Question about Curtis DVD1041 Player
How do you hook up the DVD player when you have AT&T cable running to the TV? There doesn't seem to be a schematic on where what goes to what? If you have it on print, can you please send to me email? If not, can you please explain how I can do this? Sorry...but I'm not to savvy with this sort of thing...so please explain in detail. Thank you so much!! :)
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 100 Answers
Without having the model# of the TV or what connections are available I cannot go into details, BUT
A DVD player will need both Video and Audio connections connected to your TV. Depending on what connections are available on the back of your TV you have a few options
  • Composite Video (Yellow RCA connector)
  • SVideo (round 4 pin connector)
  • Component Video (Red/Blue/Green 3 RCA Connectors)
  • HDMI (flat rectangular digital connector)
Take a look on the back of your TV and see what types of these are available (or provide me your Model#)
HDMI will give you these highest quality signal....Composite Video the lowest
With all of the connections mentioned (except HDMI, HDMI has audio signal built in) you will ALSO need to connect the audio connection from the DVD to the TV as well (red/white RCA connectors)
I hope this helps,
Magoo
Posted on Mar 11, 2011
I have comcast cable serice. Do I have to hook up my dvd/vhs recorder to comcast box or just to my tv?
Your tv. You will use your tv "source" to select which input to watch from. Everything goes to the TV. I have a surround sound amp that I run the sound FROM the TV that way if I want it loud I turn that on. It is the only exception.
Dec 29, 2014 | Televison & Video
I have free cable at where I live now and hooked up my tv to the cable but now I don't know how to hook up my vcr player and my dvd player to my tv so I can tape my soap opera & watch dvd's. ...
What tv do you have? Whant model? DVD player and VCR can hook up to your tv in many different ways via HDMI, S-video, Component and Audio/Video cable.
May 07, 2011 | Televison & Video
My dvd player appears to be working - the disk is in place and the numbers advance as if it is playing - but all the tv screen displays is No Signal. I've talked to a Comcast tech and the problem doesn't...
Make sure your TV input source selector is set to the correct option (Video 1, Video 2 or Rear Video Connection or whaever the options are for your TV) when you want to play a DVD.
Try using the DVD player on a different TV to see if the DVD player is working OK.
Then try a different DVD player hooked up to your TV to see if your TV is set up OK.
You can also try using a different set of cables just in case the cables are faulty.
Try using an S-Video cable from your DVD player to your TV (if they both have those connections)and see if you get any signal that way.
When you are testing, be sure to check the sound on your TV to see if you are getting any audio signal from your DVD player.
By carrying out these troubleshooting procedures you should be able to narrow down exactly where the problem is and then fix it.
Apr 19, 2011 | Apex Digital AD-2600 DVD Player
How do I hook up a dvd player?
Hello Andy, Hi!, you can hook up your DVD in 3 ways. 1. using standard RCA cables, 2, using Svideo cables, and 3. using HDMI cables. Depending on your player. I suggest you buy the RCA cable. they are color coded so the yellow goes to the player Video out to the TV video in, red and white cables goes to the Left and Right channel of the player audio out to the TV audio in. thats it.
Dec 21, 2010 | RCA F27242GY 27" TV
I have Time Warner cable. I have a Symphonic SR90VE vcr/dvd that I have hooked up to the main TV. The cable box services a second tv in another room. I can't seem to get the main tv and the vcr/dvd player...
Cable goes to vcr cable INPUT, then run cables from vcr OUPUT to tv INPUT or AV.
Then put tv on input or av channel or channel 4 and use put the vcr on the channel you want to record.
Apr 19, 2010 | Televison & Video
I have an old DVD player from 2002 & I'm trying to hook it up to my TV (old TV too). Do you have a graphic of the hook up? The TV has a spot to hook up my cable for my basic cable channels. The DVD...
You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
Feb 07, 2010 | Toshiba SD-2800 DVD Player
How do I connect my Magnavox DVD/VHS player to my Element Flat screen TV?
Do you have a newer TV or a older one lets start with a newer models does your tv have 3 or more jacks on the back or front you should see a RED, YELLOW and WHITE if you have a HDTV you should see more. (LETS HOOK UP) Did your DVD/VCR come with a cables if not you will need to buy at least 2 they are called RCA cables Lets start with the dvd/vcr combo on the back you should see a (LINE OUT) this is where playback or your picture and sound come out. On the back of the TV you should see a (LINE IN) this is where you plug it in to. RED goes to RED, WHITE goes to WHITE and YELLOW goes to YELLOW. To Record you will need to hook up the line in on your combo and the line out to your tv. ( IF YOU HAVE AN OLDER T.V WITH NONE OF THOSE JACKS ) you will need to buy a RF- MODULATOR the are cheap it is a box that let you hook a cable wire to a little box and the RCA jacks to you combo and you will turn your tv to channel 3 or 4
Jul 15, 2009 | Philips Magnavox DVD/VCR Dual Player
How do i hook dvd player to tv..i know its probably simple
The yellow and white cables hook into your tv inputs
Jan 19, 2009 | GPX D1816 DVD Player
Hooking up DVD player to proscan TV. Video is coming thru but there is no sound.A digital cable box from comcast is in the mix. I can usually figure things out but I am stumped on this one. Any ideas?
Hi,if you have video and no sound you have hooked up the dvd with component cables but you still need phono cables for sound,run these from the dvd audio output to tv audio in,if you have a amp for sound come from dvd out to dvd in on your amp.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Audio Players & Recorders
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Curtis DVD1041 Player Logo
229 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
