I need to reset a new HP 4700 DN to factory settngs so I can reset the IP adress, to all 0's. Thanks
  • 104 Answers
Performing a cold reset erases all of the EI0 card information. Print a configuration page prior to performing a cold reset to reference previous information.
1. Turn the printer on.
2. As the printer performs its memory count, press and hold the check button until all three lights on the control panel are lit.
3. When SELECT LANGUAGE appears on the control-panel display, press the arrow up button until COLD RESET appears on the control-panel.
4. Press the check button. The printer performs a cold reset and then continues its power-on sequence.
Hope this helps
Please rate this solution, thanks!
Posted on Mar 11, 2011
  • John Smith
    John Smith Feb 04, 2015
    When I try this, I don't receive "Select Language". I get enter password. I've tried every password I could think of, as well as the default service password. Any ideas?
Reset fuser on Xerox phaser 7760
You don't need to reset it it. It should automatically reset with no problem you can try to clear the NVRAM . Careful because you will lose all the information you have stored in it like any IP address or specific settings. What it will do is bring the printer to"factory default settings. You can do it in "service diagnostic mode. goodluck
Feb 19, 2014 | Xerox Corporation 7760/Dn - Xerox Phaser...
My hp laptop had its memory wiped back to factory specs how do i give it a valid ip address so it can connect to my homenet 4a4e wireless
Check your router and confirm ip adress, and type manual ip adress on your wireless network connection properties in your computer.
Apr 13, 2012 | Computers & Internet
How to re configure ip adress
Go to the "Resets" menu and select the "RESTORE FACTORY SETTINGS" selection. This will revert your machine to the condition that it was in when it came from the factory. Remember, the default for networking is DHCP, so once reset and online, you could use the web interface to configure it further.
Apr 09, 2012 | HP LaserJet P3005n Printer
J9400b defult ip adress
There should be no default IP address on a 2626 switch. HP Procurve switches are setup by default to get an IP address by DHCP. To execute the factory default reset on the switch, perform these steps:
  1. Using pointed objects, simultaneously press both the Reset and Clear buttons on the front of the switch.
  2. Continue to press the Clear button while releasing the Reset button.
  3. When the Self Test LED begins to blink, release the Clear button. The switch will then complete its self test and begin operating with its configuration restored to the factory default settings.
Be aware, using these instructions will wipe out any configuration you have on the switch
Good Luck
Jan 21, 2012 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
E250dn TCP/IP: Actif: yes Adress: 0. 0. 0. 0
What you need to do is reset the Network Settings, to do this please click on the link http://bit.ly/kR1jke
Please contact Lexmark Technical Support for additional assistance
Jun 29, 2011 | Lexmark E250dn Laser Printer
Need to access router. does it have a default ip adress
if no one changed it, should be something like
192.168.(0 or 1 or 100).(1 or 2 or 100)
if you google your owners manual should have that info too
Oct 07, 2009 | Panasonic (BBHGW700A) Wireless Router
HP LaserJet P2015n Printer IP adress
To Me it looks like your printer is set to automatically select an available IP address. If there is no IP available you get the 0:0:0:0 You need a static IP set up for the printer, this will make sure that no one can use the IP. If this is a company printer, get IT to set it up for you. If its your home network you can set this by yourself by either connecting your printer via usb and using the software from HP or if you have an IP you can log into your PC by entering the IP address in the address bar of your browser. You should get the HP page up for your printer. Set the IP from there in the networking section. I hope this helps a little
Aug 18, 2008 | HP LaserJet P2015n Printer
Need a password for factory reset
you are able to access the IVR, reset it back to factory default settings. Dial 73738# and press 1 to confirm the reset.
Jun 01, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
Default IP Adress of the modem Hughes HN7000S
The Hughes addresses are 66.82.4.8 and 66.82.4.12.
Mar 06, 2008 | Computers & Internet
Can I reset the address of the router?
wire a computer directly with ypor router.
Have contact? if Yes you can read the IP adress within your operating software.
READ!!
Connecting two routers to each other is not difficult but is a lot more work than only changing the IP address. Firewall/ DHCP and other settings have to be changed on both routers. You need to look this up in the manuals of your routers.
Hope to have helped you.
Pascal
Jan 23, 2008 | Asante (99-00618-71) Router
1,776 people viewed this question
k24674
