Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Shorting out tripping electricity,when we turn the dial it trips house lecky.was filling wth water an then triped.
    Brigadier General:
  • 6,277 Answers
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that you only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Posted on Mar 11, 2011
My fridge tripe the earth leakage everytime I switch on the fridge.
call ana accredited electrician to check the insulation of the wires and for vermin infestation that is across electrical connections
it could be a faulty capacitor or failed motor as the earth leakage breaker is also a fuse for excessive current draw
Jun 08, 2017 | Whirlpool Refrigerators
Breaker at dishwasher trips right after water has filled.Spray arm has not turned.
There is an electrical short circuit, check/reverse the leads going to the pump or heater.. Sounds like controls and water valve are fine. If wires are not connected to the correct locations you need a new motor because it is internal.
Aug 26, 2012 | Kenmore 665
The therostat breaker keeps triping no mater what the therostat setting is. I have to reset the breaker each time i want hot water. Is this GE solution to save energy?
It sounds like the thremostat may be shorting out they are not to exspensive to replace.
It it constantly triping there is a wire touching somewhere.
May 16, 2010 | General Electric GE SmartWater Household...
Our zanussi cooker is tripping out. Any idea what fault might be? Is it worth getting a zanussi electrician or a local electrician to look? Thanks in advance
if it trips as soon as you turn on a certain function that may point you in the right direction.If it trips when you just turn on at mains with no funtions set then it would be advisable to get the zanussi man out most leckys will find fault but tell you to get service man to sort it.
Hope I was helpful.
Good Luck.
Apr 25, 2010 | Zanussi ZBF360X Electric Single Oven
Trips breaker
If it trips the breaker you MUST have an Earth fault and or a short circuit to Neutral/Earth. You must get a Registered Electrician to look at it.
Feb 03, 2010 | Eemax SP80 8.0kW 277V
Second hand Fisher & Paykel keeps tripping power off
sound's like you have dead short to ground in the start mode of the compresser.
Nov 22, 2009 | Maytag MSD2651 HE Side by Side...
Washing machine tripping RCD
electrical short in m/c.could be heating element. regards
Jul 30, 2009 | Washing Machines
Circuit breaker trips when turning unit on. only unit on circuit has triped on several circuits can find no shorts on wiring.
DOES IT BLOW THE BRAKER AS SOON AS IT TURNS ON OR DOES IT TAKE A FEW SECONDS. INSTANTLY WOULD MORE LIKELY BE A SHORT IF FEW SECONDS THE COMPRESSOR IS PROBABLY DRAWING MORE AMPS THAN THE BREAKER CAN HANDLE SO IT BLOWS. TRY TAPPING THE COMPRESSOR NEXT TIME YOU ATTEMPT A HOUSE CURRENT START UP. i HAVE A WINDOW AIR CONDITIONER THAT NEEDS TAPPED FOR STARTUP FOR THE SUMMER SEASON. GOOD LUCK
May 01, 2009 | Dometic RM2852 Refrigerator
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
