Question about Daewoo DSJ-5510CRA 55" Rear Projection HDTV-Ready Television
My tv worked great then while watching it it stared to get lines through the picture then it just shut off and now when you try to turn it on it just shuts back off within 5 seconds
  • 1,476 Answers
Amiepoole1,
You have a bad main board. It is not currently available on any of the websites I use for parts. You can go to http://www.emcompass.com and put in a research request for the board. If it is available they should be able to get it for you at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Mar 11, 2011
How to fix vizio tv that turns on but no picture
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen ... Was working fine and now blank ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little research and fixed it. ... vizio E701i-A3E ...
Vizio LED TV Repair - TV Has Backlights but no Image on ...
? 5:06
https://www.youtube.com/watch?v=fSCf1xxLjNA
Aug 27, 2015 - Uploaded by ShopJimmy.com
Basic Troubleshooting Help if your Vizio LED TV has a blank screen and no ... It is on an UPS but turned off ...
Dec 10, 2015 | Vizio M3D650SV 65 inch Class Theater 3D...
My hiteker tv is not working
Check and replace its main power regulator board. It is faulty. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 05, 2014 | Hiteker TL50Z10AH-TP 50AAAAAAAA€AAAA LCD...
Pandigital mini photo scanner pictures have white lines on them
have a pandigital scanner that worked great for about 500 pics then lines stared to show up, tried cleaning and calibrating but did not help, decided to take apart and found that the glass on the surface of the scan part was dirty, cleaned the glass and put back together works perfect, took about 10 minutes to fix
Sep 05, 2009 | PANDIGITAL PhotoLink PANSCN06
The TV picture stared jumping. Then lines were
If, indeed this is a polaroid clone TV, most probably the fix is a new "control board", at the cost of $400 if TV is not under warranty.
Sorry to not be of more assistance.
Mar 02, 2009 | byD sign 4032 40 in. HD-Ready LCD...
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Turn tv on, all lines no picture
T-con board ro related cable problem.
You should check aboves, later iIf can't watch the TV because of the lines.
Dec 28, 2008 | Samsung LN-T4661F 46 in. LCD HDTV
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
TV Dilemma
you have a stuck vhs tape in it.
Oct 20, 2007 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
No picture whirring noise shuts off and on
DLP(digital light processor) does not have a color wheel
Oct 05, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Vertical line on KDL-32s20l1
You'll get this abnormality some times due to the signal if you're watching regular analog picture and you have your TV set on full screen, the TV will stretch the picture and you will see more defects than if you're watching it on normal picture. But if you are seeing the same problem when watching HD picture it needs to be serviced try this link I found: http://www.moniserv.com/doc/lcdtv.html
Aug 27, 2007 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Daewoo DSJ-5510CRA 55" Rear Projection HDTV-Ready Television Logo
147 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
