Question about Riccar 8650/8625 s Vacuum
I have a Riccar vaccum model 8625...I am having trouble switching from floor to carpet. The lever will not switch. Any suggestions?
  • 25 Answers
SOURCE: riccar rc1100 won't turn off
I am an riccar dealer, and you either have a short in the wire leads from front of vacuum to circuit board or a bad circuit board which if so the boardd will have to be sent to manufacture to be rebuilt as there are no new circuit boards available. if not under warrenty which i doubt since riccar hasnt made these models for a while. would recomend replacement with either sunburst or moonlight model as they are a comparable replacement to the repair. or just simply just plug and unplug machine, if it doesnt bother you to do so. If more questions email me at drago640@yahoo.com subject riccar, or go to www.riccar.com to locate nearest dealer
Posted on Mar 26, 2008
chrispurs1
  • 372 Answers
SOURCE: Dyson DC07 Vaccum - brush will not turn
Hi.
Your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive & try the machine.
If you still have no brush rotation after doing all this then UNPLUG machine from mains supply.
Now lay machine on its side & remove the sole plate, This is the cover over the brush roller.
Turn the 3 plastic screws to unlock postition & lift sole plate off.
Now try to yurn brush roller using your hand. It should turn freely if it is difficult to turn look for any foriegn object obstructing the roller.
If no obstruction found then remove the brush roller from the machine & check the bearings in the ends of the brush roller one or both may be siezed up if they are then new brush roller will solve the problem.
If bearings are good then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
It is difficult to fully explain the clutch removing procedure,
But there are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/
Posted on Jul 05, 2008
Vac Belts
  • 701 Answers
SOURCE: Older Dyson 07 Animal, loud ratcheting noise on carpet setting
That is an indication that the belts are worn, stretched or broken. You simply need to replace the belt. Here is a link to the belt(s) you need and a manual you can view:
Dyson DC07 Belts and Manual
Posted on Dec 05, 2009
Kuwagata
  • 181 Answers
SOURCE: Carpet/Floor Switch problem on Hoover WindTunnel Vacuum
Well, you have to deal with it, you have to play with this electrical things if you want to fix this problems.
The good news is, the sources of the problems is the switch already broken.The first things before you do anything is, find this switch on the market first to changes the old ones.Then, remove the power cord from the outlet of course.
After have it, then you must open the old switch, and remove it from the unit by cutting the cables using cutter/ pliers or anything.But remember, you must remember the locations of each cable that been cut, you can use Camera Cellphone to make sure of it if you like.
Then put the cables back together with the new switch, after all done, clean all the mess and try operate it.
Hope it works!!!
Posted on Dec 09, 2009
Testimonial: "I got into the switch area and found that it has a clip at the end. I reset the switch and it's working better. I'm sure I need to replace soon. Thx!"
Vac Belts
  • 701 Answers
SOURCE: no suction on carpets
The reason it doesn't pick up on the carpets is because the belt is stretched or worn and can't turn the roller brush against the resistance of the carpet. Here is a link to the replacement belts you need:
Riccar Upright Vacuum Belts
Posted on Dec 30, 2009
Riccar vacuum 8625 vacuums the floors;but does not seem to have suction for the carpets
The belt may look fine but could have lost elasticity. Stretch belts will lose elasticity and should be replaced at least once or twice per year. If the brush strips are worn or frayed it will not pick up properly.
Mar 01, 2015 | Riccar Vacuums
Why is my carpeting getting fuzzy tips?
You might be vacuuming too much or you may have the wrong brush strips for your style of carpeting. I recommend you take a sample of your carpet to your Riccar dealer and ask them if you have the correct vacuum and brush strips for your type of carpet.
Aug 02, 2014 | Riccar 12 8000 Simplicity 7000 Type B...
The switch will not turn the vaccum off or on
The switch is activated by the lever you push in the handle. Start by tightening the screw holding the handle in. If that doesn't solve it remove the bag door and the screws holding the cover above the bag to gain access to the switch compartment. If you can't figure it out in there take it to your Riccar dealer
Feb 17, 2014 | Riccar 8955 Upright Vacuum
Riccar 8625 doesn't seem to beat carpet but the brush is turning
Your 8625 is well over 20 years old. If it's been over a year since you've replaced the belt start with a new belt. Belts lose elasticity and should be replaced at least once or twice per year. The brush roll will still spin and appear to be working fine but when you put the brush roll onto the carpet it will stop spinning fast enough to clean the carpets.
Jan 25, 2014 | Riccar 8650/8625 s Vacuum
Troubleshooting
There is a clutch on one side of the carpet head of the vac, which needs to be moved to one direction or the other. Your instruction manual should be able to tell you which way is which. This lever in turn activates a cam to tighten a clutch plate to the end of the brush roll. Try that and get back to me.
Nov 11, 2013 | Riccar 8650/8625 s Vacuum
Faulty switch
Your 8650 is an old vacuum. The switch is in the part of the vacuum where the handle goes down into. When you push the lever on the handle it activates the switch. To get to the switch take off the dust cover, remove the three Screws on the small cover where the handle goes in to see the switch. On older Riccar vacuums like yours sometimes the screw holding the handle in is loose which can cause the switch to not Always engage properly. To test this turn the vacuum on and wiggle the handle. If the vacuum vacuum cuts out you may only need to tighten the handle screw.
Jan 31, 2013 | Riccar 8650/8625 s Vacuum
NEED ASSISTANCE ON INSTALLING BELT FOR MODEL 8625
HI There,
Here's a link that will walk you through step by step on how to replace the belt on your Riccar 8625 upright. This is an almost identical model, and the belt change is identical to yours.
If you have any questions please feel free to add a comment on the repair, and I"ll be happy to follow up and answer any of your questions.
Please rate my repair or send me feedback if this helped you,
http://www.fixya.com/support/t4184186-replace_belt_riccar
Thanks,
Apr 20, 2010 | Riccar 8650/8625 s Vacuum
When I move my bottom lever from Floor to Carpet
I cannot express enough you need to clean your dyson as great as it is its still a vaccum. look underneath at roller, clean out tube wash filter and check to see if vaccum ate something which is stuck inside. I have had mine for 4years and still picks up after 2goldens and kids.
Oct 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Riccar 8750
I have an 8625 and the button is now white not red. Probably fadded. Thanks that was the reset button and it solved my problem.
Oct 23, 2007 | Riccar 8650/8625 s Vacuum
Vacuums Logo
56 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
Jim Parker
Jim Parker
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
