Question about Electronics - Others
Won't start. No spark. Suspect oil alert.Only ran twice out of box. Had to buy another generator as I couldn,t take the time to fiddle. 10 or 15 yrs. ago.
    Sergeant:
    Champion:
  • 250 Answers
That is easy enough to tell if it is the oil alert malfunctioning by disconnecting the wire that goes to the oil alert and making sure the wire is not grounded and check for spark.
Posted on Mar 11, 2011
Homelite hgn 0960a generator wont start no spark
Change Spark Plug. Check The starting Switch with a Multitester if it have continuity.Start it again and check Spark with the spak plug unplugged and with the crankcase check the spark.
Check the oil level. almost all the new and modern generators have included an oil alert gadget that cut off for saving the engine.check oil level and refill if it need.start it again.
Sep 02, 2014 | Electrical Supplies
I have fire and gas but will not start oil alert light on when crank
By fire I assume you mean spark at the plug. When turning the engine over with the key and the oil alert light comes on the spark is interrupted by grounding the system thus the engine cannot start.
First, look at the obvious things, check oil level if it is at the recommended level smell the dipstick if it has a strong smell of gas
change the oil and try to start it again. Be sure the plug is not soaked with raw fuel before you try the restart. I the problem persists you can disconnect the wire from the top of the low oil sensor.Try to start the gen. if it starts change the low oil sensor.
I hope this all makes sense to you , good luck with it.
BR
Jul 24, 2014 | Honda 3000 Watt Portable Generator
Have a honda 11 horse on a north star power washer that has no spark,yes the switch is on.
Cause of no spark can be determined by process of elimination. Good to have a new sparkplug on hand to eliminate plug as fault. So start by replacing plug with new or test plug on mower /edger etc. for spark. If plug ok, then temporarily remove the wire connected to oil alert system (oil alert will ground coil if oil low or dirty). With oil alert unpluged, and no spark suspect sparkplug boot or coil. The sparkplug boot threads on to the spartplug wire and is what actually fits-on to the spark plug. You can test the coil by removing the boot and inserting piece of paperclip wire, or small screw into end of the coil wire and hold close to engine ground while pulling rope. If still no spark suspect coil. If spark, replace the boot. Good luck with repair.
Jul 04, 2011 | Northstar Garden
No spark on B&S industrial engine fitted ti Stephill generator
Always have a new spark plug handy to determine if faulty plug when no or weak spark. If your engine has an oil alert, disconnect sensor wire and re-test. If still no spark suspect spark plug boot or coil. New or used coils are available at small engine repair shop. If you have access to growler (used for testing armature), by placing coil on growler with one leg on each pad, you can test coil for signs of life. Good luck
Jul 02, 2011 | Briggs & Stratton Garden
Yamaha 6600de generator dies 3 seconds after starting
When you pull the bowl off of your carb is it clean? If not you have some contamination possibly inside. You might want to remove the carb and blow compressed air through all the vents a ports.
Sep 24, 2009 | Reliable Yamaha YG4000D 4000 watts/33.0...
2 year old honda eu1000i generator with new spark plug fresh oil fresh fuel clean air filter starts eazy runs for 2 mins then dies
SOUNDS LIKE TO ME YOU HAVE A PROBLEM IN THE OIL ALERT SYSTEM, IF YOU HAVE THE REPAIR MANUAL IT WILL TELL YOU HOW TO TROUBLE SHOOT IT!!!
Aug 30, 2009 | Electrical Supplies
EB 2500 starts initailly, but then dies. I have fuel flow and good spark. I have also checked the float and needle valve and both seem to be good.
DOES THAT HAVE A OIL ALERT ON IT? IF SO MAKE SURE THE OIL IS TO THE BOTTOM OF THE THREADS AND YOU CAN UNHOOK THE YELLOW WIRE COMING OFF THE SILVER BOX TO BY PASS IT AND TO SHOULD RUN!!!
Jul 02, 2009 | Electrical Supplies
Briggs engine/ genreator
change spark plug and add small amount of starting fluid to breather pull with all settings in proper place if it is going to start it will or you have other problems
Nov 04, 2008 | Coleman Propane Forced Air Heater...
Electronics - Others Logo
97 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
