Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Printing Where do I put an envelop for printing..I need to know inorder to print a single check. Thanks, Mary Alice
    Genius:
  • 1,142 Answers
Refer to this link the will help you to resolve your issue.
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&lang=en&product=2512008
Posted on Oct 14, 2008
I don't have word. I have a Mac and an Hp printer. I can print the address on paper but can't figure out how to get it on an envelope.
Verify printing options..try this.
  1. On the Mailings tab, in the Create group, click Envelopes.
  2. Click Options, and then click the Envelope Options tab.
  3. In the Envelope size box, click the choice that matches the size of your envelope. ...
  4. Click the Printing Options tab. ...
  5. Load the envelope as indicated in the dialog box.
  6. Click OK.
More items...
Create and print a single envelope - Word - Office Support
https://support.office.com/.../Create-and-print-a-single-envelope-b766aa84-5b97-4f63-b... https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=how%20to%20print%20envelopes%20on%20a%20printer
Dec 05, 2016 | HP Office Equipment & Supplies
When I try to print on a 6x6 envelope on my hp envy 110 printer it tells me it is the wrong size paper. No where is there a setting for a 6x6
Print labels and envelopes
With the HP ENVY 110 series, you can print on a single envelope, a group of envelopes, or label sheets
designed for inkjet printers.
To print a group of addresses on labels or envelopes
1. Print a test page on plain paper first.
2. Place the test page on top of the label sheet or envelope, and hold both up to the light. Check the spacing for
each block of text. Make adjustments as needed.
3. Load the labels or envelopes into the paper tray.
CAUTION: Do not use envelopes with clasps or windows. They can get stuck in the rollers and cause
paper jams.
4. Slide paper-width guides inward against the stack of labels or envelopes until the guides stop.
5. Select the appropriate options.
• On -Paper/Quality- tab select a Plain paper type.
• Click the [Advanced] button, and select the appropriate envelope size from the Paper Size drop down
menu.
6. Click [OK], and then click [Print] or [OK] in the Print dialog box.
If you print from within a program that DOES have that listed (like M$ Word,) then you don't need the limited printer driver to specify the paper size.
Tallon41
Sep 08, 2012 | HP ENVY 110 Wireless e-All-in-One Inkjet...
I don't know how to put an envelope in to print it out.
Please follow the steps below on how to print on an envelope:
  • The print side of the envelope is faceup.
  • The paper guides rest against the edges of the envelopes.
  • You print the envelopes with Landscape orientation. Note: If you are mailing within Japan, then the envelope can be printed in Portrait orientation with the stamp in the lower right corner or in Landscape orientation with the stamp in the lower left corner. If you are mailing internationally, then print in Landscape orientation with the stamp in the upper left corner.
  • You select the correct envelope size. Select the next biggest size if the exact envelope size is not listed, and set the left and right margins so your envelope is correctly positioned.
I hope this information has been helpful. Thanks.
Oct 22, 2011 | Lexmark Interpret S405 Wireless All-in-One...
How do you print envelopes on the Canon Pixma iP4600. What feeder do you put the envelope in? I need to print on square envelope 155mm x155mm and don't want the envelope to get creased.
I print envelopes a lot for my business.
What I do is I use the regular paper feed, and I open the flap on the envelope so that it's flatter. Simply slide the paper guide to adjust to the size of the envelope.
Also, typically the orientation for printing envelopes is sideways. You put the left edge of the envelope in the printer first. If you are unsure of the orientation, simply do your first print on plain paper. Then you'll know how to insert the envelope.
Oct 09, 2009 | Canon PIXMA MX310 All-In-One Printer
I need to know how to print an envelope on and HP color laserjet 4700dn
Select envelope, after you hit print. Run one first on a sheet of regular paper, to see the orientation. Then, just put them in, the way you have it set up for.
Sep 03, 2009 | HP LaserJet color laser printer
How to print an envelop
nstructions Use the following steps to ensure that you are ready to print envelopes. Your printer can have either a single envelope or multiple envelopes loaded and ready for printing.
  • If you are printing a single envelope, you can use the single envelope slot and leave your paper in the lower (IN) tray. This allows you to print the envelope and then a letter.
  • If you are printing a stack of envelopes, use the lower (IN) tray for loading the stack of envelopes.
To Load a Single Envelope
  1. Do not remove the paper from the lower (IN) tray. Be sure the card guide is in the down position, before using the single envelope slot.
  2. Remove a single envelope from its packaging.
  3. Slide the envelope evenly into the single envelope slot. The single envelope slot is located on the right side of the upper (OUT) tray. The envelope should be loaded with the address side down (flap side up).
  4. Make sure the creased flap edge of the envelope aligns with the right side of the single envelope slot.
  5. Slide the envelope through the slot until it stops. Make sure the envelope is not bent and is straight in the envelope slot.
    NOTE: To minimize print skew, use envelopes with rectangular flaps rather than triangular flaps.
To Load Multiple Envelopes
  1. Slide the paper width adjuster to its leftmost position.
  2. Pull out the paper length adjuster and remove any paper from the IN tray.
  3. Remove up to 20 envelopes from their packing and tap the short edge of the envelopes on a flat surface to even the stack.
  4. Slide the envelopes evenly into the IN tray, address side down (flap side up).
  5. Slide the paper width adjuster to the right until it gently touches the left edge of the envelope stack.
  6. For size Invitation A2 and C6 Envelopes, press the inside of the paper length adjuster handle to release and lower it.
  7. For all sizes of envelopes, push the paper length adjuster in toward the envelopes until it stops. Make sure the envelopes are flat in the lower tray and not bent.
Set up the Printer Properties
  1. Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  2. Select the Paper or Setup tab depending on the version of the printer driver software.
  3. In the Paper Options section, select the desired envelope size from the Paper Size drop-down box.
  4. Click OK.
Print Print the envelope from your chosen program. From most applications, just select the File menu, then choose Print. After Printing the Envelopes Reset the printer and the printer properties for the kind of printing you will be doing next.
  1. Remove any remaining envelopes from the lower (IN) tray.
  2. Slide the paper width adjuster to its leftmost position.
  3. Load the desired paper into the lower (IN) tray.
  4. On the computer, Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  5. Select the Paper or Setup tab depending on the version of the printer driver software.
  6. In the Paper Options section, select the desired paper size from the Paper Size drop-down box.
  7. Click OK.
Jan 19, 2009 | HP LaserJet 1600 Printer
Can i print envelopes addresses on brother HL 2140 laser printers
The manual by-pass slot just below the brother name on the front allows a user to load envelopes just put the envelope in the slot and adjust the size.by closing the two grey tabs
Nov 25, 2008 | Brother HL 2140 Laser Printer
HHow do I print envelopes on a deskjet940c. What is the set up.
Here is a how-to for the printer, but I'm not sure if you mean the printer, or in a program.
If this is not what you need, let me know.
HP Deskjet 920c and 940c Series Printers - Printing Envelopes s.gif s.gif s.gif
gtabblt.gif Loading a single envelope gtabblt.gif Loading multiple envelopes gtabseps.gif Loading a single envelope Preparing to print
  1. Place the envelope, with the flap side on the left and facing up, into the single envelope slot.
  2. Push the envelope forward until it stops. See Figure 1.
Figure 1: Inserting the envelope c00104463.jpg Printing guidelines
  • Verify that the Out tray is in the down position.
  • Avoid using envelopes that have clasps or windows.
  • Avoid using envelopes that are shiny or embossed, envelopes with thick, irregular, or curled edges, or envelopes that are wrinkled, torn, or otherwise damaged.
Loading multiple envelopes Preparing to print
  1. Pull out the In tray.
  2. Slide out both paper guides and remove all paper from the tray.
  3. Place no more than 15 envelopes -- with the flap side on the left and facing up -- in the tray.
  4. Push the envelopes forward until they stop.
  5. Slide the paper guides snugly against the edges of the envelopes, then push the tray forward until it stops. See Figure 2.
Figure 2: Inserting multiple envelopes c00104464.jpg Printing the envelopes Each software program is different and requires different steps to successfully print envelopes. For instance, in many versions of MS Word, clicking Tools , and then Envelopes and Labels , accesses the envelope-printing feature. Other software programs will differ from this procedure. Consult the Help menu on a software program or User's Guide for instructions for the particular application. Printing guidelines
  • Never place more than 15 envelopes in the In tray at one time.
  • Align the envelope edges before inserting them.
May 27, 2008 | HP Office Equipment & Supplies
Trouble printing envelopes
Instead of Word 2000 use Corel Draw for printing invelope. Because there are too many options for placing your text at desired position.
Feb 06, 2007 | Canon imageRUNNER 4570 Copier
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
27 people viewed this question
Ben Johnson
