I have a midstates farm king forced air oil heater 250000 btu where can I get parts [ignition]
5 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Kerosene forced-air heater won't start
remove the top of the heater - move the fan & motor backwards and remove the ignitor - if the element is fizzled go to www dot desatech dot com. you can get new hot surface ignitors from here. they also have spark ignition systems if yours has this.
Posted on Nov 11, 2007
Buffalo12980
  • 625 Answers
SOURCE: Reddy heater 110,000 btu forced air portable kerosene
try this, take off the top cover. plug in the heater and when the humming starts, rotate the fan sharply with a screwdriver. keep your fingers away from the fan. if the fan spins under power your start winding is shot. get a new motor. www dot desatech dot com
Posted on Dec 06, 2007
Buffalo12980
  • 625 Answers
SOURCE: RM115 Reddy Heater forced air heater problem
air pressure should be no more than 3.5 psi. could be your pressure is too high and is blowing out the flame.
SOURCE: All-Pro Kerosene Heater
I have a 100,000 allpro Kerosene heater I get sprake but won't lite I need help Thanks
Posted on Dec 03, 2008
Readsfl4 surfaces ignition problems
check the fuses going to the ignitor if ok ohm out ignitor to see if shorted or open should ohm out at 78 ohms if bad replace
Jun 05, 2014 | Jandy Laars Lite 2 Pool Heater 250000 BTU ...
I have an all pro 60,000 btu flex fuel heater. all pro went out business. i need a new igniter .... can anyone help me find this part ?
Try www.desatech.com. From the main page, click on kerosene heaters. Some igniters should be at the top of the page that comes up. See if one matches yours.
Jan 14, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
What does the service symbol 1F referring to? The gas is on, but the heater does not ignite. After a few minutes, the symbol 1F appears on the screen.
It means Ignition Failure. They heater went thru its startup cycle, and when the gas valve opened, the heater did not sense a flame. The whole routine begins again. After about 3 attempts at this, the heater will flash IF and then go into a lockout situation. This is a safety feature of this heater.
May 22, 2010 | Hayward 250FDP Universal Series Propane...
The pilot light on my coleman forced air furance will not stay
almost all thermocouples are universal just need to know the length, ie. 18" , 20", 24" etc...
Mar 15, 2009 | Coleman Propane Forced Air Heater...
Need allpro igniter
You should call Master Parts, they may have the part your looking for. You can contact them at 800-446-1446 or online at www.masterparts.net. I hope this helps...
Mar 03, 2009 | All-Pro Forced Air Kerosene Space Heater...
Model# m30 trips breaker after ignition older unit need parts manual
Plastic impeller insert broke changing the load on motor&over loading breaker still dont know part numbers need manual.
Jan 09, 2009 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heating & Cooling Logo
346 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
