How do I enter service mode on my HP 5500? - Office Equipment & Supplies
    Sergeant:
    Champion:
  • 298 Answers
Press the Select button to enter the menus.
Press the up arrow 5 times to scroll to service,and then press the select button again
Press the up arrow 5 times until you reach
the first digit of the code
Press the select button to save the digit
Repeat these steps until all 8 digits are entered
Code:04550002
Posted on Mar 11, 2011
Model W240. How can I enter service mode?
enter service mode Mohammad, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Entering Service Mode HP LaserJets
canonipf Service Mode
Service Manual free download schematics datasheets eeprom bins pcb repair...
Ricoh 6000 service mode
Apr 11, 2016 | Ricoh Office Equipment & Supplies
Reset hp tv 50
Check this link to download the user manual to your HP TV. It have details about reset. If it don't have, you must get into its service mode option to reset it to factory settings. But, entering service mode and changing data values there is a very skilled work, Improper settings to these values may even make the TV irresponsive to any external commands.
If you have sound knowledge in electronics, you can do it. Check this link for more details about how to enter the service mode to HP TVs.
Jan 24, 2013 | Samsung Televison & Video
HP T1100 paper load incorrect
Check:
1. Was its sensing the paper while loading the media?(roll or sheet)
2. Perform 'service test for sensors' to know how media sensor is working.. if its fails clean media sensor located left side of carriage assembly. If the media sensor becomes dirty due to ink, printer unable to detects the medias edge. Clean sensor gently.
Entering in service mode: Power off the printer using from the operational panel off button. Press & hold up arrow,ok button switch on the printer, wait few seconds to enter in service mode, once its enters in service mode, scroll to sensor test.
Nov 28, 2012 | HP Designjet T1100ps Printer
Hp t2300 error 21.2:13 solution
This would normally indicate "Service station error". I found the following solution elsewhere on Fixya for the HP Plotter T1100, but looks like it is for the technically minded.
"Remove right cover, remove & take out service station, check any objects in service station movement, remove motor clean entire unit with water you can find out lot of ink inside & too dirty clean it allow to dry apply grease for smooth movement( pl take care of pumping unit & tubes), fix it back, perform service station test ( to enter in service mode switch of the machine with power off button from front panel hold UP arrow button & OK key button then which on the from front panel button, wait till enter in service mode scroll to service station enter, three options service station,primary motor and aerosol motor select service station, enter wait till result papers on panel)."
Hope this helps.
Sep 08, 2012 | HP Designjet T2300 Inkjet Large Format...
RICOH AFICIO 5500 - SC555 ERROR HOW CAN THIS BE CLEARED?
press yellow clear then enter 107 and press and hold the orange stop key untill you enter service mode.
select copy sp
press 7807 and then the # key. select execute on the righ on the display
when it says complete turn off the machine from the red power switch. turn machine back on. if error returns repost here .. you may need parts
Aug 08, 2011 | Ricoh Aficio 1224C Black and White Copier
Error 21.2:13 on hp plotter t1100
Tech guys only:
Service station error..Remove right cover, remove & take out service station, check any objects in service station movement, remove motor clean entire unit with water you can find out lot of ink inside & too dirty clean it allow to dry apply grease for smooth movement( pl take care of pumping unit & tubes), fix it back, perform service station test ( to enter in service mode switch of the machine with power off button from front panel hold UP arrow button & OK key button then which on the from front panel button, wait till enter in service mode scroll to service station enter, three options service station,primary motor and aerosol motor select service station, enter wait till result papers on panel) best of luck...
Jul 25, 2011 | HP Designjet T1100ps Printer
Hp design jet T770 plotter display 21.2:13 on the control panel
Tech guys only:
Jul 12, 2011 | HP Designjet T1100ps Printer
I AM GETING PROBLEM WTIH HP PLOTTER T1100, ERROR 21.2:13
Tech guys only:
Jun 11, 2011 | HP Designjet T1100ps Printer
How to find ip address in hp 5500
To locate the IP address with the HP Designjet 5500, follow these steps below:
Press the Down Arrow keys on the front panel until the Setup Menu is displayed. Press ENTER. Go to the Utilities menu and select Test Prints.Press ENTER. For the HP Designjet 5000 series, select Service Config. Press ENTER. For the HP Designjet 5500 series, select Network-card Config. Press ENTER
Feb 12, 2011 | HP Color LaserJet 5500 Printer
50 people viewed this question
k24674
jasbo
jasbo
