable for the Wii. An HDMI cable would be a waste on the Wii, considering the Wii can't ouput 5.1 sound, and can't output 1080P (those are the main benefits with an HDMI cable).
The highest qaulity cable for the Wii is a component cable, which will allow you to output the Wii in 480p (progressive scan) vs 480i (integrated scan). All HDTV's have component inputs, so this is a non issue. Component cables actually can output 720p/1080i, but the Wii can only output 480p max.
Here is a link to the cable I am taking about. You should be able to get it from somewhere for the $20 range.
Nov 13, 2009 | Nintendo Wii Console
Yamaha HTR 5760 Video Problem with Wii
You need to connect a composite cable from the receiver. The receiver does not carry a composite signal over component cables.
Feb 25, 2009 | Yamaha HTR-5760 Receiver
Wii component cable - how to connect it?
on your tv, there should be color coded ports that tell you which cords go where but im almost 100% sure that the red and white cords are for sound and the blue and green cables are for hd video hookups.
Oct 14, 2008 | Nintendo Wii Console
Connecting Wii through Component cables and Phillips switcher
I just did some more checking...
When you have the Wii connected to the AV Switch, try turning on the DVD player too, but have the switch set to show the Wii on the TV. It is odd, but that has worked for me.
Jun 19, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
49 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
