Question about Garden
Hello & thank you... I was given a used Wagner Power Stainter 1400psi w/o instructions. I have the unit, the tube & the tube for attachment between the unit and draw tube. I did a pre-chech by placing the draw tube into water to insure operation... it didn't operate. No suction, no draw. the unit seems clean w/o any obstruction. Turning the knob at the handle also produces nothing. Please, your feedback on this? thanks again. jack
  • 95 Answers
Try manualsonline.com they might have a user manual there.You can download it free.
Posted on Mar 11, 2011
Remove and Install prime/spray valve Wagner paint crew airless paint sprayer?
Was the unit purchased new or used? The price of a new is about $125-170. This unit is for homeowner occasional use, not for large jobs.Was the unit working on the previous use? If so were the cleaning instructions followed and not shortcut. If paint is failed to be totally removed on cleanup it will dry inside unit.There are very few replacement parts for this unit. If the unit is not working take wrench and try to remove prime/spray valve. You will have to remove knob to access this part.
Apr 18, 2017 | Wagner Air Tools & Compressors
Need instruction manual for a "Wagner 200" sprayer
Owner's Manual - Wagner
www.wagnerspraytech.com/fileadmin/user_upload/wagner.../0525800_eng.pdf
wagner power painter 200 series manual - download - Google Docs
https://docs.google.com/document/d/.../edi
Oct 20, 2016 | Air Tools & Compressors
What cain of oil a cant uuse for wagner 1250 hp
Your Wagner 1250 is a diaphragm airless sprayer, which uses hydraulic oil to push the diaphragm, so the oil must be hydraulic quality as it gets quite hot; don't use any other type. The Wagner part number for their quart size is 0088009
Jun 15, 2015 | Wagner SprayTech Wagner Airless Paint...
Will not suck the paint just air is coming out
Hello I just saw this in my inbox, let me see if I can help you-
NOTE: Whenever you are going to spray with any HVLP or cup-gun
strain paint through either a strainer bag or an Automotive strainer cone to remove any kind of debris from the paint that can clog the delivery tube that sucks the paint up from the "cup" and into the fluid needle.
yes even though "Wagner" says the Flexio will spray un-thinned Latex-
However by thinning your paint 10% to 15% you will get better coverage and the paint will move through the gun better
If you have no paint coming out try adjusting the fluid material knob on top-
Also try holding a piece of card in front of the the Tip and try all your Adjustments and you should start seeing the paint spraying onto the piece of cardboard or wall.
Thanks,
Perry Tradesman @ Tradesman Painting & Decorating
Feb 15, 2015 | Wagner SprayTech Paint Sprayer. Flexio 590...
How can I fix a electrical spray gun that does not spray but makes noise like its going to spray.
R D, I think the spray nozzle is blocked with previous paint job. I would try soaking it in paint solvent for a few hours to see if it helps. Use the cleaning brush to clean as much as you can all the channels where you see paint. good luck.
May 20, 2014 | Wagner Spray Tech Model 242 Electric...
I bought new wagner model HT3500 a few years ago never used until now pulled it out of the box it does not stay running. is there a call back on them?
I was given a dead HT3500. Holding the power switch down made unit lights rapidly blink and motor start/stop.
However, before starting repair refer to the HT3500 recall notice.
http://www.cpsc.gov/en/Recalls/2009/Wagner-Spray-Tech-Recalls-Heat-Guns-Due-to-Fire-and-Burn-Hazards/
Assuming your gun isn't in recall, the repair involves dis assembly and replacing the 470uF 10V electrolytic capacitor on board (it is a tall cylindercal plastic covered part.) Replaced it with a 470uF 16V rated at 105*C. If you are handy with a pencil solder iron and solder removal tools, it is a 5 minute repair. Any electronics technician or ham radio buff can do this job.
Jan 31, 2013 | Wagner 0503040 MODEL HT3500 Digital Heat...
Connection for continuous discharge
There unit should have come with a small plastic tube. One end should have a thread connecion for hose hook-up. There should be an opening on the back of the unit that you push the tube through to connect with a little elbow tube inside the unit. You should be able to see the elbow connector from the front of the unit by removing the water bucket. Just push the plastic tube in from the back until it fits snuggly over or into the elbow tube and replace the water bucket. Run the connected hose to your sump pump.
Jul 16, 2008 | Dehumidifiers
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
