Question about Microsoft Xbox 360 Console
Solid red light no error code on tv just says no signal
    Problem Solver:
  • 13 Answers
The solution for this problem is to check all cables on the console to make sure they are all connected correctly both on television set and console, if problem persist try a different AV cable or an HDMI cable, if nothing works after trying these solutions try Microsoft's xbox support for help here
Posted on Mar 13, 2011
What is Mitsubishi DLP TV error code 44?
That is an Open(blown)
Check for open F9A06 on the Power PCB
Sep 15, 2015 | Mitsubishi Televison & Video
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Mitsubishi Televison & Video
I am trying to get the code numbers for Dynex tv
Unfortunately the user manual does not have a pre-programmed code for Dynex, so your best bet is going to be performing a code search.
To search:
1. Make sure the TV is on
2. Point the remote at the TV and hold down "CODE SEARCH" for at least 3 seconds, until the red light lights up solid
3. Press the "TV" button once and the light will blink once, then return solid red.
4. Press the On/Off button repeatedly until the TV turns off (go slowly enough that you don't keep pushing on/off after the TV turns off)
5. Once the TV turns off, press the ENTER button and the code will save (and the red light should go off)
This may take a while, so be patient, but if anything should get it working with your TV this will be your best bet.
Aug 25, 2011 | Innovage Jumbo Remote Control
I have a panasonic th-42pz800a and it wont turn on all that appears is a flashing red light instead of the solid green light next to the button on the tv... any helpers
Flashing red light is an error code, please count how many times red light is flashing after long pause and let me know to diagnose possible cause of problem..
Thanks.
Mar 18, 2011 | Panasonic Televison & Video
No picture no sound will turn on but not off, red light comes on
When the red light is lit press both the menu and device buttons in on the front of the set in together and hold for 5 seconds then record the two digit blink code that will repeat. I am assuming you will receive a 34 error or a 41Error. But let me know what blink code you get and I will assist you.
Jul 20, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I need the codes for the jumbo innovage control for an advent tv.
I don't see Advent TV codes in the Innovage Jumbo Remote manual.
Here are the Code Search instructions:
  1. Turn on your TV.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the TV button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the TV turns off. The LED will blink once each time you press ON/OFF.
  5. Once the TV turns off, press the ENTER button to store the code. the LED light will turn off.
Oct 11, 2009 | Innovage Jumbo Remote Control
My GE instajack is not working. It had a greeen signal, now it has a red signal.
Most likely, the extension unit cannot communicate with the
indicator light is solid base unit for one of the following reasons:
red • Base unit has yet to be installed. Install base unit. (Refer to
the Set Up section.)
• Extension is too far from the base unit. Relocate either the
base or extension unit to another electrical outlet. If
indicator light on extension
unit remains solid red, reprogram the link code on extension
unit
Follow these steps:
• Press and hold the button on the right side of the base
unit until the indicator light changes to solid red.
(Approximately five seconds.)
• Release the button, then the indicator light will blink orange.
This creates a new link code and places the base unit into
program mode.
• Follow steps (2) and (3) in the Additional Extension Units
section for all extension units.
• Press and release the button on the base unit to take it out of
program mode. The indicator light will change from flashing
orange to solid green.
Oct 10, 2008 | Computers & Internet
Toshiba tv
Is the red light flashing or solid?
If the red light is flashing it is the signal board is bad part number 75001688 $425.00 - $475.00 depending on supplier.
If the red light is solid then you signal cable has come loose or has went bad.
Sep 10, 2008 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
