Question about iLO (2 GB) MP3 Player
Infitek MP4 8GB player - No Drivers??
Hardware Device Manager cannot find any drivers for the player. When plugged in, the player permanently displays the hourglass 'wait' icon. Actually, it always displays that, plugged in or not. No 'Removable Disk' shows up in Windows Explorer. Only a failed hardware install.
  • 1 more comment
  • msudbury Jul 31, 2008
    Windows XP Pro. Tried the search for drivers. I even have the disk that came with the player in the drive. Seems that the disk is only about a wma-mp3 converter. I've also looked on Infitek's website for the drivers, can't even find the specific player...
    Tried the computer shut down & unplug. Waited maybe 20 seconds, restarted. Same deal. Didn't try uninstalling the device before power down though. But I did uninstall and reinstall it previously.
    More ideas?
  • msudbury Aug 01, 2008
    Okay, tried using a different computer with the same results. I think something is wrong with the player. Even when disconnected, it does nothing more than display the hourglass icon. Although I'm told that after its first battery charge, it did display and play the preloaded media. Not sure when it stopped doing that.
  • iLO Master
  • 13,433 Answers
Make sure you have windows media player 10 or 11 installed, I will look into this more later.
Posted on Aug 01, 2008
  • iLO Master
  • 19,396 Answers
The player should be recognised with no need for additional drivers. If it does not install try unplugging computer power cable, and if it is a laptop also remove laptop battery. This will reset power on computer and get rid of some usb problem, give it a try.
Posted on Jul 31, 2008
    Brigadier General:
  • 3,614 Answers
Did you try to check or use a different data cable..?
  • micromaster
    micromaster Jul 31, 2008
    are you using a laptop or desktop computer.?
  • micromaster
    if you are using a laptop, kindly check and change this setings;
    1, In the System Properties dialog box, click the Hardware tab and the Device Manager button.
    2. Next, look through the list of devices until you see Universal Serial Bus Controllers and click the plus (+) sign next to it.
    3. Double-click one of the USB Root Hub lines and click the Power Management tab in the USB Root Hub Properties dialog box.
    4. Click the Allow The Computer To Turn Off This Device To Save Power checkbox so it is unchecked.
    5. Click OK and restart your computer.
  • iLO Master
  • 6,487 Answers
What windows version are you suing?? Try going to device manager and look for a root hub there or any usb device that has a exclamation mark then right click on it select update driver and let the wizard search for the driver.
Hope that helps..........
  • 1 more comment
  • Mark Gil
    Mark Gil Jul 31, 2008
    Ok, did you try connecting that player to a different computer and check if it will work fine? Check also device manager if you will see any USB device there that has a exclamation mark..
  • Mark Gil
    Try uninstalling first the program then restart the computer, Then reinstall the program then plug the player then restart the computer..
  • Mark Gil
    Mark Gil Aug 01, 2008
    If that's the case we can already say that there's really a problem with the player that you have, if its still under warranty better have it replace...
Dvd player doesn t work
The Code 10 error is one of several Device Manager error codes. The Code 10 error will almost always display in the following way:
"This device cannot start. (Code 10)"
Details on Device Manager error codes like Code 10 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 10 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
Cause of the Code 10 Error
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem.
Error Code 10 Troubleshooting
1.Restart your computer if you haven't done so already.
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware. If so, a reboot might fix the Code 10 error.
2.Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to a version prior to your update.
•Use System Restore to undo recent Device Manager related changes.
3.Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
Important: If a USB device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Sep 14, 2013 | Dell Dimension E510 PC Desktop
Sansa View: is not recognized by my computer
See myother TIP posted here on this site. About MSC and MTP Connection problems.
First thing to do is:
Try otherUSB ports on your computer. A USB port on the back of a PC usually has better poweroutput.
Try adifferent cable if there's one available, to rule out if you have a bad cable.
Tryanother computer.
If none of the above works:
Then-Check and refresh the drivers in Windows, for a Portable Device.
1 -Connect your player to the PC
2 -Check under Device Manager
-> 1.Right-click My Computer, and select Manage.
NOTE: The player should show up on the Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2.Portable Device (if the player is set to MTP mode.)
(See my other TIP listed above for an Explanation of MSC and MTP modes)
If thereis a yellow exclamation point (!) or question mark (?) beside the device, tryto refresh the drivers.
Then -Refresh the drivers
1.Right-click the entry with the error mark, select Uninstall.
2. On thetop menu, click Action then select Scan for hardware changes.
If your BRAND NEW player is NOT recognized by the computer when plugged in:
This may becaused by one of the following:
1.Minimum system requirements were not met.
2.Corrupted drivers.
3.Computer restrictions, Vista or 7 authorizations.
4. Powerissue, plug your player into the back of the computer.
Next be sure you are using WindowsMedia player :
Version10 or 11
Downloadand install the latest Windows Media Player if it's not installed.
If all this has failed - Refresh the drivers again.
If allthat does not work - Manually add the hardware driver.
1. Connect the Sansa player in MTP mode
2. Manually install the device driver through Windows device manager in control panel. Install the Device as a Portable Device.
on Jan 11, 2010 | Audio Players & Recorders
When i connect my sony ericsson w200i phone by usb data cable to laptop then it shows that usb device not recongized
Cell phones use the popular USB connection which sometimes produces errors while connecting. These messages are similar to the "Device Not Recognized" error received with various USB devices. Fixing a cell phone is sometimes specific to the brand, but they are so similar that most can be fixed the same troubleshooting steps.
Device Manager
Click "Start" and go to "Control Panel." Double-click "System" and locate the Hardware tab to find the Device Manager. Vista and Windows 7 users can just type "Device Manager' from the start menu.
Locate "Disk Drives" from the list and double-click "Portable Device." If there is an exclamation mark or other error on the device, go to the "Drivers" tab.
Click "Uninstall" and remove the player. Restart the computer and attach the player reinstall the drivers.
Anti-virus conflicts
Plug the player into a different computer to see if it gets recognized. If it does not, contact the manufacturer to find out if it is broken.
Turn off your anti-virus program on your PC if the device works on other computers. Reinstall the drivers using the device manager as described in section 1.
Plug in the player to confirm the connection.
Other solutions
Check the battery level and make sure the batter is not low or depleted. A low battery will sometimes prevent the player from connecting. Let it charge from the power cord, if necessary.
Verify that you have at least Service Pack 1 installed. Go to the Start menu and type "Run." Press Enter.
Type "Winver" in the box and press "Enter." The Windows version will be displayed along with any installed service packs. Download a service pack from Microsoft, if applicable.
Remove the player from the USB port and push a pin into the reset hole located on the bottom. Reconnect to see if the problem is resolved.
Check the connection to make sure it's secure. The cable should fit firmly into both the player and the computer. Connect to a different USB port if you have one available.
Tips & Warnings
A bad cable will sometimes prevent a good connection. Use a different one to isolate the cause.
Jul 23, 2011 | Sony Ericsson W200i Cellular Phone
Hi am trying to connect it with my pc but its asking new hardware found "mtp device driver" but not installing just poping up againg and again not connecting with pc
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
If you have problem with your device follow this steps:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
May 03, 2011 | Sony Walkman NWZ-B135 MP3 Player
What is device manager
device manager is a control applet in windows. It informs you what devices (keyboards, dvd players, hard drives, mp3 players, webcams) are connected to your computer. You can also manage your drivers with it (drivers are the programs that tells windows how to work with the hardware specifically)
in windows 95, 98, and ME you can get to device manager by Settings > Control panel > Device Manager tab
Windows 2000 and xp = Right click on my compuer > "Hardware" tab > Device Manager
Windows Vista = Control panel > Hardware and sound > View Hardware and Devices
Windows 7 = Start Menu > Control Panel > System and Security > System > Device Manager
Mar 06, 2011 | Huawei MT841 Network Device
I have no sound on my pc
Check the sound drivers are loaded or not from control panel-system-hardware-device manager. If not load your MB Driver CD in CD tray & dble click & reinstall driver. If this also does not work & device manager says proper drivers are installed then check your speakers/headphones by plugging into a CD player. If they are OK then your sound hardware is kaput. Install a sound card on a PCI slot to get sound from your PC.
Nov 08, 2010 | Audio Players & Recorders
Device manager
Plug it into your computer via a USB cable. Open Windows Explorer, click on My Computer, click on Control panel. When there, double click on System. This brings up a screen called System Propertied, click on the tab "Hardware" and the top section is called Device Manager. Click on device manager, this will bring Device Manager up and should be able to diagnose the problem with your MP3 player. If it shows a yellow trianglewith a ! in it, it means there is a problem with drivers, but you will have to do it to see what it says.
Jan 18, 2010 | Philips GoGear HDD6330 MP3 Player
Infitek Player
not mac compatible
Aug 06, 2008 | iLO (2 GB) MP3 Player
No Display
i can help with the computer registering it...
insert zen v plus install cd
exit out of autorun for cd
go to control panel
click on system
click on the hardware tab
click on device manager
click on portable devices
right click on your USB device with the yellow warning sign
go to properties
when it tells you that the drivers arent installed... go to the browse button and select your zen v plus install disk
hit ok and it will find the drivers that way...
as for thedisplay... once you get the computer to recognize its there troubleshoot it.
Mar 26, 2008 | Creative Labs ZEN V Plus MP3 Player
Finding Device Manager
Once you have the Device Manager, click on the Repair tab. to find Device Manager:
Go to, enter in your model number - SA261; on the next page, click on SA261/17 (not /17B); click on software and drivers; then click on, Firmware upgrade - software
If this fails, enter model sa6087 and click on the "Device/Firmware Manager" link under the software & drivers section for that device
If this fails, go to start-->settings-->control panel (if using Windows XP), click on Add Hardware (with the GoGear connected), and run the Add Hardware wizard
Vista has a feature that allows you to add the driver by searching on the internet;
1) Go to, enter your mp3 player model number in the search tab and see if a new driver has been developed for this device to make it compatible with Vista
2) With your mp3 player plugged in to the computer, go to Start --> Control Panel --> Systema nd Maintenance --> Device Manager
3) Find your mp3 player on the list and double-click the device; click on driver tab and then update driver - select the option that allows you to search the computer AND the internet for the driver (make sure you are connected to the internet BEFORE selecting this option); if you do not see your exact mp3 player name on the list, look for a similar looking name on the list such as "MTP Device"; also, look for devices with a yellow exclamation mark next to them - this is a sign of a device needing a repair or driver update
If all of the above fails, reply to me - I have a few other tricks up my sleeve.
-Tha Mp3 Doctor
Jan 09, 2008 | Philips GoGear SA261 MP3 Player
iLO (2 GB) MP3 Player Logo
64 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
