Question about Xerox WorkCentre M-24 Color Copier
I have Xerox M-24. It goes through self test, turns on for two seconds and then off, saying a fault has occurred. The code is 116-349. Sometimes it actually starts up and works, then it throws this fault code, but today it will not work at all. My "tech guy" says it's a software fault and to press 6, stop and powersave while powering on. I do that and it reboots and says "Download Mode," but nothing else happens. I think it is waiting for something to download. What is going on, and what should I do?
  • 4 Answers
Go with a different product other than xerox. you will save yourself huge amounts of headaches. their network controllers are ****.
Posted on Mar 11, 2011
Why am I getting heat out of one duct with ac on. and sometimes after it runs a while you can hear the blower but little air from the ducts.
wow1, no statement of you have manual HVAC or the
AZC options automatic zone controls. (apples and org, diffr)
or is your car the MTC HVAC (manual temp controls)?????
what is your question>?
are you saying, it worked ok before core change
or fails before and after core change,??
my guess, after....
did you run the self test ? (guessing AZC)
for sure the damper are failing
only 2 ways do do that
controls bad
or the actuator bad. (or the wire between) maybe even fuses?
the WJ, the book is free.
read chapter 24 HVAC yet?
the AZC has 4 electric damper motors. (actuators)
chapter 24 and 8w cover hvac. i FSM
ill now post AZC self test, (posted here 10 times now)
quote:
ENTERING THE AZC SELF-DIAGNOSTIC MODE
To enter the AZC self-diagnostic mode, perform the
following:
(1) Depress the A/C and Recirc buttons at the
same time and hold. Rotate the left temperature control
knob clockwise (CW) one detent.
(2) If you continue to hold the A/C and Recirc buttons
depressed, the AZC control module will perform
a Segment Test of the vacuum fluorescent (VF) display.
In the Segment Test you should see all of the
display segments illuminate as long as both buttons
are held. If a display segment fails to illuminate, the
vacuum fluorescent display is faulty and the heater-
A/C control must be replaced.
(3) After viewing the Segment Test, release the
A/C and Recirc buttons and the display will clear
momentarily. If a 0 is displayed, then no faults
are set in the system. Should there be any faults,
either "current9 or "historical", all fault codes will be
displayed in ascending numerical sequence (note no
effort is made to display fault codes in chronological
order). Each fault code is displayed for one second
before the next code is displayed. Once all fault codes
have been displayed, the system will then repeat the
fault code numbers. This will continue until the left
side set temperature control is moved at least one
detent position in the CW direction or the ignition is
turned "OFF".
end quote
if no AZC , nows the time to say..... right?
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
Mar 15, 2016 | 1999 Jeep Grand Cherokee Limited
LL56
This type of code has not recovery procedure which could mean replacement of hardware component. LL-56 refers to a power board fault on the printer and occurs during power on self test.
Refer page 1-10 for the code description in this service manual.
http://www.printertec.com.br/arquivos_download/xerox/xerox8825.pdf
Jul 31, 2014 | Xerox 8830 Copier
8560 printer shut itself down and will not true back on
The following lists the chain of events that occur when you turn on a printer. You can follow this list as one means of determining if the printer is operating correctly. The exact chain of events depends upon the last power down condition and where the printer has last determined the printhead is positioned, this is stored in non-volatile RAM. The Checklist is the primary reference for troubleshooting power-up problems.
1. Power cord is plugged in and the power switch is turned on:
2. Power supply senses AC line voltage conditions (110 VAC or 220 VAC)
and enables DC voltages. If an overload occurs, the printer turns off the high voltage DC supplies, causing a "blink" effect on the Control Panel LEDs.
3. BIST test flashes the PE LED very briefly at a fast rate until the end of the
next test.
4. The Boot loader performs CPU initialization and RAM test. It then sends
the boot loader version to the serial port.
5. Power-On Self Test (POST) initializes the Control Panel. The Control
Panel LED turns red, green, orange, and then off. The Control Panel LCD then goes black and then clear. The POST version displays on the LCD
and waits two seconds. During this time the operator can press the Back
button to bypass the remaining POST test.
6. Low level Power-On Self Test (POST) diagnostics are performed. The
Control Panel displays status messages as each sub-test is performed.
This test takes about 8 seconds. All LEDs are off during the test.
If POST diagnostics pass, the Control Panel displays the Xerox logo and turns on the green LED.
If the test detects an error, the error message displays on the LCD and the printer flashes the LEDs with a repeating error code pattern.
7. The VxWorks operating system is initialized and engine code is started.
This takes about 15 seconds. The Xerox logo is displayed.
8. Print Engine Self Test (PEST) diagnostics are then performed. These test
the heaters, clutches, motors and solenoids. As each clutch is tested, you hear clicking with four high tones as each motor is tested. This test takes about 30 seconds.
9. The printer now runs the mechanical initialization. The exact sequence
depends on the initial position of the printhead and wiper assembly.
Feb 28, 2014 | Xerox Phaser 8560MFP Laser Printer
8560 shut down and will not turn back on
next test.
Panel LED turns red, green, orange, and then off. The Control Panel LCD then goes black and then clear. The POST version displays on the LCD and waits two seconds.
During this time the operator can press the Back button to bypass the remaining POST test.
Control Panel displays status messages as each sub-test is performed. This test takes about 8 seconds. All LEDs are off during the test. If POST diagnostics pass, the Control Panel displays the Xerox logo and turns on the green LED.
As my Xerox M-24 powers up, and gets to the fourth white dot during the start up self tests, which flashes three times, then the machine seems to turn on for two seconds, then gives the fault stating...
Try this with the network cable unplugged.
This step will delete all pending print or copy jobs in the job queue, and then perform a reboot.
To execute: simultaneously press and hold the 6, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
If it doesnt correct the problem the network board ESS has failed.
Mar 11, 2011 | Xerox WorkCentre M-24 Color Copier
Xerox Phaser 8550 error code 07,01043:90804
This fault occurs due to the printhead being stuck in the tilted position. There are many reasons why this fault will occur, too many to mention.
More often than not, your problem will require the printhead and process gear to be re-aligned in order to get a reboot but sometimes it is possible to get a reboot by doing the following;
Turn the printer off, wait ten seconds then turn it back on again. Wait for the printer to start warming up to about 5 or 10 percent. At this point, switch the machine off again by the machine switch NOT your wall/plug switch. Wait ten seconds and switch on again. Now let it run through its normal cycle. The success rate for this method is small, possibly only 1 in 30 machines will recover.
The reason this will sometimes work is that, when you turn the machine off from the warm up, it powers down using its proper head parking routine, you will notice, it takes a while to shut down. If the original fault was due to say a power cut or someone pulling the plug out it is possible for the printer to find its home position and boot ok.
Unfortunately, a lot of the time, the reason for the fault is printer related and such, this method does not work. But it is always worth a try.
Hope this helps.
Jan 19, 2011 | Xerox Office Equipment & Supplies
Xerox phaser 8560 DX error 07 010 43:14011
Hope this helps.
Dec 07, 2010 | Xerox Phaser 8560DN Laser Printer
Code 24 and 25 (blend door actuator)are showing up
yes, IP must come out.
Actuator —Electronic Blend Door Removal
  1. Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
  1. Remove the instrument panel. For additional information, refer to Section 501-12 .
  1. Disconnect the connector
But, you sure it's the blend door actuator?
Electronic Automatic Temperature Control Module Self-Test
  • The EATC module self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A scan tool must be used to retrieve these concerns.
  • The EATC module self-test will detect concerns in the system control functions and will display hard diagnostic trouble codes (DTCs) in addition to intermittent diagnostic trouble codes for concerns that occur during system operation. The vehicle interior temperature should be between 4°-32°C (40-90°F) when carrying out the self-test. If the temperatures are not within the specified ranges, false in-car temperature sensor DTCs will be displayed.
  • The self-test can be initiated at any time. Normal operation of the system stops when the self-test is activated.
  • To enter the self-test, press the OFF and FLOOR buttons simultaneously and then press the AUTOMATIC button within two seconds. The display will show a pulse tracer going around the center of the display window. The test may run as long as 30 seconds. Record all DTCs displayed.
  • If any DTCs appear during the self-test, follow the diagnostics procedure given under ACTION for each DTC given.
  • If a condition exists but no DTCs appear during the self-test, refer to the Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Improper Operation.
  • To exit self-test and retain all intermittent DTCs, push the blue (cooler) button. The control will exit self-test, retain all intermittent diagnostic trouble codes and then turn OFF (display blank).
  • To exit the self-test and clear all DTCs, press the DEFROST button. The vacuum fluorescent display window will show 888 and all function symbols for one second. Then, the EATC control assembly will turn OFF (display blank) and all DTCs will be cleared.
  • Always exit the self-test before powering the system down (system turned OFF).
  • Intermittent DTCs will be deleted after 80 ignition switch ON cycles after the intermittent condition occurs.
Connect a fused jumper wire between EATC module C228 pin 26, circuit 246 (VT) and EATC module C227 pin 2, circuit 54 (LG/YE). Connect a second fused jumper wire between EATC module C228 pin 13, circuit 245 (BN/LG) and EATC module C227 pin 3, circuit 57 (BK).
  • Does the actuator motor move in the clockwise direction?
sya~us~en~file=arrow.gif~gen~ref.gifYes GO to A2 .
sya~us~en~file=arrow.gif~gen~ref.gifNo GO to A3 .
Jul 02, 2009 | 2000 Mercury Grand Marquis
Fault 094-322
i have problem code 094-322 how cant i solve ?
May 22, 2009 | Xerox DocuColor 12 Color Copier
Xerox Workcentre 24. 20 months old. The sreen simply says: Fault/Error, then below: A fault has occured. Switch the machine Off and then On. If the problem persists, call for service. In the bottom left...
That is a software processing error.
Do you have it set up as a printer? If so, try removing the print cable and power it on that way.
If that doesn't work, you need to have the firmware reloaded. That can only be done from a laptop with Xerox software on it.
Oct 02, 2008 | Xerox Office Equipment & Supplies
Xerox WorkCentre M-24 Color Copier Logo
236 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
