Question about Kodak Easyshare C813 Digital Camera
On the bottom of the camera there is the area where you slide open and put the batteries in. The little "door" that slides open broke apart and I can't keep the door closed. Can you buy that little part?
  • 604 Answers
I doubt it, but you could just tape it shut. You might contact Kodak but like I said, not much change for a part like that, you might be able to purchase the case but pretty expensive and probaby very difficult to install the guts into. if you have all the parts to the door, you might be able to glue it back together.
Posted on Mar 11, 2011
How do I open the battery door?
With the display screen facing you, look on the bottom right for the door for the batteries. There's a tiny grey slide switch on the right side of that door with polk-a-dots that you have to slide toward the screen side of the camera. Hold the camera upside down and while sliding this switch away from you, you can slide the door to the right, which opens the battery compartment.
Jan 19, 2013 | Nikon Coolpix S30 Digital Camera White
I can not get my Power Shot S2 IS battery door open
with the camera upside down. slide the latch to the right, with the same motion slide the door to the front of the camera. I had to gently pry the door to move a little. you might find that there are no batteries currantly in it. thats the way i did mine. good luck your on your own.
Jan 02, 2013 | Canon PowerShot S2 IS Digital Camera
I recently won the Polaroid iF045 camera and I cannot figure out how to open the battery compartment. Help!
To open the Polaroid if045 , you will see a sliding lever on the bottom, slide that little lever to the back of the camera while at the same time ,sliding the battery cover to the right , this will open the battery cover.
Oct 14, 2012 | Polaroid iF045 Waterproof Digital Camera...
How do i open the battery door on my D3000
Try again. Slide the tab and pull on the door lightly. Or after sliding it, keep the slider in that position and turn the camera upright so that the battery presses against the door.
May 16, 2012 | Nikon D3000 Digital Camera
Hoe to remove camera card
Open the battery/card door on the bottom by sliding the catch toward the back then sliding the door to the outside following the arrow. Press down on the card with a fingernail and it should pop a bit. Grasp it and pull it out. It may be easier if you let the batteries drop out first; just make sure you put them back in the correct way.
Mar 13, 2010 | Nikon COOLPIX L18 Digital Camera
How do I open the camera up to check for batteries and film?
there should be a little slide door on the side of the camera or on the bottom slide it left or towards u and it should open.
Jan 19, 2010 | Polaroid One600 Pro Instant Camera
The date and time will not save on my canon powershot a560 when it is turned off and on.
Open your battery door. Notice inside that there's a little slide door inside labeled CR1220. Pry open this little slide door and remove and reinsert the encased watch battery (this battery powers the camera's clock). Removing and reinserting might fix it temporarily, but more than likely this battery is getting very low. Recommend going to your local drugstore's battery section and buying a replacement CR1220 battery. They're very common and inexpensive (a few bucks).
Sep 01, 2008 | Cameras
HP Photosmart R927 Battery Compartment door latch
Same problem, The small plastic tab that extends into the slot to keep the battery compartment door broke off. I can't locate a source for replacement part. I disassembled the slide and reversed it, breaking off the little tip that fit into spring, and it sort of works, but a new plastic slide would be much better.
Mar 21, 2008 | HP Photosmart R927 Digital Camera
KODAY DC3400 BATTERY DOOR BROKE
Easy Fix-
I had the same problem. Place the camera upside down with the battery door to your right. There is a plastic plate with the eject switch to the left. It has three philips screws. Get a jewlers screwdriver (Any hobby store, Harbour Freight, etc.) Take out the three small screws. Don't lose them. Get a razor blade and pry up the plate in the line just to the right of the top right screw. Only pry up about an 1/8 of an inch and only that corner not the whole plate. Then you can slant the new battery door so that the top part goes to the left under the plate and then straigten it out so that the tabs seat in the grooves. Repace the screws. Voila.
Good Luck,
-Joe
Aug 14, 2006 | Kodak DC3400 Zoom Digital Camera
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
Kodak Easyshare C813 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
