Question about Tools & Hardware - Others
Is there a manual for a sears jointer mod. 149.236223 I need to set the blades.
SOURCE: Need to find out haw to adjust cutter head and blades.
I called Jet and they e-mailed me a pdf file with the older manual. There is a toll free number on their website.
Posted on Jan 27, 2009
  • 86 Answers
SOURCE: I have inherited an older
Go to the bottom of the page of this link, under "Product Details", the manual is a PDF:
http://www.amazon.com/708457K-JJ-6CSX-Horsepower-Jointer-230-Volt/dp/B00006ANS5
Posted on Mar 01, 2009
efs_perpends
  • 1996 Answers
SOURCE: can not find replacement blades for delta jointer
I can't get a hit on that number, the model must be other. But it shouldn't be too hard.
Try to find a reliable sharpening service in your area; someone who does saw blades and knives for the cabinet shops will have a source for tool steel and carbide and can make you a set of knives for your jointer. Just get tool steel. While it won't hold it's edge quite as long as carbide knives, it will take a sharper edge to begin with, and should last just fine if you don't run sand through it.
If you have the original knives, hang onto them as they most likely can be resharpened to like new condition, and steel today ain't necessarily what it used to be.
The critical factor is the height. It's usually between 5/8" and 3/4" tall. You want them to be able to rest all the way down on the adjustable pistons without sticking up more than 10-15 thousands above the cutterhead. That will give you the most resharpenings from a set. You might want to invest in a magnaset to help with setting the knives in place.
Here's a link to the sharpening service I use: http://maps.google.com/maps?rls=com.microsoft:en-us&oe=UTF-8&um=1&ie=UTF-8&q=Precision+sharpening+%2B+Albuquerque,+NM&fb=1&split=1&gl=us&view=text&latlng=15322695688682105671
Finally, I would almost bet some contemporary delta replacement knives would work. If you find a place that will return your funds if they don't, you might be able to order them online. These guys will carry them if you can't find someone nearer you: http://woodworker.com
If I've answered your question or solved a problem, please take a moment to rate this posting...thanks!
Posted on Mar 28, 2009
efs_perpends
  • 1996 Answers
SOURCE: need manual for powermatic jointer model 60a
Try here. Otherwise please provide model number.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 03, 2009
efs_perpends
  • 1996 Answers
SOURCE: Looking for blades for a 6 inch craftsman
Most reliable sharpening services will be able to grind knives for your jointer that will work just fine. The key is to match the existing knives as far as thickness (guage) and height of the new knives. You want them to give you maximum life but not extend too far past the cutterhead when adjusted all the way down. I don't know about your machine, but on an 8" powermatic the tip of the knife shouldn't extend more than about .0012" above the circumference of the cutterhead. You can check this with a set of calipers and give the height to the sharpener, then just choose high speed steel or carbide and you're on your way.
If you check the overall length of the knives, sometimes they are slightly under the nominal length, and a 6" long knife could bump into the housing as the cutterhead rotates, so this is one other thing to check before you go ahead and order them 6" long.
But the short answer is, no problem. Just get a reliable sharpener to make them for you, buy a quality steel blank, and have him put a fine grit polish or hone on the knives when he sharpens them...
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 23, 2009
FIND BLADES
What is a MOD 74FD250? It does not return any searchable result on the Net
Nov 01, 2014 | Masonry Tools
How do i set knifves in wards powr-kraft jointer mod.no. 2508a
Lower the in feed table to keep it clear of your work, hold a straight edge on the out feed table, both sides, adj the knives to just touch the straight edge, both sides the same, all knives set the same, should work like a charm, do not answer the phone while you are doing this. check all jib screws twice to make sure they are tight. Hope this helps.
Jan 28, 2012 | Delta Jointer Blades 6 Inch Fits , Jet...
Jointer blade installation ?.......model 103.21820..... spacers ? ....blade holder? when making a pass ,the part being machined bumps into the outfeed table
YOu have the infeed table set far too low, and/or your knives are not set even with the height of the outfeed table. You should very rarely need to take a pass of more than 1/16 th of an inch on a jointer, unless the wood you're jointing is very rough cut or cupped/warped.
Please also see the answer given in this article for information about where to download a user's manual and find information on using and tuning up a jointer.
Mar 14, 2011 | Masonry Tools
Eg2175need manual for craftsman 6inch jointer model number 113 20 680
Go to partsdirect.com and type in your model number. From there, you can order whatever you need for your jointer.
Feb 06, 2011 | Delta Jointer Blades 6 Inch Fits , Jet...
I need to find blades to fit a delta 6" X5 jointer, model 37-866x
go to Dewaltservicenet.com and under the service locator on the right hand side type in your information. The blade set number that I came up with is 37-658 and they show that as qty 3 in one package.
Mar 19, 2010 | Delta Jointer Blades 6 Inch Fits , Jet...
Jan 26, 2009 | Delta Jointer Blades 6 Inch Fits , Jet...
Technical
a jointer includes infeed and outfeed tables. A set of rotating blades is positioned between these two blades. A fence is set on one side of the jointer to serve as a guide. The infeed table and outfeed table are adjusted so that they are parallel, but the infeed table is slightly lower thereby exposing a small amount of the cutting blades. The woodworker then presses the lumber against the infeed table and pushes it onto the outfeed table; the rapidly spinning blades remove a small amount of material. If the wood is particularly warped, several passes on the jointer may be required.
Aug 27, 2008 | Delta 37-108 Push Blocks for Jointers
Tools & Hardware - Others Logo
114 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
