Hello
first i would check and see if the brake fluid is low if it is you should have a brake inspection probably needs front or rear brakes or both, if you fill the master cylider with fluid lighty tap on it sometimes the sensor gets stuck down and it thinks the fluid is low next i would check that the emergency brake is not applied pull the release handle and lift with your foot or if it is a hand brake make sure it is down,lastly make sure that there is no brake fluid leak they should notice that during a brake inspection
good luck
chris
