Question about Toshiba Computers & Internet
Toshiba l505 have a green light for power cord and battery but won't power up. This has happened twice. Both times it was when I was working from battery power only and the battery completely ran out. When I tried to plug in power cord, it won't power up.
    Genius:
  • 1,542 Answers
Hi
have you tried to remove the battery then plug in and try to start laptop
and see if it starts up ok
then put battery back in and leave switched off but plugged into the electric to
charge up the battery for 2 or 3 hrs
then try to power up the laptop again
many thanks
Posted on Mar 12, 2011
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
Toshiba laptop L505 won't turn on
Remove main battery and turn on, next! check the power supply for correct voltage, if okay! sub the ram out one out a time and power on and repeat. If still no result, the DC jack in the laptop is a common issue, suggest a professional to assess.
Mar 13, 2012 | Toshiba Satellite L500 Series Notebook
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My daughters Toshiba satellite l505d will not boot up correctly. It starts but then nothing happens. What do I need to do. Have already taken battery out and restarted. Any help would be helpful.
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
If yes - Battery is defective
If no - Motherboard Problem/AC adapter
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. Reformat your computer and install necessary drivers and applications
Thanks. Cheers!
Apr 15, 2010 | Toshiba Satellite L505-S5966 Notebook
Toshiba Satellite A15-S127 won't power up
basically this may be the fault of ram or ram slot connectivity problem.
Aug 23, 2009 | Toshiba Satellite A15-S127 Notebook
Toshiba satelite r15-s822 will not power up
Take the battery out and try starting it with just the power cord plugged in.
Sep 25, 2008 | Toshiba Satellite R15-S822 Tablet PC
Laptop won't turn on/stay on
Is the fan blocked?
If no air goes in, CPU could overheat.
Aug 26, 2008 | Toshiba Satellite 1135-S125 Notebook
Computers & Internet Logo
87 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
