Question about Elkay E-granite Single Bowl Sink BLACK ELG2522BK
I just had the mocha elkay granite sink installed yesterday, and I am noticing a whitish film on the walls of the sink, it looks like hard water deposits. Itdoesn't wipe off with water.....the bottom of the sink looks fine
Just try a little white vinegar and see if that takes the white off
Posted on Jun 04, 2015
  • 528 Answers
If you used anything with bleach in it this may be the problem.
Posted on Mar 11, 2011
My black granite countertop has a stain which must have soaked thru seal, now shows a whitish spot, How can I fix this? Thanks
Remove Water Marks/Stains from Granite Countertops ...
? 2:55
https://www.youtube.com/watch?v=VO571n_4Jns
Jun 10, 2011 - Uploaded by KristyU2178
... the water mark/stain from my black granite countertop in mybathroom. ... @TheJefferyjones The stains ...
Removing Stains from Granite Countertops - YouTube
? 5:51
https://www.youtube.com/watch?v=hPPFe8902Zg
Oct 1, 2010 - Uploaded by MonkeySee
I left a bag of sweet potatoes on my black granite and there were some ... @Oxidized181 yes I have lots of ...
Stains on Black Galaxy Granite - Countertops
Jan 17, 2016 | Home
Elkay vrc hd8 drinking fountain is leaking how do i fix it
Replace the gaskets on th ep-trap and thre tray to drain gasket.
Aug 18, 2014 | Elkay EZS8-L Single-Level Wall Mount Water...
This fountain is located at my church, the problem: The water dispenses, then it doesn't. Wait a while and it dispences again, then it doesn't. It did not do this before now it does...
sounds like there is a build up of minerals in the water line that is coiled around the cooler unplug from wall take off cover and run fine wire through copper tubing
Aug 02, 2011 | Elkay EZS8-L Single-Level Wall Mount Water...
To much water presure
just needs ajustment need to take the shroud off and a screwdriver
Jul 17, 2011 | Elkay EZS8-L Single-Level Wall Mount Water...
Plumber installed mocha e-granite sink and used white silicone! There is a bit around the drain now, sort of a halo... White film on my mocha sink. Should I try some denatured alcohol to clean it?
Just live with it for a few more weeks and see if the problem still bugs you.
I will guarantee you will be unhappier after messing with the minor halo.
1) This is because there is no home-use solvent that dissolves silicone.
You can try acetone or denatured alcohol but neither will work.
Only thing that removes silicone is a blade.
2) As a painter, I work with silicone caulk jobs all the time, because no paint sticks to silicone.
Silicone is a nuisance product to my profession.
Silicone does not cut off smoothly using ANY tool, even single-edge razor blade.
The edges tear, they do not cut.
So when you mess with it, the edges will tear up and the job will look WORSE the more you try.
I guarantee it will look worse.
Add a comment and let us know if you find a magic bullet solution for silicone.
Feb 27, 2011 | Elkay E-granite Single Bowl Sink BLACK...
I have power and water to the fountain, but fail to get the water to pump to the fountain head
The water pressure get the water to the spout it is not pumped there. You have a valve in the off position some where. http://www.elkayusa.com/cps/rde/xbcr/elkay/12-23D_EZ_EZS_EZSD_EZD.pdf this link shows an electric solenoid valve and also a manual valve.
Feb 18, 2011 | Elkay EZS8-L Single-Level Wall Mount Water...
Water pressure is low on the elkay fountain
if you mean the amount of water that comes out of the bubbler head....you can adjust that by accessing the push button cartridge and turning it to adjust how far it is pushed.
Oct 18, 2009 | Elkay EZS8-L Single-Level Wall Mount Water...
How do the clips go on 3/4 granite 3/4 plywood
You might have to route out the wood where you want to put the clips because the clip hardware is not intended for a top thickness greater than about 3/4 inch
Jul 15, 2009 | NEPTUNE/ELKAY AG2522 STANDARD SERIES...
Wobbly faucet on new elkay sink
this faucet comes with diffrent hold downs for diffrent sinks on is wider for stainless sinks the other is smaller for granite or corian sinks, it sounds like your plumber might have put the wrond spacer under the facet where it mounts to the sink,, it doesn't matter the sink or the faucet they all come with proper adapters, and I do know that moen and delta have them in the box with the faucet,,, good luck with yo people, this faucet of yours even comes with the plastic tool to put the faucet in because it has a long shank with threads on it and is hard to get a wrench on
Jun 07, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Elkay water cooler does not turn on
You need to first check the circuit breaker for that wall outlet, and see if you short circuited it from water going behind the wall. if that is the case you need to reset it at the circuit box and then run a bead of clear silicone on the back of the water cooler to prevent water from dripping down the back .
May 30, 2009 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Elkay E-granite Single Bowl Sink BLACK ELG2522BK Logo
663 people viewed this question
Top Elkay Home Experts
Donni Steen
Tom Chichester
Are you an Elkay Home Expert? Answer questions, earn points and help others
