Question about Seca 710 Waist High Mechanical Balance Beam Scale
I have a Seca model 707 waist high digital scale and starting last month it started going 5 lbs heavy for a few weeks than the correct weght now its back to about 5 lbs heavy. is this fixable?
  • 604 Answers
Get out the operation manual and look in the index or glossary for the "calibration" routine. it is a failry simple process of recalibration. As these units age the solid state components inside chage a little bit. it needs to be reset, that's all
Posted on Mar 11, 2011
John deere L118 engine just stopped while mowing like it ran out of gas or electrical shutoff, started back once and ran for a few seconds and died again. it just had a tuneup last month, I also put o
WATER IN GAS CLOGGED CARB REBUILD IT IF WATER IN GAS DRAIN IT OUT DRIAN CARB BOWL MAKE SURE NO WATER IN IT TRY TO START IT IF DOES SAME CHECK COIL SEE IF IT IS SPARKING WHEN IT SHUTS DOWN IF NOT REPLACE COIL 60.00 THEN CHECK FUEL PUMP GOOD PRESSURE 3TO 5 LBS CHECK ALL THIS AND LET ME NO WHAT HAPPEN WILL GO FROM THERE TO CHECK MORE THE REDNECK
Sep 01, 2014 | Garden
I have a Seca 703 digital scales, When I turn on it says Er:1:40 Can you help me?
This could be a power issue. Make sure your battery pack wire connections are good. If they are loose, I suggest purchasing the Seca 400 power adapter, which works with this model.
Sep 18, 2011 | Seca 769 Digital Scale 400 Lb with Bmi and...
How to calibrate seca 354???please help me...
I don't know if the 354 can be calibrated.
Here are calibration instructions for the 374. It includes a toll free number to call seca in case this doesn't work.
http://ons.wvdhhr.org/Portals/20/PDFs/policies/2.12%20Anthropometric%20Measurements%20Attachment%20-%202.pdf
May 19, 2010 | Seca 354 Digital Baby Scale Pediatric...
New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
Jan 16, 2010 | Jobar International Idea Works Wireless...
Scale is not weighing correctly. Weighs correct
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
Jan 04, 2010 | Health-O-Meter Health o meter 402KLWH...
Balance beam wants to stick at about 300 lbs. not smooth moving
I contacted the manufacturer and here is there reply.
No need for oiling or grease, but tip the scale on its side, and look
under the base. There will be four "connection points" where pivot pins
connect to the linkage assembly; see if any of those pins or linkage
points are bent or look different from the other ones.
Then, note down the serial number of the scale located on the side of
the base, or behind the column of the scale at the top or bottom of the
column, and call our Maryland repair center at 800-542-7322 ext. 111 and
speak with Tyson Long from 9:00 AM - 4:00 PM Maryland time to describe
the issue and for further troubleshooting over the phone.
I have attached our new catalogue in PDF format as well. FYI: The model
703 is a very popular, extremely heavy-duty, high-capacity digital
column scale that is a popular alternative to the mechanical physician
scales in the gym and schools environment.
Kind regards,
William Morris
Sales Support
seca north america west
Medical Scales and Measuring Systems seca corp.
3401 Centrelake Drive, Suite 320
Ontario, CA 91761
USA
Telephone +1 909 605 7600
Telefax +1 909 605 7654
E-Mail william.morris@seca.com
Internet www.seca.com
Jan 26, 2009 | Seca 700KG Balance Beam Scale With Wheels,...
Err 12 and Err 16
Dear FixYA
Was advised to send to Scales to another company to be fixed. Therefore no longer need your assistance.
Thank you
Julia
Jan 22, 2009 | Seca 354 Digital Baby Scale Pediatric...
Seca 710 Waist High Mechanical Balance Beam Scale Logo
662 people viewed this question
Top Seca Health & Beauty Experts
pawnpower
Jaye t rock
Tom Chichester
Are you a Seca Health and Beauty Expert? Answer questions, earn points and help others
