Question about Sram X-0 XO REAR DERAILLEUR MTB ATB LONG CAGE 2008 X O
On my ROAD bike could a Sram/Truvati XX or XO (crankset 42/28-cassette11/36) work smoothly with Sram red doubletap Thank you.
    Problem Solver:
  • 16 Answers
To use Sram Red Shifters with such a wide range rear cassette requires a Sram 10-speed MTB rear derailleur such as an XX or X.0, it will work without problems with your red shifter.
Because it is a road bike, i suggest leaving the road crankset and front derailleur in place. If you need low gearing I suggest a compact front crankset.
If you need to use a mtb crankset, attept to use the road front derailluer with it.
Posted on Mar 16, 2011
I Currently have X9 10 speed rear, but need to replace jockey wheels. are these interchangable with X10 or XX?
Replacing jockey wheels is one of the easier tasks on a bike. You will two standard, 11 tooth jockey wheels. Investing in metal ones with ball bearings is a good idea. Use an aallen key to remove and replace one at a time, taking particular attention to the way the CHAIN goes around each jockey wheel.
Mar 16, 2013 | Sram X9 Crankset 2x10 w/Bash for GXP
Tip
User Manual -SRAM Integrated Brake Shifter
Follow this link and see information: <span><b><a href="http://www.sram.com/_media/techdocs/DoubleTap%20Integrated%20Brake%20Shifter%2095-7015-007-000%20Rev%20C.pdf">http://www.sram.com/_media/techdocs/DoubleTap%20Integrated%20Brake%20Shifter%2095-7015-007-000%20Rev%20C.pdf</a></b></span>
on Mar 01, 2011 | Cycling
Tip
SRAM User Manual - Road Cranksets and BB
Follow this link and choose your SRAM manual: <a href="http://www.sram.com/_media/techdocs/95-6115-007-000%20Rev%20A%20-%20Road%20Cranksets.pdf">http://www.sram.com/_media/techdocs/95-6115-007-000%20Rev%20A%20-%20Road%20Cranksets.pdf</a>
Hi Everyone! I have a Shimano 5603 Hollowtech 2 triple chainring.......(10 Speed) I want to add a Utlegra 6600 front derailleur and Ultegra 6600 rear derailleur. Also 10 speed cassette, Ultegra...
No -
If you are going to use the front triple crankset, then you need to use the 6603 components. These are for Triple set-ups.
If you intend to keep your bike a triple, then everything in the drivetrain must be the triple designation, hence the XX03.
If you want to change the crankset to a compact, then you can use the 6600 (double) equipment, but you will need to change the left (front shifter) to a double as well. The compact crankset, will give you virtually the same range as the triple and be much lighter and shift better.
The cassette: You can use any 10 spd cassette from Shimano or SRAM as long as the rear cog is no larger than 27. if you want to use a larger cog like a 28, then you will have to use the 6700 group, assuming yoiu want to stay with shimano ultegra.
Final Note: Since you are chainging everything, you may want to consider the SRAM Apex group, this gives you more gear ratio than the Ultegra, is slightly less expensive and around the same weight. Great alternative to Triple bikes.
Parts you will need to convert:
Rear Derailleur
Front Derailleur (if changing to compact double or Apex)
Chain
Shifter set (if Apex)
Crankset (if Apex or compact shimano)
Bottom Bracket (if Apex)
The biggest thing is that Shifters and rear derailleur must be from the same company (shimano, SRAM, etc.) after that just make sure that yoiu use 10spd with 10spd, 9 with 9, and so on. Everything else can mix and match.
Dec 18, 2010 | Shimano Ultegra Triple Front Derailleur Fd...
Tip
User Manual - SRAM Road Cranksets and BB
Follow this link and see User Manual - SRAM Road Cranksets and BB <a href="http://www.sram.com/_media/techdocs/95-6115-007-000%20Rev%20A%20-%20Road%20Cranksets.pdf">http://www.sram.com/_media/techdocs/95-6115-007-000%20Rev%20A%20-%20Road%20Cranksets.pdf</a>
Question, . . need to replace chain Will a Sram PC-971 Chain work on my 8 speed road bike? Thanks T.K Yandell
Nope - This is a 9spd chain. The gears on a 9spd are narrower than on an 8spd. If you are going to use a SRAM chain you need one that starts with an 8 such as PC-850.
Any 8spd chain will work fine, Shimano, SRAM, whatever.
Nov 21, 2010 | Cycling
Sram Red outer chain ring problems. I have been a bicycle mech since 1994. I have a customer with sram red chain rings. He was in outer ring 53T and smallest cog rear cassette. The outer chain ring folded...
im in the industry aswell hmmmmm never heard of any recalls but i know quality speaks volumes of whether i would buy product from which i see an obvious quality based failures ive has similar issues and reported them sram said abuse without even looking at the issue we since have discontinued their line of products hope this helps
Nov 16, 2010 | Sram Force Crankset 53/39
Clueless
The rear cassette is only a part of the solution. The front gearset also comes with a variety of ring/teeth configurations.
Plenty on new bikes come with a 'compact' gearset (2 front rings, 10 speed rear cassette). That is generally a lower gear ration to aid in hill climbing.
The rear cassettes are easily interchanged (must be same brand as what the hub uses). Of the 3 you listed; the 11-26 would be "Fastest".
If you want to go fast, and are fit enough to power it at speed for a good duration... look for a large crank ring (greatest number of teeth) and a small cassette # (like the 11-26 you listed). It's a sinple ratio calculation. What you're looking for is the most amount of rear wheel rotations per crank rotation. That is achieved by a big (lots of teeth) front ring and a small (not many teeth) rear cassette ring.
While at the bike store, put the bike in it's highest gear (biggest ring on the crankset, smallest ring on the wheel cassette). Lift the rear wheel off the ground and count the amount of rear wheel rotations for 1 crank rotaion.
A triathalon/time-trial bike will come with a ratio of about 5.5-6.5 rotatotions of the rear wheel for each rotation of the crank.
An endurance road bike (with compact gearset) might come with about 4.25 rear wheel rotations for each crank rotation.
Tri/TT bikes are made to put the rider in the most areodynamic position possible thereby reducing the wind drag and making pedaling easier (so you can manage a higher gear ratio). Endurance road bikes are designed to put the rider in a confortable position (more upright) for all day riding.
Get the bike shop to fit you properly to the bike you choose, not all shops offer this. There are professional bike fitters that can help you when you get close.
Hope that helps
Apr 30, 2009 | Sram 850 8 Speed Cassette 11-32t Mountain...
Chain rubs inner front derailleur while in lowest gear.
on front derailleurs there should be two small cross head screws one has L(lower) next to it the other has H(higher), you will need a cross head srewdriver, you simply losten or tighten the 2 screws and it will adjust the position of the derailleur to your crankset and it that completely fails then you might need to try a different crankset
Feb 26, 2009 | Sram Cycling
Sram X-0 XO REAR DERAILLEUR MTB ATB LONG CAGE 2008 X O Logo
167 people viewed this question
Top Sram Cycling Experts
Michial Gueffroy
hgpilot
John Egan
John Egan
Are you a Sram Cycling Expert? Answer questions, earn points and help others
