Question about Microwave Ovens
We bought a used gas-range / electric oven in great condition. I've just learned that it should have an anti-tip device, but it wasn't sold with the stove (since it was used). Where can I get one for our stove? It's a 7 year old Frigidaire, model CFDS389JGB2.
mikedem7
  • 25 Answers
SOURCE: Removing an old old microwave oven
look in the cabinet above the microwave, there should be 2 bolts which go through the bottom of the cabinet and screw into the microwave. remove these 2 bolts holding the unit steady then tilt the unit down and away from the wall.
Posted on Aug 19, 2008
  • 212 Answers
SOURCE: 11 yr old range/oven ; oven stopped working (clock
your clock controls the oven functions. replace clock. probally a little cheaper than a new range but depends on service call fees and labor
Posted on Jun 22, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Range RF315PXDW
It sounds like you are missing part of your input voltage.
I would take a voltage reading at the receptacle and confirm you are reading 220-240VAC. Some homes have the 220 service receptacles wired up with two 120 volt breakers to make up your 220 service. If your home is configured this way, you may have one of the breakers tripped. Or, the receptacle itself may be bad. If you confirm you have the correct voltage at the receptacle, your power cord may be bad.
The reason the clock and display will still appear to work is because the clock only uses 110-120VAC and is tapped off the source voltage. The surface burners and the oven heating elements, however, require the full 220 service.
If you are confused by this explanation, please post back and let me know. Hopefully, this is a problem that will not require any parts or a service call. If the power cord is bad, you can purchase a replacement at any hardware store. I hope this information is helpful.
Posted on Dec 19, 2009
Testimonial: "I will definitely check both the 120v wires in receptacle feeding power to the stove. The breaker in the house breaker box is a single 60amp breaker. "
SOURCE: frigidaire microwave model # plmv168,will heat
Mine just stopped heating things up this morning and I need to reheat my coffee!!! HELP!!! Did you guys find a solution? Want to see if it is easy enough for my hubby to do before I call a repair person in!
Posted on Mar 25, 2010
tbreeze47
  • 3083 Answers
SOURCE: Error code F-14 when using
Read the following blog, it describes Frigidaire's F14 error code:
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/47659-frigidaire-stove-displaying-f14-error.html
Although your model differs from the one in this blog, the error code will be the same as far as symptoms go, and should clue you in as to what to check, clean, etc.
Also, here is a pdf that describes this fault, also:
manuals.frigidaire.com/prodinfo_pdf/Springfield/316904402.pdf
Good luck, thanks for using FixYa, and hope this helps.
Posted on Aug 30, 2010
Gas rings will not light because of no electric spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 20, 2011 | Baumatic Microwave Ovens
Do you know what the average electric cooktop lifespan is? We have a Kenmore that is 9 years old and working fine. However, we are in the midst of a renovation and are wondering if it wouldn't be wise to...
The life span of the range depends on it's use or abuse.... Common issues are burners and the connections that the burner plugs into. These are not hard to change out.... There is nothing that can make the stove useless, if you keep after it. Newer units do a better job of retaining the heat within the unit, oven wise....Which is nice.
A gas range is certainly nicer, so they say. It is faster, but has one odd issue: if you boil water over, you can put out the flame and have raw gas running in. Most work this way, expensive units have thermal sensors that would turn off the gas flow in flame out condition....
My wife loves her gas range....
Mar 08, 2011 | Microwave Ovens
The electric starter on one burner sparks once every ten seconds or so. All burners are turned off.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Jan 10, 2011 | Microwave Ovens
The electric sparker won't switch off, unless I turn the electricity off at the mains
heatman101
Nov 20, 2010 | Microwave Ovens
Hi, MY name is Ben I have problem with my Kenmore (GE) gas range. the oven does not start up...I've replaced the igniter, but no luck. I measured the voltage across the the two wires at the inigter and...
A burner works only intermittently If one of your burner heating elements works only intermittently, it's probably because of worn or bad contacts in the receptacle that the element plugs into. On most electric ranges, you can remove the element by lifting it up several inches and firmly pulling it away from its attachment (receptacle). Read your owner's manual to learn the correct technique for your range. If, after removing the element, you see that the ends of the element that were plugged in are pitted, corroded, burned, scarred, or rusted, replace both the element and the receptacle.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 09, 2009 | Microwave Ovens
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
