Question about Microsoft Xbox 360 Console
I was getting an error message when trying to play a dvd or game in my xbox 360 so i replaced the dvd drive with a brand new one now it only plays dvds, when i put a game in it says play dvd? can you help me
  • Anonymous Mar 12, 2011
    yeah it was brand new it was a benq, the only think i am using that is different is the power pack from my old xbox would that make a difference
  • 661 Answers
Are you sure that the DVD drive that you put in is the same brand aas the one you took out? microsoft has 3 different suppliers for dvd drives. BenQ, Phillips, and Samsung. Also, check the lens for dirt or scratches.
Posted on Mar 11, 2011
  • 1 more comment
  • Eddie Chen Mar 13, 2011
    I'm not sure, but i think you may have to flash the drive with the correct firmware first. Have you done that?
  • Eddie Chen Apr 01, 2011
    No, it wouldn't. If you still have your old broken drive, Pull out the PCB(the computer chip on the bottom once you remove the metal casing) and swap it out with the PCB on the new drive. It should work now. If not, you may have a broken trace or faulty connection somewhere; i couldn't tell you where though, with me not being there and all.
  • Anonymous Apr 04, 2011
    it was a benq drive it plays dvd but not games
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Tip
When you try to play a DVD game on Xbox 360 it tries to play as a movie?
c on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
on Feb 18, 2010 | Video Game Consoles & Games
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
Feb 18, 2010 | Microsoft Xbox 360 Console
When i try to play a game it keeps sayiny play dvd
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this mayhappen:
Jan 15, 2010 | Microsoft Xbox 360 Console
Xbox 360 arcade pal game read error
You will get this error when your laser is in need of replacing. The other message you will get is open tray. If your system will play regular movie dvd's but not games then replace the laser. You can find them pretty cheap on ebay.
Sep 11, 2009 | Video Game Consoles & Games
Error message, play dvd when playing games
either deal with it. Your cd drive is going.... get it fixed, or buy a new one
Apr 04, 2009 | Microsoft Xbox 360 Console
360 reads game discs but it won't play game and it says play DVD
The problem is that the laser is either dying out, is dirty, or is not getting enough power.
so try to fix it using these steps...
- first open the 360 and pull out the dvd drive and open it up too.
- clean everything out good with compressed air, and q-tips dipped in alcohol.
- now you need to adjust the power going to the laser.Sometimes you may have to try multiple settings before getting it justright. Just keep adjusting the resistance lower and lower until itworks.
- if you tried multiple settings and still get the errors, then either get a replacement drive, or a new laser for it. Click Here for how to properly install the new laser.
- if you get a replacement drive, please not that there is a key in the pcb of the drive that must match the key from the motherboard, so you must either spoof firmware with the key, or swap out the old pcb board and put it in to the new drive.
If you need more dvd drive repair help click here
Dec 23, 2008 | Microsoft Xbox 360 Console
XBOX 360 - Games will not play -
a red light appears instead of green
Jul 13, 2008 | Microsoft Xbox 360 Console
Message "To play game put game in xbox 360 console"
Pick up in the DVD is bad or weak and will need replacing.
Or replace the whole DVD unit.
Make sure the disks are clean and not too scratched up
Check here for more things to try
Nov 07, 2007 | Microsoft Xbox 360 Console
Xbox 360
hard drive not reading game, faulty hard drive, get it changed inc box. this is also a common microsoft fault with this console.
Aug 03, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
111 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
