Question about Kenmore Sewing Machines
30 stitch kenmore....model # 385 1884180 serial # 72004581 having problems with the thread bunching up on back side of material. not sure if my settings are right. lost manual for my machine,what should they be set on?
  • Kenmore Master
  • 1,564 Answers
It really depends on the type of material you are sewing. But most machines are set at around 4 from the factory. remember right to tighten, left to loosen.
Posted on Mar 12, 2011
  • sylviaivie Mar 12, 2011
    It took me a while but I finally found your threading diagram which has information about tension for your model as well. The diagram has it set at "5" I hope it helps!
    http://www.sewusa.com/Threading_Diagrams...
I am having adjustment problems on my machine, it did not have an owners manual. missing stitches and bunching up underneath the meterial
Have you changed the needle ? Is the fabric a knit ? If the needle has been used for awhile, it may be dull. Many modern fibres are quite hard on needles, which need to be replaced fairly often.
Many knit fabrics require a ball point or Q needle.. [ Kenmore\'s brand of ball point knit needle]. Many knits are notorious for causing skipped stitches and a special needle for knits can really help with this.
If thread is bunching up, is this underneath or on top of the fabric ?
If it is underneath, the top tension may need to be adjusted. Mal adjusted top tension can cause a lot of problems, and the mechanism that controls it can become worn and may need service or replacement.
Oct 01, 2014 | Kenmore Sewing Machines
Shuttle action not working, doesnt catch the down thread, bunches up thread and breaks needle.
Hi. I did not have this exact problem with my Featherweight. My machine was not stitching properly (top stitch looked so-so, but lots of thread bunching on underneath side of fabric). I took it to repair shop and learned that I was threading the needle thread on the wrong side of the metal plate which is part of the take-up arm (I do not think that the threading instructions make this distinction). After the repairman pointed out the problem & threaded the machine, it made a proper stitch.
My suggestion for this issue: check the bobbin threading. My bobbin has to be inserted so that it turns counterclockwise in order to catch the down thread.
May 27, 2014 | Singer Featherweight II 117
My kenmore is about 30yrs old .Never had a problem till now. I was sewing and stitched over a pin, broke needle,replaced needle. Now the problem is that the top thread bunches up underneath,also after i...
Sounds like the timing adjustment of the bobbin case has been upset. Have that checked, it involves an adjustment on the gear that drives the bobbin case.
Feb 22, 2011 | Kenmore Sewing Machines
TOP THREAD ON kENMORE 1791 BUNCHES UP IN BOBBIN AREA ,DOES NOT STITCH
Are you using kenmore needles? I had the same problem when I used certain needles like singer ... Make sure the thread is wound correctly on the bobbin and going into the needle in the correct direction.
Mar 25, 2010 | Sewing Machines
I have an older kenmore sewing machine. It's been
When I have run into similar problems with my older Singer, it's because there is a bit of thread caught somewhere in the bobbin mechanism that doesn't allow the shuttle to run freely. Take the bobbin assembly apart and use a bright light to see if you see any bits of thread in there.
Good luck and let me know if this works!
Jan 14, 2010 | Kenmore Sewing Machines
My new sewing machine, just opened to use, is bunching thread on the underneath or bobbin side when I attempt to straight stitch. What is causing this to happen. Thanks.
re thread the top and bobbin threads
after pulling up the bobbin thread pull both threads to the back and hol them when stitching the first few stitches
with out holing the threads the machine will pull the thread into the machine and bunch the thread
Aug 24, 2009 | Kenmore Sewing Machines
Wont sew thread bunches up
Hi!
I think you are threading the top of the machine incorrectly. Make sure that what I'm saying is correct, use two color threads to sew with- and you will see that it is in fact the top thread that is bunching.
This might be a tension problem. Could be the bobbin is not threaded in the case right. First, check the threading of the bobbin and then check the stitch.
Next, adjust the tension on the bobbin case. There is usually a small screw on the case that can be tightened or loosened. I think you may need to adjust it a bit or adjust the top tension knob, just a small bit at a time. It the top does not change the stitch, then go to the bobbin case and adjust the screw to tighten the stitch a little bit more.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 19, 2009 | Kenmore Sewing Machines
Kenmore sewing machine
Make sure your needle is in correctly...most machines are flat to the back except the really old ones.
Dec 10, 2008 | Kenmore 15516 Mechanical Sewing Machine
Bobbin thread bunching
I have a Singer 2950. The thread keeps getting bunched up on the reserve side of the fabric, and does not stitch. It is driving me crazy. I think I have the bobbin threaded correctly, as well as the machine. I have tried everything! Please help!
Oct 22, 2007 | Sewing Machines
Sewing Machines Logo
437 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
