Question about Whirlpool LER5636P Electric Dryer
Dryer takes very long to dry it is a admiral mod aed4475tq1
  • 552 Answers
Most likely this means you have a blocked vent. Check the vent hose behind the dryer followed by the vent in the wall.
http://www.appliancerepairlesson.com/
Posted on Mar 12, 2011
Admiral designer series heavy duty giant capacity 20 lb dryer
two possible problems
the air blower is not running properly
too many clothes being dried restricting air flow
Nov 24, 2016 | Admiral Dryers
Whirlpool admiral clothes dryer won't turn on. It's approx 8-9yrs old & in good condition. The Model number AED4475TQ1 Serial number MY1739210 Type DWJR-ELE-2406026-FM54
Check breaker in breaker box (30 amp). Check door switch plunger on door, check door switch. Check dryer plug in to outlet.
Sep 06, 2015 | Whirlpool Dryers
Dryer admiral aed4475tq1
Check heater element itself may have a short to casing seen this many times bra wire most comon cause stuck in heater
This dryer is a whirlpool disgn
Heater coil may be shorted to case
Dec 05, 2013 | Dryers
If an "Admiral" dryer stops getting warm or hot, wouldn't it be the hot/warm selector switch?
it could be the element burnt or restricted venttube or maybe even a burnt wire from the pigtail take the cover off where the pigtail goes into the dryer and see if one of the wires burnt
Jan 08, 2013 | Admiral Dryers
Admiral dryer model aed4475tq1 wont start
Take a look at this troubleshooting tip for the no heat problem and no start, for your dryer.
Oct 21, 2011 | Whirlpool LER5636P Electric Dryer
My admiral dryer is not drying as it should - troubleshooting advice?
I love an admiral dryer. Simply a beautiful machine. They do have a few basic problems but whos doesn't. One of the main problems has to do with the 53-0106 plastic blower. It has a flat side to it to keep the blower from slipping but the heat wallers out the hub abd the blower spins. This results in improper air flow. The dryer takes twice as long to dry clothes and gets real hot on top because of poor air circulation. Also a hole could get in the filter and cause lint to build in the filter housing. The lint combined with the loos blower wheel makes a huge ball of lint form in front of the blower. I have some repair photos for various maytag dryers old and new and diff styles showing how to get inside and check all this stuff out. Remove power and clean out the vent to outside also and this sweet little admiral will be all kosher again. Repair photos and stuff: HERE
I have other brands HERE
You say you have an admiral but ler5636p is a whirlpool dryer, anywho I have posted the repair pix for whirlpool HERE
Jan 18, 2010 | Whirlpool LER5636P Electric Dryer
Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Nov 29, 2009 | Dryers
My admiral dryer runs but has stopped drying the clothes to where I have to run the load five or six times and when I take out the clothes they are cool instead of warm. It does this with every drying...
either your heat cycling switch,hi-limit switch,thermistor or part of your element is defective or you don't have full 240 volts to operate your dryer i.e. only 1 leg of 120 volts it will run in some cases but will heat poorly
Oct 29, 2009 | Admiral AAV7000A
Admiral Dryer: 5 cycle 3 temperature electric
Unplug Dryer
Remove back (many screws)
Clean lint from interior & Vent Chute
check for breakage & parts on dryer floor
check for burn damage (wires burned off or char)
if no burn or char:
could be the "Dryer Coil" itself broke or
a "Snap Disc" usually mounted on the coil housing.
Very Serious!!!! Replace only!!!! Do not ever bypass!!!!
Stay clear of dryer for test start
Be ready to shut it down fast in case of problems
Always replace back & vent chute
Good luck,
Vinnie
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
303 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
