Question about Cuisinart CBK-200 Bread Maker
The pin in the bottom of the breadpan has fallen out and the seal is starting to briddle so I cannot use the pan anymore.
    Genius:
  • 1,739 Answers
I need a new round gasket that goes under the dough blade. Where may I obtain one?
Hi, That "gasket" can not be replaced. It is part of the sealed bearing assembly located on the bottom of the pan. This bearing fails after time and the breadpan needs to be replaced if you can find one.. Check out ebay or amazon for a bread pan. Sorry for the bad news. Hank
Aug 22, 2010 | Breadman Kitchen Appliances - Others
The gears underneath are frozen and won't turn the paddle inside the pan. Is there anyway to unfreeze the gears. It appears that the gear grease has all oozed out and the gears underneath are fused and...
The gear grease you are referring to is from the sealed bearing on the bottom of the pan. This has failed and will not allow the paddle to rotate. There is no replacement parts, and a new bread pan is needed. Sorry..Hank.
Jun 10, 2010 | Toastmaster TBR15 Bread Maker
Paddle shaft unable to rotate in the breadpan.
Hi, There is a sealed bearing in the base of the bread pan. When this sealed bearing fails the paddle gets stuck and will not turn. Take the pan out of the machine and see if you can turn the paddle by hand. If it doesn't turn freely, then it's probably the sealed bearing that is is failing. If it turns freely, then this is good news. Keep the pan out of the machine and go to a kneading cycle. Look through the lid window to see if the motor shaft is turning. If it is not turning, then a belt fell off , needs to be tightened, or has broken. Motor, belts and pulleys are in the base of the machine. Remember to unplug machine before working inside the machine. Finally, make sure the pan is seated in the machine correctly. Good luck Hankl
May 11, 2010 | Black & Decker Bread Machine
I have a Zojirushi bbcc-s15, and it started to leak from the bottom pan. The felt washer on the bottom has fallen off. Where can I find or how can I replace the outer and inner parts?
All those parts are part of the sealed bearing that is stamped into the bottom of the pan. Unfortunately they can't be replaced and you will need a new bread pan. Sorry Hank
Mar 10, 2010 | Zojirushi BB-HAC10 Bread Maker
Black substance on bottom of bread pan. What is it?
That's oil from the sealed bearing. Breadpan needs to be replaced soon.
Hank
Sep 10, 2009 | Kitchen Appliances - Others
Breville breadmaker model BR1 breadpan
seems like we all have the same fault with this breadmaker - and we all cant find the solution easily - looks like breville really dont have much of a customer care section do they - i suppose they think you should just go out and buy a new one -i am still hunting for a new pan and paddle - looks like they're as scarce as rocking horse **** !!
Jan 12, 2009 | Kitchen Appliances - Others
I have a Breadman TR 800. Can I buy a shaft seal for the bread pan?
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Nov 09, 2008 | Kitchen Appliances - Others
Cuisinart CBK-200 Bread Maker Logo
66 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
