Shorting out when you turn the dial on front ,was making funny noise the other day too
    Problem Solver:
  • 9 Answers
Please post a model number. What do you mean by 'shorting out'? Was there a pop, or spark, smoke, or burning smell? What was the funny noise? A hum, a clanking, a squeal? And what area of the machine did it come from? Does the machine agitate, spin, or fill? Thanks.
Posted on Mar 11, 2011
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Panasonic MC-CL673 vacuum is not getting up to speed and smells
Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar. This is causing the smell (burning rubber). I don't believe it is your motor. :-)
Jim
Nov 29, 2009 | Panasonic Vacuums
I have a GE Spacemaker xl1800 - Funny noise, flickering light
very possible your magnatron is faulty. Disconnect 2 transformer wires and make sure they dont short. try the program again. if no noise, replace magnatron:capacitor and HV diode Please i strongly suggest an electrician help you as it is truely dangerous in there. .
Sep 15, 2009 | Microwave Ovens
G36710 RCA console TV just quit while watching... makes noise
a shorted horizontal output transistor will make a funny squeek or chirp noise when turning on the tv. Usually mounts on a metal dissipator near the bulky plastic part with the red thick wire coming out of it.good luck!
Aug 06, 2009 | RCA D52W19 52" Rear Projection Television
No picture, funny noise
The funny noise is probibly the balist trying to strike the lamp. It will try several times to strike the lamp and if it is un successful, the lamp light will begin blinking on the front of the set. If so you have a bad bulb
Jul 01, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Front load washer makes funny noise when pump turns on
The pump sounds like it may be plugged wih a coin or something like that. If the pump is plugged it will make a funny noise. Remove the pump and clear everything out of it
Jun 07, 2009 | Frigidaire Affinity ATF6000F Front Load...
Front loader is making funny noises. It was
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Noise coming from rear hub after replacing various fluids
did u use honda fluid and honda friction modifier if not diff will make funny noises worse when turning at a slower pace
Dec 16, 2008 | 2003 Honda Pilot
Electrical noise
If the noise from the compressor sounds like a humming followed by a click, the compressor is "short cycling". Could be either the compressor relay or the compressor itself is bad. Not sure on the hissing noise. Could be just a loose panel that needs to be tightened or adjusted.
Apr 07, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
