Question about Refrigerators
Where I can reset the margin of printer to narrow or zero.
  • 604 Answers
Not sure why this is listed as a refrigerator issue, but anyway, the margins are set in the software not on the printer itself. If you use Microsoft "word" its fairly easy to set, go to print setup and you will find the options to change margins and a bunch of other stuff.
Posted on Mar 11, 2011
How do I bypass the 1/4" unprintable area so my document bleeds to the edges of the paper?
This printer is not capable of "Full Bleed" printing.
You can change your margins in your software to all zeros or narrow to get the maximum print area.
Sep 25, 2014 | OKI C5150n Led Printer
I can't get my computer to print because it keeps saying the margins of section 1 are set outside the printable area of the page. I have a meeting to go to and It's important that I get this paper off the...
I assume this error is occuring in Microsoft Word.
  1. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  2. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  3. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  4. Click OK.
May 12, 2010 | HP Officejet J5780 All-In-One Printer
I need to print some cards with my printer, is it possible to reduct margin to zero? I have created the document without margins, but the printer cuts part of te documents... thank you for your help!
This is normal. Practically all printers have a 'non-printable area' which forms a border at the top and bottom and left and right hand sides of the page. Whilst your software may allow you to work with a zero margin, your printer is physically incapable of printing in the non-printable area and will simply cut-off any text or images that overflow into this region.
The best solution is to reduce the number of cards on your page so that you can bring the text back within the printable area of the page. Then print with normal or wide margins and trim the excess from your cards.
Mar 19, 2010 | Canon PIXMA MP210 InkJet Printer
When printing, there is a large margin and uses
you can shorten margins using F+. using narrow will make smaller margins
Dec 02, 2009 | Brother PT-1000 Thermal Label Printer
I am not able to print the portion from exactly start of the page of ms word document, why? Not able to show it in print preview??
Hello and Welcome to FixYa!
The portion within the Margins can only be printed, lessen the top margin at bit.
I remember the top margin for default is 1', change it to 0.5' or 0.6'
In Office < 2007 (Margins are in File > Page Setup)
In Office 2007 (Margins are in Page Layout > Margins > Set it to Narrow)
Note: If you printer is non-Laser (I mean if it is Ink-Jet) Do not make the margins too less, the printer won't be able to print it.
Sep 27, 2009 | Microsoft Office Word 2007 Upgrade Version...
The printer will not print on the half inch left edge of the page.
go to settings and change the left margin to 0.0. if in Word, then file->page setup and set the margins to what you want, left margin to 0.0 in your case.
Sep 02, 2009 | Laser Office Equipment & Supplies
Says paper too narrow but it isn't.
Can be that margins are set outside what are considered printable margins. Or might be that the optical sensor has been misaligned. Check the paper path/tray to see if the tray has the guides set to the correct size.
Aug 24, 2009 | HP Office Equipment & Supplies
Problems printing a booklet
What size paper are you printing on? Reset the side margin to make narrow and see if that helps.
Sep 23, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
Jun 29, 2009 | Lexmark P3150 All-In-One InkJet Printer
Always prints more to left than established margin
Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
Hope this helps. Bud
Jan 08, 2009 | Lexmark Optra T610 Laser Printer
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
