Tripping out when turning dial on front. - Washing Machines
  • john_cross Mar 11, 2011
    We could do with a little more information, please ;-0)
    You do not say what the make and model is. Is it the main breaker which is tripping? Also at what point of the dial does it happen?
    Thanks,
    John C
    Brigadier General:
  • 6,277 Answers
(I've used the same solution for both of your postings)
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that you only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Posted on Mar 11, 2011
Intermatic WH40 will not "turn on" trip switch but will do the turn off trip switch. Why?
Make sure there one silver and one black adjustable trip pins on the dial. One is for on abd one is for off.
Feb 20, 2015 | Intermatic Wh40 Water Heater Timer Switch
Why does my dryer only work for 20-30 sec. and then turn off?
The high temp safety switch could be shorted.
Aug 24, 2014 | Maytag Dryers
Kia Sedona- center and third row heating vents blowing cold air
This model has a rear heat/cold blend door actuator. Its an electric motor that moves the duct door from hot to cold. When they wear out, they're usually stuck on the last setting
Nov 13, 2013 | Kia Cars & Trucks
My tork 1101 timer will not trip on. It trips off ok. Manual override works fine, trip pins fine. When I manually rotate the dial it trips off fine, i hear and feel it click when the on pin pass, but the...
as per geno, Tork T1101 has 120 Volt clock motor and is generally used for 120Volt loads but can be wired other ways to handle 240Volt circuits.
Here are basic wiring instructions for 120Volt.
1) Black Hot wire from breaker connects to both terminal 1 and terminal L.
There is usually a brass connector plate between these two terminals. If that plate is present, then connect Hot wire to one terminal or the other.
2) White Neutral wire from breaker box connects to terminal X.
3) Black wire going to Load (light, fan, motor) connects to terminal 2
4) White neutral wire going to Load connects to terminal X along with other neutral wire.
That's the wiring.
To operate timer:
1) Set current time: rotate dial clockwise until current time lines up with the word TIME that is located to lower right of dial at about 5 o'clock position.
2) Put on-off trippers on outer edge of dial at times you want timer to turn on and off.
The trippers are marked ON and OFF.
3) The ON tripper rotates around on the dial until it encounters a lever, and then it pushes the lever.
The lever clicks one direction for ON tripper, and then OFF tripper pushes lever other direction.
The lever opens and closes electrical contacts which turns the Load on-and-off.
May 14, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
When you turn on the drier it trips the electricty. there is power in to the power switch but when you turn the dial it trips the fuse box. the model is TC7103W
an electrical earth leakage will cause the trip. possibly the the heating element. but the motor or wiring fault can do it. you could try disconnecting the heater if the electric stays on. then change the element.
Jul 22, 2010 | Zanussi Dryers
Washer will not start - no power - no noise when turning dial.
Is there power at the wall plug? A breaker might be tripped.
(Just a thought)
Hope this helps... Good luck.
Jul 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Display for s80 volvo car maintence keeps popping up on dial;
1. Turn on the ignition. Make sure you have T1 on trip odometer.
2. Press trip odometer some 3 sec, or until you hear a beep or you see an yellow triangel flashing or the previous trip mileage appears.
3. Release the trip button.
4. Turn off ignition.
The service reminder should be reset. Don't forget to service your car.
Apr 17, 2010 | 2000 Volvo S80
Worked fine until I tried to change the on/off time of the lights. Now the timer does not move around. I have unplugged it and plugged it back in but still does not work. How do I fix it? ML300RTW
Check to see if you are getting power at the outlet. Sometimes GFCI receptacles will trip with very little provocation. Also, remove the trips and re-install them, as you may have inadvertently jammed one between the dial and the case, causing the dial not to turn Needle nose pliers make it an easy job to remove and replace the pins. You should be able to turn the dial easily.
Also, if you tried to install a trip in a slot close to the current time, it's possible it may have jammed the mechanism.
Dec 08, 2009 | Malibu ML300RTW - Low Voltage Power Pack...
Frigidaire compact 30 elec. stove. I need a wiring diagram for the front connections for oven, burners, oven lights. My oven isnt working and when I removed the front cover, noticed a wire not connected. ...
Does yours have the timer/clock thing that stands at the rear left of the stove? If so, make sure the far right dial is set at Manual. I had a repair person come out once (luckily it was someone I knew who didn't charge me) because my oven quit working. He turned the dial to manual and presto! :)
Sep 19, 2008 | Kitchen Ranges
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
