Question about Homelite Consumer Products Tiller Attachment
Pull starter cord wont return, so cannot pull start
  • 604 Answers
You need to order the replacement coil spring, this is a tricky job to replace and if you are not handy, your best bet is to take it to a small engine repair depot.
Posted on Mar 11, 2011
My pull cord won't release, to start engine.
if you cant pull it possible engine failure or debris in recoiler --check and inspect pull cord --remove plug and try to pull if engine turns it was air locked and should be able to start if locked solid have an internal failure -----if cord wont rewind return spring failure ,,rope jammed or debris
Jul 08, 2017 | Garden
The manual recoil starter I pulled starter slowly two or three times and then cord was loose no resistance what is the problem?
Sounds like the starter drive is jammed. Look for a large cog azt the back of the starter cord on the motor, manually push it in the opposite direction to the spin created when the cord is pulled.
Dec 29, 2015 | Garden
I replaced a broken starter cord and when I reassemble the starter won't turn. Any ideas?
Remove for the n-th time the pull start assembly. Confirm the engine will in fact rotate by hand. Turn the flywheel a full turn or more ensuring that the engine is free. You should expect to feel some resistance from the compression cycle.
Holding the hand crank assembly attempt to pull the pull-cord and observe that the hub rotates. When released the spring returns the cord and handle into the wound position.
If the cord will not pull or operate as expected then remove and reassemble the cord into the pulley making sure that the knot retaining the cord is small enough and does not interfere with the operation. U-tube has several videos showing how to assemble the cord to the hub.
Nov 21, 2015 | Garden
U tube chainsaw pull cord wont pull start
Some saws with autotmatic oiling will leak bar oil into the cylinder and cause this. Pull out the spark plug and hold the saw so the oil runs out of the spark plug hole. Pull the starter cord till no more oil sprays out of the hole.Clean the oil off the plug and start your saw. It will smoke more than normal till the extra oil is burned out.
Sep 05, 2014 | Homelite Garden
I have a ryobi hedge trimmer RHT 2660 DA why wont the pull cord wont return ?
If you can try and tap by the starter housing with a small hammer and then you need to get some lubricant spray injected in to the spring. If it wont go back in there is a chance the spring has either broke or become unseated.
Jul 28, 2014 | Ryobi Garden
Pull cord wont spin the motor
The engagement "dog" is probably rusted in place. Try spraying WD 40 on the recoil mechanism as you pull the starter cord
Jun 27, 2012 | Garden
I have replaced the pull cord in my Talon Silver Eagle but it wont return onto the pulley after starting.
The recoil assembly must be wound when installing the new rope:
Remove the recoil assembly from the mower, there are 3 machine screws.
Remove the old rope and get matching cord, make sure you get the correct diameter, usually 3/16 or 1/4 inch, and type, I believe it should be nylon braided. Do not cut the new cord.
Use a match to light the end of the cord and once it ignites, use an old rag to pull and form the end into a point.
Notice which way the pulley in the starter assembly rotates and hand spin it in that direction until it is fairly tight. Once it is tight, rotate it into a position such that you can push the pointed end of the cord from the outside into the hole in the housing of the starter and directly into the hole on the inner pulley. Tie a tight knot in the end of the rope inside the pulley.
Remove the clamp and let the rope get rewound on the pulley. Cut the cord, point this end and run it into the handle and knot it.
Gary
Feb 15, 2011 | Garden
I have been trying to turn on my chain saw. Ive pulled the handle back by the trigger gave a few pull on the rope. then i pushed the button in on the side also the push the button back in by the trigger...
The chainbrake should be activated when starting the chain saw. Activate the chain brakeby pushing the front hand guard forwards.b>Cold engine Start position, 1: Set the start/stop switch in the choke position by pulling thered control outward - upward.Decompression valve: Press the valve to reduce the pressure in the cylinder and makestarting easier. Once the machine has started the valve will automaticallyreturn to its original setting.Air purge: Press the air purge diaphragm repeatedly until fuel fills thediaphragm (at least 6 times). The diaphragm need not be completely filled.Grip the front handle with yourleft hand. Hold the chain saw on the ground by placing your right foot throughthe rear handle.Pull the starter handle, 4: Pull the starter handle with your right hand and pull out thestarter cord slowly until you feel a resistance (as the starter pawls engage)then pull firmly and rapidly until the engine fires.Push down the red choke control: As soon as the engine fires which can be heard through a"puff" sound, push down on the red choke control.Pull the starter handle (6): Keep on pulling the cord powerfully until the engine starts.
Nov 18, 2010 | Husqvarna 450 e-series 18" Chain Saw
My pull start cord won't retract. How do I fix it
Remove the starter assembly from the engine and pull the cord out--it should have spring resistance to pulling. If nothing, the rewind spring may be broken, or it may have pulled loose from one of the attachment points. Remove the cord from the pull handle and unwind it from the spool if it isn't already pulled out. Remove the spool from the frame to expose the spring--check the ends for breakage and the attachment points for damage (one will be on the under side of the spool). Repair or replace any damaged components and assemble the spring into the attachments. Wind the spool/spring about 2-turns CW, then wedge it to prevent unwinding. Fit the cord back into the spool and wind it CW until the cord has about 8" or so to feed out through the cord port. Fit the cord end back into the handle, tie an overhand knot, and push the knot into the handle bore. Remove the spool wedge and try pulling the cord several times to make sure it goes out and back smoothly. Return the starter to the engine and attempt starting. Hope this helps!
Nov 08, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The pull string will not pull out to start the
Remove the starter mechanism from the saw and try to turn the flywheel--it should turn freely except when the piston is rising against compression. If ok, pull the starter cord and watch for twisted cord or a damaged/split spool. Try to turn the spool CW by hand to see if it is bound up by something. Was the starter cord just replaced? If so, maybe the return spring was over-wound and can't be turned further. Hope this helps!
May 21, 2010 | Craftsman Garden
Homelite Consumer Products Tiller Attachment Logo
176 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
