Question about Brother HL-4070CDW Printer
Hi I'm getting pink images from a Brother HL-4070CDW. I've tried recalibration and setting the colors adjustments in printing preferences, but that didn't change anything. Straight black prints fine. The drum unit counter is <900. Thanks!
  • hoeffner558 Nov 15, 2011
    Hi
    (Belated) Thanks for the response. The toner cartridges for this printer have been a nightmare. The magenta has since been replaced (used up) and all seems fine. For now...
  • Brother Expert
  • 159 Answers
It could be a problem with the bias voltages in the High Voltage Power Supply, but a much more common cause is simply a bad magenta toner cartridge. If the cartridge is fairly new, take it and a print sample back to the store where you bought it, and they might exchange it for you.
Posted on Mar 11, 2011
Brother HL-4070CDW still prints page upside down in duplex.
Check the duplex settings, often you have a choice on long side or short side for duplexing. If short side is chosen then it will print duplex as though you are making a flip chart not a book
Nov 10, 2014 | Brother HL-4070CDW Printer
Brother HL-4040CDN printer colors are off, tend to be pink
There could be a number of causes for the problems your describing, but one of the most common causes of discoloration and issues with toner is a faulty ribbon sensor. A broken sensor will be unable to accurately read the ribbon and apply the correct color. I hope this helps
Sep 02, 2012 | Brother HL-4040cdn Color Laser Printer...
Hi. When we print color pages, on our HL-4070CDW, there are colors on the edges of the paper...usually on the right side of the paper. Sometimes it's yellow or red, etc. How do I resolve this?
You need to clean your corona wires. Go to Brother support website. Look for Problem 100000012419 and follow steps in solution 200000015852.
Sep 16, 2011 | Brother HL-4070CDW Printer
I have a Brother HL 4070 CDW. I have replace the Magenta cartridge but it seems to be spilling ink. When I print in color, the images are not good.
Make sure that the toner cartridges are installed properly.Make sure that the drum unit is installed properly.Make sure that the belt unit is installed properly. Perform the calibration. Adjust the colour by using the custom setting in the driver and by using the control panel. Colours the printer can print and colours you see on a monitor are different. The printer may not be able to reproduce the colours on your monitor. Make sure that you use paper that meets the printer's specifications. Put in a new drum unit.Put in a new belt unit. Check the printer's environment. Conditions such as high humidity and high temperatures may cause this print quality problem.Identify the colour causing the problem and put in a new toner cartridge. If the problem continues, put in a new drum unit. Also visit >>
Image Defect Troubleshooting
Sep 06, 2011 | Brother HL-4070CDW Printer
Why is there a hazy back ground to printing on Brother HL 4070CDW?
The DRUM is faulty, you need to replace it, but check first with Brother for warranty, they may replace it for free.
www.brother.ca
Jan 03, 2011 | Brother HL-4070CDW Printer
Brother 4070CDW Shadowing Problem
Check your toner if they are properly installed.
Check your drum if they are properly installed.
Clearn your toner and drum.
Print a test page.
If nothing happens please replace your printer drum
Sep 19, 2009 | Brother HL-4070CDW Printer
Hl-4070cdw prints booklets with upside down pages
I had the same problem and finally figured it out.
When you select print and the print window comes up:
select Printing Preferences or Properties (depends on program you are using),
select the Advance tab,
select the icon that has 'A' and 'B' on two pages (near the top left),
select Booklet Printing. (then Okay and Okay/Print, depends on program)
In all honesty, I'm can't remember if this is what I selected to fix the problem, but the choice is on this page. Try this with each choice of "Flip on Left Edge" and then "Flip on Right Edge".
If neither works, unselect Booklet Printing and try "Flip on Top Edge" and if that doesn't work, try "Flip on Bottom Edge". Etc.
I know the solution is on this screen so experiment until you find it.
Good Luck!
Jul 26, 2009 | Brother HL-4070CDW Printer
Color spots on left margin when printing with my HL-4070CDW
Replace the cartridge if that dont do it its the write head fouled up with ink or just plain died all togeather, dried ink can cause this to happen check and see if you can clean it out with 70 percent isp. alcohal if the issue still does not resolve its new printer time.
Apr 22, 2009 | Brother HL-4070CDW Printer
Brother HL-4070CDW Printer Logo
329 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
