Question about Juki DDL-8700
I just received my Juki 8700. I new to industrial machines. How do I wind the thread onto the bobbin?
  • 86 Answers
There should be a bobbin winding device next too and slighlty behind the drive belt.
Should be like this bobbin winder.
Posted on Mar 12, 2011
Why isn't my bobbin threading?
Georgia, Generally it is one of two problems:
1. there is a thread stuck in the spindle where the metal disk attaches to the machine. If this is the problem, put a couple drops of oil on the spot and pull the thread loose. While you are there, you should be able to see a tiny hole at the top of the metal where the spindle runs between the disk and the bobbin. Put a couple drops of oil in that also.
2. Somehow the whole bobbin mechanism has slid forward and is not coming in contact with your belt when you engage your bobbin winder. To fix that, unscrew the two screws that attach the WHOLE METAL MECHANISM to the table. Shove the mechanism back towards the back of the machine, SLIGHTLY, and retighten the screws. After this, you might want to check to make sure that the tension on your bobbin isn't too tight. You only need minimal tension on it to wind a good bobbin.
Good Luck.
Mar 16, 2016 | Juki DDL-8700 Industrial Straight Stitch...
My juki 8700 h frays thread while trying to sew
Hello Daniel, I suggest you start with a new needle. Back off the needle thread tension and the bobbin thread tension to a minimum and see how it sews. If it does not ravel the thread, you can increase the tensions until you acquire the stitch you want.
Mar 26, 2014 | Juki DDL-8700 Industrial Straight Stitch...
I just brought home a Juki 8700. The needle went down and now I can't get it basck up. There is thread stuck in the bobbin. How do I get the bobbin casing off
Cut the thread above the needle eye and rock the handwheel back and forth sharply to cut the thread with the sewing hook. If that doesn't work pretty promptly, undo the needle clamp and turn the handwheel, which should raise the needle bar. Then get into the bobbin case area and try to remove the bobbin case, cutting any threads you can. Keep rocking the handwheel and trying to pull out the needle (pliers help!), and eventually everything will loosen up.
Next, clean and lubricate the area under the needle plate and the shuttle, and reassemble. Put in a brand new needle, right way around and fully up in the machine. Load the bobbin case with a well-wound bobbin, and rethread the top of the machine and you should be good to go.
Jan 28, 2014 | Juki DDL-8700
Oily bobbin
Sounds like you've over oiled your machine. Take the bobbin out, strip the thread from it. wipe it down well... and re-wind the bobbin with new thread.
Next time you oil after your day of sewing. Place a piece of absorbent scrap fabric under the presser foot to catch excess drips.
Sep 27, 2013 | Juki DDL-8700
Juki DDL8700 Bobbin Winder Problem
the machine should be checked by a sewing machine technican
to see what wrong with the bobbin winder, the assembly may need
to be replaced
Dec 20, 2012 | Juki DDL-8700
I have an 8700 juki industrial machine and as I'm sewing the thread will not catch on the bottom bobbin. I'm frustrated.. It was fine the last time I've used it.
machines do not just go out of time. Is the top threaded correctly. did u miss threading thru the take up arm or take up spring change needle too.
Nov 26, 2012 | Juki Sewing Machines
Juki ddl 8700 my machine was sewing fine I put in a heavier (jean) thread. Now it wont pick up the bobbin thread to sew at all? Help?
try changing the needle to one that will work with heavier thread
you may have to change the bobbin to heavier thread also
try adjusting the tension also
Sep 25, 2012 | Juki DDL-8700
Juki DDL-8700 Logo
249 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
