Question about Microwave Ovens
Needing to assemble an old Qualheim Model 200 Slicer and looking for some type of assembly picture or owners manual
Owners manual for a GE Spacemaker over the range microwave model #JVM1440WH01
GE has the manuals for most of their products on their support site: http://www.geappliances.com/ge/service-and-support/literature.htm?icid=GEARsupportflyout-manuals . The direct link to the Owner's Manual for the JVM1440WH01 is currently https://www.myapstore.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40473.pdf . This particular model's support page is https://www.geapplianceparts.com/store/parts/assembly/JVM1440WH01 .
I hope this helps.
Oct 15, 2017 | GE Microwave Ovens
Where do I purchase the microwave oven bulb model #100n30als3b
You should be able to take the bulb to a local hardware store, home center, or big box store like Wal-Mart and match it to one in stock.
If it's an integrated bulb assembly in its own socket, you would have to contact the manufacturer.
The contact information for the manufacturer will be in the owner's manual.
If for some reason you don't still have your manual, here are ways to get one:
Look at the model number tag and find the FCC ID number.
Enter the number (in two parts) as shown on the FCC ID page here:
https://www.fcc.gov/oet/ea/fccid
In the list of exhibits, look for the owner's manual. You can download it free.
If it's not there, you should be able to order it via the links on my part ordering page here:
http://www.microwavecontrol.com/parts.htm
- William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 05, 2017 | Microwave Ovens
I need an instruction manual for Ronson Food slicer model 87003 please
Bronte,
Did you ever get a manual for your Ronson food slicer, model 87003?
I have 1 of these slicers & am needing a manual as well.
Apr 19, 2011 | Microwave Ovens
How do assemble a Krups 213A food slicer?
I was looking for the same thing and this is where i found the instruction http://ep.yimg.com/ty/cdn/krupsonline/213.pdf
Jan 18, 2011 | Microwave Ovens
Where can I find a user's manual for a Toledo Scale meat slicer, model#5401?
looking as well for sharpening stone for model 5400-0-001
Oct 22, 2010 | Microwave Ovens
Owners manual for food processor FP022
If reasonably new look for serial number and model type.
Go their or ring place of purshase and ask if owners manual is available. they might be able to help.
If it is an old appliance, check on computer just type in what you want with the serial number and model number, and theirs a good chance it will be their.
Sep 12, 2010 | Microwave Ovens
My Tappan TMV151FS MIROWAVE OVEN DOES NOT WORK THE MESSAGE READS (SE) IN THE LCD WINDOW CAN'T LOCATE MY OWNERS MANUAL CAN YOU GIVE ME ANY INFORMATION ON THIS PROBLEM THANK YOU LEO LAFLER
"SE" means you have a shorted membrane keypad.
The most economical repair (and a pretty simple one) is to replace your entire controller assembly.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Model TMV151FBA is black and model TMV151FSA is white.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
You would order one of these here:
PART DESCRIPTION COST
5304456080 Control Box, assembly, black $145.14
5304456081 Control Box, assembly, white $149.42
Sep 07, 2010 | Tappan Microwave Ovens
Can i get a display screen for a sharp microwave model # R-530ES, and if you can provide this display, can it be shipped to miami?
The relevant service manuals are HTML clipboard here and here. hey contain detailed disassembly instructions.
There are three ways to get this fixed:
1. You could order a new power unit (lower board assembly) and a new upper display board assembly, solder them together, then replace your assembly with the newly assembled one.
You'd need the following parts:
DPWBFC167WRKZ CPU/LSI/display unit $107.07
DPWBFB094MRU0 power unit $53.09
Which can can be ordered from Encompass here.
2. This option is more difficult, but cheaper. You would order the upper circuit board assembly, desolder your old one from the lower power board, then solder the new upper board onto your power board.
You'd only need to order this part:
DPWBFC167WRKZ CPU / LSI / display unit $107.07
3. You could send your control panel assembly for repair for $39.95 with a one-year guarantee. Details are HTML clipboardhere.
Aug 31, 2010 | Sharp R-530ES Microwave Oven
Looking for a printable/downloadable owners manual
Go to managemylife.com and type in the model number you provided under the "Manuals" link. Your owner's manual is available in a .pdf (Adobe) format that you can download or print for FREE. I hope this helps you.
Mar 02, 2010 | Microwave Ovens
How to replace light bulb in Quasar microwave oven model MQS1236H
Could that be MQS1263H?
Either way, this owner's manual may be close enough.
If it's not addressed in the manual, and there's no obvious cover on the side or back, then you'll have to remove the cover of the oven to change it.
If it's an owner the range type, you can likely get to and replace the light by just removing the grille or possibly the control panel assembly.
If it's a counter top unit, you will need to remove the outer cover and look for it near the magnetron cooling duct on the right side.
Before doing any disassembly, please see these files: safety disassembly.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
You can also order Panasonic parts here.
Dec 25, 2009 | Microwave Ovens
Microwave Ovens Logo
55 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
