HI I have apair of wharefdale vr400 speakers and they are not ported the problem is its like the speakers need to breath to release there full bass capacity would you recomend porting them an if so should it be front or rear thanks I can be contacted at aitkenmartin23@yahoo.co.uk
    Brigadier General:
  • 8,546 Answers
If you think you're smarter than the engineeers, go for it. [sarcasm]
Seriously, don't do it. Find your missing bass some other way.
Posted on Mar 12, 2011
I want to replace the speakers for my FW320C What do I need to buy?
System - double port bass reflex
Impedance - 3
Woofer -1 x 4" full range (1) Dimensions (w x h x d) - 210 x 310 x 188 (mm) (1)
Weight - 2.3 kg ea
Aug 02, 2016 | Philips 3-Disc Changer FW320C Cassette/CD...
What type of amp do I need for apair of rfdj1 12" dj 600w band speakers?
The 600 watt rating is FAKE like most of our advertising and will be either 600 watts PEAK or 600 watts PROGRAM. If it is Peak, use an amplifier with no more than 100 watts a side RMS... If it is program rating use an amp with no more than 150 watts a side RMS but that is pushing it for speaker safety. Also pay attention to the spec of the amp as to what it will output at the impedance of the speakers. I read the spec on the speakers... they are rated 150 watts RMS, NOT 600 watts... Use an amp rated at 150 watts RMS MAXIMUM at 4 ohms per side. Also don't turn up the bass excessively or you be buying new speakers. Twelve inch speakers would be adequate for a 20 by 20 room at SAFE listening levels. If you want driving bass, you need to get an 18 inch subwoofer.
Jul 14, 2011 | Rockford Fosgate Rfdj1 12" 2-way Passive...
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
How do i connect speakers
How do I connect speakers to m-vr400
Jun 27, 2010 | Mitsubishi M-VR400 Receiver
I have a crackling speaker on the left port of the bass box
The crackling sound on the left port of the bass box, indicates vibrating foreign matters inside it. Just open the box and clear it up. Put the sounds on. Listen if the crackling sound is audible. If the result is ok, then, close the box, and everything is alright..
However, if the result is otherwise, then, it is due to a defective speaker that needs to be replaced.
Nov 21, 2009 | Creative Labs Sound Blaster Live! 5.1...
Alesis M1 MKII bass ports
if desiring loud bass, keep port open. It is designed to be that way. If subs are in a corner, face the wall to change the wavelength and port noise wont be as evident.
Dec 23, 2008 | Alesis M1-Active MkII Main / Stereo...
Lab l4 bass amp smoked my speakers
If your description is to be taken literally, and smoke did indeed come out of the speakers, your output transistors have shorted out, and put the full power supply voltage and current through your speakers.
The amp and the speakers will need to be serviced. The speakers will need new voice coils at the least.
Sep 30, 2008 | Audio Players & Recorders
Ozaki DV808 speakers problem?
i think there s some problem inside the circuit of ur spekaer,,,u gotta take that to a repairer as soon as possible...he might tune up the circuit board
Jul 02, 2008 | Audio Players & Recorders
Rear Speaker Vibrations
just right off hand does your rear speakers have a port so that air traped can be released if you port your box sound would get better
air inside of a speaker box has no where to go so it bounces off the speaker makin it vibrate out perfect harmony
also some stations and cd's can have a bad tune too them or signal which can give distortion greatly not appreciated sound
but i would go with the port suggestion first
when i built my first speaker box from scratch i found out the smaller the box the more air would dammage the speakers so i ported the boxes sound increased so much better
bigger the box better the air flow and bass
May 08, 2008 | Car Audio & Video
Subwoofer control
No there are no adjustments to that model as far as I know thats why they call them sub woofers my nephews would break their hearts getting at one of those and they would have the bass full bore...hahaha!
Aug 28, 2007 | Logitech Z-2300 Computer Speakers
44 people viewed this question
 Grubhead
Grubhead
