Question about Dynex Televison & Video
I have just brought a new dynex dx-32l152a11 32" tv and i want to use a wall mount but i dont know what size the bolts/screws are for the four threaded holes on the back of the tv
4 Suggested Answers
SOURCE: TV wall mount screws for Dynex 32" TV, which size?
Orchard supply.....Metric Cap Screw size:
M6-1.0 x 12MM
They come 2 to a package for about $1.39
Posted on Jan 30, 2011
BElectric
  • 1140 Answers
SOURCE: I just bought a new
Hello Debbie,
This is due to incorrect connections between the dish box and the TV. You may find that if you select another input (AV1) on the TV, you will have sound from the dish system, but no picture.
I suspect you are using an RCA type AV cable with red, white and yellow jacks on both ends. You've most likely connected the yellow jack to a socket labelled Y, Pb or Pr on the back of the TV and then selected the COMPONENT input on the TV.
If you are using a cable with red, white and yellow jacks, please make sure they are connected to the sockets on the back of the TV shown below. I've ringed the socket for the white jack in green for better visibility.
Once you've done this, select the AV1 input on the TV by pressing the INPUT button on the dynex remote, then use the arrow keys to highlight AV1 and press ENTER to select.
If this does not solve your problem, please let me know which type of cable you are using and the model number of your dish box. If you don't know the technical term for the type of cable you are using, please describe it as best you can, i.e. how many plugs/jacks are on each end of the cable and whether they are color-coded.
Hope this helps. If you need further assistance, please reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Posted on Apr 16, 2011
jyackle5
  • 8197 Answers
SOURCE: I need codes to control
May I get the model # of the samsung remote to help you more
Posted on Jun 06, 2011
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
Need wall mounting screws
It would be best to call a TV installation company to do this for you.
Aug 02, 2014 | Dynex DX-L32-10A 32" LCD HDTV
I own a Samsung DLP 56" TV for which I purchased a swivel wall mounting bracket that holds up to 160 Lbs of weight. However when looking at the back of the tv set and the such smal size screws that...
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
Jun 30, 2011 | Samsung HL-T5676S Television
I have a wall mount installed already but dont know how to attach the TV - model LA32R71B to it, should I have some bolts or nuts as there are 4 bolt holes in the back of the TV but I dont know the thread...
The wall mounting kit should come with all kind of screws to attach the mounting barckets to the back of the TV. Most TV uses metric M5 or M6 screws for the mounting holes on the back of TV, you should be able to get them at HD or LOWE for about 35 cents each.
My kits come with a bunch of Metric screws. Do you have the instruction sheet of the mounting kit?
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 08, 2010 | Samsung Televison & Video
How to mount on wall
first you neeed to buy a wall mount kit for your size tv, menards or lowes is cheaper than best buy. you can also purchase a box for behind the tv that has a cable and power supply, it mounts in the wall so you see any wires. you must take the tv base off, normally 4 screws and make sure you have studs where you would like to mount the tv
Aug 06, 2010 | Dynex DX-LCD37 TV
VESA Screws
I went to Lowes and found some 4mm .7 screws, 25mm long, and they worked like a champ. (get the lock washers too)
Apparently, most mounts include only 5mm and larger screws
Mar 29, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
What size bolts hold the wall mount bracket to the tv
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
Aug 23, 2009 | Televison & Video
M6-1.0 x 12MM
Jul 06, 2009 | CTL Nexus NX3200 Television
Where/what do I buy to mount my tv on the wall?
You can buy almost any wall mount for it, just be sure of 2 or 3 things... 1st the location, you have to screw some rather large bolts into the wooden studs in the wall so check where it will be located... 2nd weight and size... You want a mount that will be able to hold up the weigh of the TV, usually the size will be between 32" to 40" (various mount sizes) Just make sure the size 37" is between the size lengths... and 3rd that it has a "tilt" adjustment... due to the placement of the TV you might get either reflection off of a light source or you may need to change the angle so that you can see it better on the wall... Hope this helps out and if in doubt be sure to ask someone at the store you buy your equipment (TV, Audio, Games, etc)...
Mar 27, 2009 | Dynex DX-LCD37 TV
Televison & Video Logo
229 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
