Question about Directed Dei Valet 561r Remote Start/Keyless Entry
Car cranks but will not start - Directed Dei Valet 561r Remote Start/Keyless Entry
2001 hyundai xg300 My alarm was set lost my keys thought they was in the car but was in the house lol ,but I got in the door with a lock out when I went to in the dooor opened it ,The alarm sounded off not knowing where the keys was I took out the battery ,now I found my keys but battery back in and car wont start starter checked out good is it the theft causing it not to fire up
Posted on Nov 09, 2011
  • 430 Answers
It can be the issue with anti-theft system.The security system must be causing the problem, as you mentioned that doors automatically gets unlocked.But if that is not the case then it Can be short in ignition switch harness wire or there are many other possibilities too. Click the link below and follow the instructions to troubleshoot the problem:---http://schematicsdiagram.blogspot.com/2011/05/carjeep-no-start-troubleshooting.html
---- Thanks.
Posted on May 19, 2011
It turns over but it wont start
Engine cranks but won't start. Troubleshooting tips
www.samarins.com/diagnose/index2.html
In this guide, we are going to look into no-start problems when the car engine cranks,but won't start. If your engine won't crank at all, check the first part No-start: ...‎Why a car won't start - ‎Crankshaft position sensor - ‎Check Engine light
Engine cranks but won't start - YouTube
? 8:03
https://www.youtube.com/watch?v=1L4nB2NdA0U
May 16, 2014 - Uploaded by jimthecarguy
2003 Ford Taurus 3.0 liter 24 valve no start cranks OK.You will not ... Car will not start trouble shooting guide, wont crank, wont turn over, etc.
Problem 5: Engine Cranks But won't Start
Jan 01, 2016 | Cars & Trucks
My husband just replaced my water pump on my 2000 Camry, now it cranks but won't start what happened?
car no start problem. - YouTube
? 6:11
https://www.youtube.com/watch?v=uaKQkHMgFSI
Mar 18, 2014 - Uploaded by LearningZone
Here is Toyota Camry 2000 model which is not starting. The car had come from ... Test an engine that cranks but won't start. - Duration: 1:54. by ...
www.samarins.com > For Car Owners
Few tips how to find a problem when the engine cranks but won't start: what is ... If your engine won't crank at all, check the first part No-start: Car won't crank. .... Now, Google "Passlock" and you will find a number of treads at various forums ... cause a problem where the engine cranks but won't start in some 1996-2000 ...
Oct 29, 2015 | Cars & Trucks
My 1989 Toyota cress I'd a will crank but won't start .
Fixing A Car That Cranks But Doesn't Start Up - YouTube
? 3:22
www.youtube.com/watch?v=064Ilsz8Fzg
Mar 30, 2010 - Uploaded by Scotty Kilmer
Fixing A Car That Cranks But Doesn't Start Up ... for the last 46 years and counting, shows how to fix a car that cranks over but will not start up. ... Engine cranks but won't start - Duration: 8:03. by jimthecarguy 477,267 views.
Test an engine that cranks but won't start. - YouTube
? 1:54
www.youtube.com/watch?v=weidkoI7clE
Aug 24, 2011 - Uploaded by CheckMyEngineLight
I have a 98 Jeep Grand Cherokee and it will crank but won't stay crunk. .... Try this if it cranks perfectly but wont start : Camshaft Position Sensor ...
Oct 27, 2015 | Toyota Cars & Trucks
1998 ford couier ute wont start
it must crank fast or no car starts.
mine push starts and gravity starts.
does crank,,,
look at crank shaft of car (front pulley) is it spinning fast as person 2 cranks, yes, then it is cranking and must be fast and robust.
is it?
Mar 25, 2015 | Ford Cars & Trucks
Will not start
is this this s DIY question or ? just a request for wild guessing.
Ill assume its a real DIY. ? do tell.
what is a jumper box to house. ?????????????????
first off, you need to say,
it cranks robustly but does not start or not.
does it crank? if yes, why buy a starter?
no car starts unless cranked. (mine push starts and gravity starts)
but I bet yours is a A/T tranny , automatic.?
so does it crank.?
lets pretend, it cranks perfectly.
and really is a no start (confusing your replacing a starter )
this jeep , like most from 1993 have the ASD relay.
THE ASD relay must close to start the engine.
The ASD relay must close, and if spark , and up to 7 other things
are good, then it will stay closed, if not it drops out. KILLING starts.
that is what it does, so watch the ASD while cranking, what does it do>???????????
http://www.fixkick.com/Jeeps/ASD.html
now I will do NO CRANK.
and the funny house box thing, (a battery charger? or what i cant guess)
no cranks are caused.
By bad shifter, switch.
this is called the key line.
so i hot wire the starter solenoid, (remove tiny wire first to it)
ask how to do this.... its not hard. (mostly but some cars have shields making it harder today)
and it dont crank ! NOW? , then bad battery,starter bad, cables or seized engine. (turn engine by hand ,ok? to spin? by hand?)
and it does crank. then bad key line is reason.
easy huh? just one hot wire step and bam, problem cut in half.
i then try to crank in neutral, bam it cranks. and starts.
bad PRNLD switch.
or i just wiggle the shifter, bam, it cranks
or i wiggle the key switch funny in crank position and bam it cranks
bad key switch.
last, pretend the starter fails the hot wire above.
i hit it with a hammer, bam it cranks now.
we can do all that with a voltmeter easy,
ask.
http://www.fixkick.com/nocrank.html
see hot to solve no cranks on most cars.
other simular failures.
battery dies after parked.?
charge light (dash) on , driving? or idling, bingo, dead battery.
one more , car cranks but will not start for longer than 2 seconds
ASD action
but you failed to notice the Immobilizer lamp glowing wrongly.
my last answer. the funny house thing is a battery charger
and if you leave it charging long enough car cranks.
bingo?.?????
if yes, then the battery is DEAD and is DISCHARGED.
it discharged because you or something is left running, in car.
see phantom drains here.
the reason the car jump failed is you didnt give it enough time.
a very bad car battery can swamp the donor cars power source.
(and easy with cheap jumper cables.)
here is what you did wrong.
car is rested, it wont crank
you open the hood.
and check the batteryvoltage with a volt meter.
it reads 12.6vdc rested. good, it should crank ok, (but my not)
or it reads 12v, its discharged, so charge it to 12.6v and try again.
http://www.fixkick.com/drain/drain.html
  1. won't crank?
  2. battery discharges overnight.?
  3. won't start but cranks ok.?
  4. charge light stuck on.? running.?
which?
Apr 05, 2014 | Jeep Compass Cars & Trucks
Hi, guys, my Isuzu kb 320 v6 just cranks and won't start. The problem started after bursting a water pipe, the engine overheated and stalled. I replaced the water pipe, tried to start but all it did was...
mine cranks but fail to start.its KB 320 v6 of 2001 petrol.some Automan sujest wrong key programming since her keys were lost.they tried several times but the car is still cranking n no start.what can b the solution.its 2years now n the car is still cranking.I'm in Zimbabwe. pliz help were the right thing should b done for the car to start.my number +263773027643
Oct 03, 2013 | Cars & Trucks
Refuse to start, who much will it cost me to buy another one?
another what?
NO CRANK or NO START
no car starts unless cranked fast. or pushstarted (stick) or jumper cable cranked.)
if it dont crank
1: check all fuses.
2: try jumper cable start, does it crank now (stater makes noise and engine crank shaft spins(eyes see that)
Aug 05, 2013 | Honda CR-V Cars & Trucks
Car won't start without a jump but battery okay
wont crank or wont start.??
no car starts , if it cant crank. (unless push starter (M/T magic)
that is not a trans sensor its the PRN switch.
ill answer for, wont CRANK !
it wont crank even with a good battery (charged) or jump started.
1: bad start
2: bad wires to same.
so hot wire the starter small wire, the key start line is tiny.
cranks. , starter good, no crank starter bad or cables bad.
if it cranks hot wired, then the key line is dead.
easy, huh?
Feb 11, 2013 | Suzuki Forenza Cars & Trucks
Car wont crank 1994 plymouth acclaim
Not sure what yor experiencing . Do you have crank no start or no crank no start? No crank no start is battery and cables issue. Crank no start is ignition , plugs, and fuel.
May 28, 2009 | 1991 Plymouth Acclaim
Directed Dei Valet 561r Remote Start/Keyless Entry Logo
154 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
