Question about ASUS Computers & Internet
No thing on screen and power does not switch off
  • ASUS Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help don
Posted on Mar 11, 2011
When the Garmin powers up it goes to the screen explaining the dangers of driving and reading...anyway pressing the "accept" button is not functioning. Powering the system on/off has no affect. Any...
The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
To reset a nuvi 3xx or 6xx:
  1. Lift the antenna
  2. Locate a button with the word Reset inside
  3. Press the button to reset the device.
The device will now switch off.
Oct 19, 2010 | Garmin Nuvi 660 GPS Receiver
Just bought a 9250 vision fitness treadmill and when we first plugged it in the screen stays blank?? What should we do?
First Your outlet to see if power is their, then check on/off switch usually their is an internal light in the switch to show power is to the switch then check the breaker button next power switch. these are a few things to look at. Check if the safety key in place on the upper console
Feb 01, 2010 | Dmm Vision Fitness T9500 Treadmill
My main menu screen and monitor "tour" constantly switch back and forth...sometimes my screen flashes between the different viewing modes. All of this just happens and nothing I do to the buttons on the...
csofhaus, First place (thing) I would look is at the monitor's "switch-mode-power-supply!!! When Very Strange things start to occur with LCD back-lit monitors that's the FIRST place I would look for a problem.
12fixlouie
Dec 10, 2009 | Gateway Computers & Internet
After applying picture on the screen atfer 45 minutes screen becames none thats thing was caused by what?
check the power options in control panel, see if monitor is set to go off in 45 min.some ahve a setting in the bios for the same check it also
Jul 10, 2009 | Dell (71PXP) KVM Switch
Pc entering power saver mde
This message apears when there is no input coming from your computer. There should be a bution you can puch on the monater that would cnahge it from digatail to analog this may be the problem that you are having problems with
May 21, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
MONITOR KEEPS SWITCHING TO STANDBY
Either the power supply is going bad (power light will be orange or off when it goes dark) or the screen itself has the problem (inverter?). If the power button stays green but the screen goes dark, that'll be the problem.
Jan 10, 2009 | Computers & Internet
Blank screen
the power is supposed to stay on when that little plastic button is pressed(screen switch)the screen switch activates hibernate and power saving;if you press the power button a screen will open informing you what programs are currently working.by shutting down you have caused an illegal command.
hopefully if you restart in safemode then shut down correctly and restart every thing should be ok.
Mar 03, 2008 | Dell Inspiron 700M Notebook
Toshiba e310 no reset
When it is reset the screen is just a series of vertical lines or just plain white. if it beeps it isone quick beep.
It appears to do things when you move the stylist over the screen yet can't go to the main screen.
I have followed factory reset (switch off then on), (reset power till screen on then release power), (disconnect power plug from battery to board). NOTHING worked
Jan 24, 2007 | Toshiba e310 Pocket PC
Computers & Internet Logo
37 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
