Question about Broderbund Print Shop® 21 Pro Publisher Deluxe Full Version for PC
I want to change the size of the paper from 81/2 x 11 to 11 x 14. I am unable to locate any tools that will let me do that. I am trying to create a 4 section brochure and want to use larger paper.
    President:
  • 2,340 Answers
To make changes in the paper sizes , you have go to the "Printer Properties" to do that.
Go to "Printers & Faxes" -> Select the printer you are using, right-click and click properties to open the printer properties dialog box to make your paper sizes click OK.
Hope it helps.
Posted on Mar 13, 2011
I have created a custom paper size 14' * 4' but i am unable to select the same paper size to set the page setup.
The maximum paper width the 6306 can print on is 13.6 inches, you will not be able to select a custom size form larger than the printer is capable of handling.Simply set the for size to 13.6 inches or the maximum width you will be printing.
Aug 11, 2011 | TallyGenicom 6306 Matrix Printer
Tip
Create a Restore Point
We never know how or when our Windows OS corrupt or unexpectedly unable to continue. Try practice using system restore located in your Windows Start > All Programs > Accessories > System Tools > System Restore then Create a Restore Point. The importance of this is that you can undo harmful changes. Example youve created Restore point today then on the next day, you're PC is infected with a harmful virus, with this you will be able to restore the settings to the one youve create a restore point.
on Dec 07, 2009 | Computers & Internet
Please teach me how to use my HPF4185 to print envelopes. Thanks.
Hi
Use the product software, also known as the printer driver, to change the print settings for your envelope size and type. Then, use the Envelopes and Labels tool in Microsoft Word to select your envelope size.
Step one: Adjust the print settings
-In Microsoft Word, click File , and then click Print .
-Make sure that your product is in the Name drop-down list box, and then click Properties .
-Click the Features tab, or the Paper/Quality tab.
-Select an envelope size from the Size drop-down list.
-If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
-Select Custom from the drop-down list.
-In the Custom Paper Size dialog box, type a name for the new custom size.
-In the Width and Height boxes, type the dimensions.
-Select the unit of measurement, and then click Save .
-Click OK to close the Custom Paper Size dialog box, and then click OK again to close the Properties dialog box.
NOTE: You must exit the Properties dialog box to apply your changes.
Open the Properties dialog box again, and select the new custom size from the Size drop-down list.
-Select the paper type.
-In the Paper Type or Type is drop down list, click More .
-Click the desired paper type, and then click OK .
-Select the paper source from the Paper Source drop-down list.
-Change any other settings, and then click OK to close the Properties dialog box.
Step two: Set the correct envelope size
-Set the correct envelope size in the Envelopes and Labels dialog box before printing envelopes.
-In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
-In the Envelopes and Labels dialog box, click the Envelopes tab.
-Click Options .
-From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
-Click OK , and then click Close to close the Envelopes and Labels dialog box.
-Click File , and then click Print to print the envelope.
NOTE: When you finish printing the envelopes, return the paper size and the paper type settings to the defaults.
Regards
Riztech
Oct 30, 2010 | HP Deskjet F4140 All-In-One InkJet Printer
Custem size paper are not creat
am using an Epson LX-300+II dot matrix printer in Windows XP. I am
trying to print checks that are tractor feed 8.0" x 3.66". I added the cusotm
paper size in the print server and it is saved correctly, however, when I try
to print, the print properties dialog does not show the paper size. In fact,
there are many paper sizes in the print manager that do not show up in the
list of available paper sizes.
Apr 13, 2010 | Epson LX-300+ II Matrix Printer
WHen printing from MS Word academic version, the canon MX310 will print 1 page across multiple pieces of paper, at random. The drivers have been reinstalled. Any ideas?
Many programs allow you to change the size of the page for the document you are creating. If the size of the page defined in the program is different than the size of the page set in the printer driver, the document may print too small or over multiple pages.
In the application you wish to print from, check for a 'Page Setup' option in the 'File' menu. Make sure that the defined page size in 'Page Setup' matches the printer's settings. If you are unable to locate 'Page Setup', consult the application's 'Help' files or manual.
Jan 09, 2010 | Canon PIXMA MX310 All-In-One Printer
How can i add paper size of tally printing in lx-300
if you want change page setting in your printer ..... to get the all settings of your printer press font button and switch on the printer (before take setting make sure that you printer loaded with paper ) goes through the instruction printed in the paper to change the settings ........ change paper size.....
you can map your tally printer paper size in system .....go to printer and faxes ... file..>server properties ...>select create a new from ...> change the name as you wise and change the paper setting and click ok ........
while you give print change paper size to your created paper size and check
Dec 19, 2009 | Epson LX-300+ II Matrix Printer
Sir, I, have developed my application on windows 98 but now a days everywhere set the WindowsXp but my printer Epson LQ-2090 have not a Custom paper setting. Please tell me how I can solve this problem for...
have you created same paper size as per windows 98 custom paper size ..... if not create as same please create the same and select the printing area also in the server properties ...... in the printing preference change page size to your created page size in layout tab advance option and in paper/quality tab advance option ... and check it ....
Nov 20, 2009 | Epson LQ-2090 Matrix Printer
Ricoh Aficio 1075 - Change paper size on TRAY 1
you need to set the dial on the back of the paper tray
May 21, 2009 | Ricoh Aficio 1013F Copier
Printing on 4x8 cards
There are two different ways to create a custom page size within the Epson printer driver on Windows 2000 or XP. The method you need to use will vary depending on what type of driver is installed.
CREATING A CUSTOM PAPER SIZE IN SERVER PROPERTIES
This method will create a new page size accessible by all printer drivers installed in Windows.
1. Open the PRINTERS (2000) or PRINTERS and FAXES (XP) window.
2. Click on FILE, then select SERVER PROPERTIES.
3. On the FORMS tab, place a check beside CREATE A NEW FORM.
4. Input a new name for the paper size. Enter the desired height and width, following the existing format (#.##in).
5. Click SAVE or SAVE FORM to add the new form size to the list, then close SERVER PROPERTIES.
6. Right click on the printer name and left click PRINTING PREFERENCES.
7. Look for PAPER SIZE. (Depending on the driver in use, this will be found on the MAIN tab, the PAPER tab, or under the ADVANCED button). Select your custom paper size from the list.
8. Click APPLY to save this setting, or OK in Windows XP.
NOTE: If your new custom size is not available on the list of preset paper sizes, it indicates that the new size is either too large or too small for the driver in use.
CREATING A CUSTOM PAPER SIZE WITHIN THE EPSON DRIVER
This method will create a custom size within the Epson printer driver only.
1. Open the PRINTERS (2000) or PRINTERS AND FAXES (XP) window.
2. Right click your Epson printer name and left click PRINTING PREFERENCES.
3. On the MAIN or PAPER tab, select USER DEFINED from the PAPER SIZE drop down box.
4. Enter the new custom size and give it a name. Click SAVE to save the new size and OK to return to MAIN.
5. Click APPLY to save the changes (OK in Windows XP).
Oct 12, 2007 | Epson Stylus RX580 InkJet Photo Printer
Paper size
When you go to print go in properties go to paper size the go to user defined and put the size you want the paper to be.
Aug 16, 2007 | HP PSC 1315 All-in-One Printer
Broderbund Print Shop® 21 Pro Publisher Deluxe Full Version for PC Logo
228 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
