Question about Toshiba D-VR4 DVD Recorder/VCR
My new Toshiba D-VR7KC2 DVD Video Recorder will not format any DVD-RW disks. Have tried with both New DVD- and DVD+ RW DVD's and ones that have already been used in this unit to record on. Either the Set-Up Format doesn't display or if it does, nothing happens when you select format.
SOURCE: Toshiba DVR recorder incorrect disk message
You could try the factory initializing process I found on another webesite (AVS Forums): "Had this message pop up a few weeks ago. Tried the solutions in the manual, no go. Tried unplugging it for 7 days, no go. Called Toshiba customer service @1-800-631-3811, the tech told me: 1) turn on TV and set to receive your DVD signal 2) Turn on DVD player and remove any discs 3) put Dvd / VCR selector on DVD 4) at the same time, push channel selector button UP (^) along with the PLAY button 5) hold the buttons down until TV screen shows "Initializing" message, release buttons, let DVD player go thru it's reset cycle and shut down 6) turn DVD player on and watch your DVD movies now Works like a charm. Put this in your manual for the next time." My unit has not worked since December of last year, I only had it for one year and it conveniently stopped working right after the one year warranty. My unit was not functioning whatsoever past turning it on, but when I did the factory initialization I was able to operate my unit again....UNFORTUNATELY, it still does not read disks, I still get the "Incorrect Disk" message. I guess I could consider it progress. But still try it, it may work for you. My unit just seems to be fried beyond repair. If anyone has any suggestions on how to correct the incorrect disk problem, I would be greatly appreciative. I'm not ready to throw mine away yet!
Posted on Sep 08, 2007
SOURCE: Sylvania DVR90VE DVD Recorder / VCR - formatting DVD-RW
This unit only supports 2X -RW discs or 4X -R discs.
Posted on Oct 28, 2007
night71
  • 328 Answers
SOURCE: dvd - rw
The full manual can be found here. http://support.toshiba.ca/support/ceg/manuals/#
SOURCE: Problem with DVD-RW's
I had a very similar problem with my Toshiba D-R2. I found two firmware updates on the Toshiba website. One was called 1314.iso and the other was called 1416.iso. All the instructions are there for how to burn a CD and install it on your DVD recorder. It solved my problems - hope it works for you.
Posted on Dec 12, 2007
  • 476 Answers
SOURCE: Playing recorded DVDs on PC or other DVD player
Recordings from your DVD recorder should play on other DVD players as long as you finalize the recording on your recorder.
A PC should recognise an un-finalized, but only in a DVD writer drive.
There is a firmware upgrade available for this model. Follow this link and select your particular country version DVDR3320/XX
http://www.support.philips.com/support/html/index_gb_en.html#../~scripts/xsltransformsearch.asp?url=http://www.sms.philips.com/catalogue/list?sid=SMS||type=CONSUMER||locale=gb_en||mode=prod_text||item=dvdr3320v||page=1||show=50&xsl=search_result.xsl
Select Software & Drivers and click on the link to the zip file.
Follow the on-screen instructions.
Posted on Mar 02, 2008
How do I fix the problem if the empty disc says can't record on this disc?
Try a new / different disk recognized by this recorder. Make sure you're using DVD+RW disks. Others will not be recognized.
Toshiba R410 Specs CNET
Feb 25, 2015 | Toshiba DR410 DVD Recorder
Can't make dvd's from my recordings
The recorder supports these formats
DVD-RW · DVD-R · DVD+R · DVD+RW
There shouldn't be a problem with the speed, maybe a compatibility issue with brands.
Also it might be your lens is dirty have you tryed a cd/dvd lens cleaner disk? dry/wet?
May 17, 2008 | Lite On LVW-5045 DVD Recorder
For some reason I can no longer copy from my VHS tape to my DVD disk in my Toshiba DVR620KU DVD Video Recorder. I have tried some of the same tapes which had copied just fine in the past. I am using the...
How old is Toshiba DVR620KU recorder and how long it started this problem?
Does it playback previously recorded discs correctly?
Did you tried lens cleaning disc in recorder to clean optical lens?
These info will help me to suggest a solution.
Thanks.
Jul 22, 2011 | toshibadirect.com
Won't format new DVD-RW disks
i did everyting today to fix this. bought new dvds, name brands different, tried finding codes, called the number. trust me. try this. clean it. thats All i did. cleaned it with a dvd cd cleaning disc, the one with two little brushes on it, nothing special, ran it until i heard the beep, popped my dvd in, they all worked. everyone, im still recording. i ran it about four times. now, if you tried to burn a dvd, and got the error, throw that dvd away. because i tried about ten dvds. after i fixed it, THOSE dvds were no longer usable. dont know why. hope this works.
Sep 18, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
Disc initialization Toshiba D-R250SB recorder
can i suggest you record vhs tapes on maxell dvd-r or tdk dvd-r (if you wish to keep them) used the dvd-rw to record those sporting events / movies or specials that you might not be around for....(because any one can accidently erase an dvd-rw).......now that formatting dvd-rw issue. i found that dynex http://www.dynexproducts.com/c-11-storage-media.aspx dvdv-rw works best with toshiba . i record all the ultimate fights erase (format) after i look at and on to next good luck
May 28, 2009 | Toshiba DRW2 DVD Recorder
Says blank DVD-RW is not formatted, then formats -- then error
I have same TOSHIBA D-VR4XSU VCR/DVD RECORDER. According to the
manual, you (COULD) can use for recording: DVD-RAM, DVD-RW and DVD-R (see page 50). WRONG!!! I bought all 3 types of discs, but after few
weeks I got same experience you got now. Just type DVD-R works. The other
types were - wasted money and a lot of time trying to finalize the disc. I had to
throw all into the garbage. Try DVD-R and you should?? be O.K.
Dec 13, 2008 | Toshiba DR4 DVD Recorder
DVD-RW Recordables
This problem also happens when you try to use vide tapes from other countires inside american vcr players and vice versa. The problem is a format incompatibility. There was several differnt dvd formats when dvds were emerging and in some countries they havent updated to the latest format. My solution would be to get a new dvd recorder or try to change the formats of the files on the disks.
Jun 06, 2008 | Televison & Video
Dvd - rw
Oct 28, 2007 | Toshiba D-R2 DVD Recorder
Jul 28, 2007 | Toshiba D-R2 DVD Recorder
Open Questions:
See all Toshiba D-VR4 DVD Recorder/VCR Questions
Toshiba D-VR4 DVD Recorder/VCR Logo
304 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
