Question about Whirlpool GEQ9858J Dryer
Slider positions on drum bearing No.WE3M26. Two are of white plastic and two of identical size but of a green material.
    President:
  • 3,074 Answers
Drum rollers/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Posted on Mar 12, 2011
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Youtube DRUM DRYER
Sep 02, 2015 | Dryers
Why is my whirlpool electric drying making a loud screeching sound
I know this is a late answer but you have bad bearings on the dryer. There is usually 1 on the back of the drum in the center. Its in 2 pieces, one is nickel coated and the other is hard plastic like material that holds the nickel piece. The other 2 are on the front of the drum on the top just out of sight. They attache to a lip on the front of the machine and the drum 'rides' on the bearings. These are usually about 3 inches long by 1/2 inch wide and 3/8 inch tall and are made of a hard plastic like material.
Aug 28, 2014 | Whirlpool Dryers
When i run my GE Clothes Dryer, It has a high pitch squeak How can I fix this
remove the front panel inside there is what is called the top door bearing,its probably worn through the drum slides and into the plastic bearing creating this squeal part # WE3m26
Feb 10, 2013 | GE Dryers
Replace slide DPRS405EA0WW
you need the front 1/2 top bearing G.E. part # WE3M26,also the 4 drum bearing slides that are mounted on this bearing need to be purchased too as they do not come with the door bearing,you need 2 white slides ( Part # WE1M504) and 2 green slides, (Part# WE1M507)which can be purchased along with this bearing
Aug 20, 2012 | GE Dryers
Getting the message clean drum. Clean corona wire of drum unit. Need instructions on how to clean unit. What parts to I need?
You do not need any parts, just do the following.
1. open the front toner cover
2. take out toner and drum together
3. on the back side of drum unit you will see green or purple slider (it is used to clean corona wire)
4. push that slider few times from left to the right.
Important notice: you must leave slider on exact position to match black arrow on the drum unit.
BR
Sep 12, 2011 | Brother IntelliFAX 4100 Laser Fax
Radio wiring hook up
1996 Dodge Avenger Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/White
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange/Brown
Car Stereo Dimmer Wire: Black/Green
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Blue
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Orange
1996 Dodge Avenger with Infinity Audio Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/Orange
Car Stereo Dimmer Wire: Green/Yellow
Car Stereo Amp Trigger Wire: White/Black
Car Stereo Amplifier Location: Mounted under the rear deck. Some models have a black plastic trim covering the factory amplifier.
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
pls rate
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Aug 15, 2010 | 1996 Dodge Avenger
I have a GE profile Dryer DPSE810GOT and the dryer sounds like its running on metal to metal is the felt around the drum one piece or two and counld that cause it
The felt is two pieces. And, no, the problem is the drum support glides have worn through, allowing the drum to continue to wear into the front drum bearing. Replace the front drum bearing (WE3M26) and the drum slides (WE1M481) located at the top front of the drum.
Feb 28, 2010 | GE DPSE810EGWT Electric Dryer
How do i oil the belts? The dryer squeaks every time its turned on?
You don't oil the belts on a dryer. This will cause the belt to slip on the motor shaft and/or drum. Oil permiated into the metal of the dryer drum can ruin it causing any replacement belt to slip as well.
If the dryer is squealing, you probably need to lubricate the idler pulley wheel at the axle point (also known as a tension pulley). If this is a GE model they usually have drum slides and a drum bearing that support the front of the dryer drum as well. When they wear down, they begin to make noise. The drum slides are made of teflon and not only help support the drum, but ensures it turns smoothy. You may need to replace both the drum slides and the drum bearing.
If the model number is correct, the part numbers are as follows:
Drum Bearing - WE3M26
Drum Slide - WE1M481 (Blue), WE1M333 (White)
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need.
If you have any questions, or if your model number is different from the one you listed this question under, please post back and let me know. I hope this helps you.
Feb 24, 2010 | GE Profile Wizard DPSE592EAWW Electric...
Dryer drum causing squeak
Most likely the front support bearing. If this is the problem you will likely have to replace the slides too. The wizards have a ten year warranty. The bearing is part number WE3M26 and the slides probably need 3 or 4 of them are we1m333. Hope this helps.
Dec 11, 2008 | GE Profile Wizard DPSE592EAWW Electric...
GE Profile Dryer Model # DPSR473EWOWW SQUEAKING
If the squeaking has been going on for only a short time, you may be able to get by with only replacing the rear drum bearing, but if it has been going on for some time you should replace the drum bearing kit part # WE25M40. Also be sure to check that the front drum slides are ok, especially the one on the left side of the front drum support, as this one wears out faster. Drum slides #
WE1M481 and
WE1M333 and if front support frame is worn so that there is nothing left to hook the slides into you would need a
WE3M26.
Sep 17, 2008 | GE Profile DPSR473EW Dryer
Dryers Logo
60 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
