Question about Toshiba Satellite A15-S127 Notebook
How to clean or replace cooling fan? Upon power
How to clean or replace cooling fan? Upon power on, the fan makes loud noise ad stops
    Scholar:
  • 172 Answers
I think below link can give ou step to replace or clean fan
http://www.irisvista.com/tech/laptops/ToshibaA15/SatelliteA15_laptop_disassembly_1.htm
http://www.ehow.com/how_6339146_replace-toshiba-satellite-cooling-fan.html
Please rate & vote if you like the solutons..
Thanks
Sandeep
Posted on Mar 11, 2011
  • 104 Answers
This is actually normal for the cooling fans up to full power for a few seconds when the laptop starts. When any computer starts, it performs a Power-On Self Test (POST), most laptops test to see if the fans are functional by spinning them up to 100% power for a few seconds. If the fans don't spin up during bootup the laptop will mark them as failed and will notify you to change the fans.
Hope this helps
Please rate this solution, thanks!
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
New Cooling Fan is Very Loud
might be a fan with a faulty bearing lubricate it by pulling the sticker off and the cover then use some oil NOT WD40 if this doesnt work then get another fan
Dec 08, 2012 | Compaq Presario CQ56110US Laptop
I have dell 3300mp,when I turn the power on it makes a very loud noise. It does not make the sound in standby or cool down. It does work and display a signal okay, but it is very loud. Sound like a fan?,...
The main fan that cools the lamp is mostly high speed when the unit is running. when it shuts down it slows the fan down, until it stops in standby. So the noise is only really loud when it is showing a picture.
try setting the fan to eco mode (slower running) and see if the noise is acceptable. If it is still too loud then you will have to replace it. Have a look at the fan and see if any of the plastic blades are missing.
Mar 26, 2011 | Dell 3300MP Multimedia Projector
My computer fan making loud noise ,why?
fans tend to make loud noise right before they stop working!!! check to make sure that there is no clump of dust inside affecting the spin of the blades
Dec 16, 2010 | HP (219426-001) Cooling Fan
My computer started making a loud noise that will not stop. I am not sure if it is the fan or hard drive. The computer seems to be working fine. Any idea what could be making the noise?
In order to confirm the problem.. first of all turn off the pc and unplug the power cable from the back of the pc.... get a Philips head screw driver and open the chasis.... plug in the power cable and see where are you getting the noise from .... there are three fans namely one on the processor, the other a cooling fan and the last would be inside the power supply.. if its inside the power supply nothing can be done ... if its the cooling fan noise .... try to clean the vents or the cooling fan with the help of the dry cloth and if its the processor fan then its a serious issue ....
Apr 12, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My computer fan speeds up whenever I'm on the
Nothing ... probably ... your fan speeds up when the processor temp goes up ... the more you are doing, the more cooling you need. The processor is calling for more cooling so the fan runs faster.
If this is a concern for you, you may wish to consider adding another fan to your case. In any event, make sure your power supply fan is clean. Use a vacuum or canned air to clean.
Mar 14, 2010 | Dell OptiPlex GX270 PC Desktop
Kenmore upright vac model 33922 - good suction but developed loud whining noise after accidentally vacuuming room without bag. Added bag and changed both filters. Still makes noise. How can I stop noise?
The bag is the first stage in your filtration. Most times what you did will draw fine dust right through the filters and into the motor itself, affecting the bearings and clogging the motor fans, throwing them off balance.
The fact that there is a new noise would seem to indicate bearing problems which will only worsen unless the vac motor is dismantled, fans cleaned and bearings either replaced or cleaned and repacked.
Sep 14, 2009 | Kenmore 33922 Direct Drive Bagged Upright...
My fans are very loud do I need to replace them
check the plastic rings behind the fan blades, check to make sure plastic rings is tight and the screws holding fan cage on. Then when putting the fan cage back together, make sure it is tight so it wont vibrate
Jul 20, 2009 | HP (219462-001) Cooling Fan
Over heat cooling fan load noise remove and replace
A bearing more than likely has went bad causing your fan to stop properly cooling your unit. Replace with a compatible fan and you should be all set. Hope this helps.
Jun 03, 2009 | Sony Computers & Internet
Cooling fan
Yes. It can be replaced. Try to check which fan is making that sound. Do you have a laptop or a PC? On a PC, there are 3 standard fans inside it. one for the CPU, one for the power supply and one for the computer casing fan as well. It depends on which of those fans it's coming from. On a laptop, some laptops' fans actually makes a loud noise which is common but there is a way that it could be lessened but it might slow down your pc and it might overheat it as well. The loud noise on the fans of a laptop actually indicates that it's trying to cool down the system. If it doesn't stop the loud noise, it could indicate a problem switching the fans back to normal and would just continue to spin fast. Try to contact your PC tech for further diagnostics on the laptops fan to indicate if the problem is with the fan or the mainboard as well.
Jan 02, 2008 | Iomega 33089 250 GB Hard Drive
Toshiba Satellite A15-S127 Notebook Logo
539 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
