Question about HP LaserJet 3050 All-In-One Printer
Hi, i bought HP DeskJet 3050 All In One printer and it's in another language , how can i change the printer language display to English? Thankyou.
    Genius:
  • 1,089 Answers
Press MENU and then press 2
Press < or > to select Location and then press Check Mark
Press < or > until correct location appears
Press Check Mark
Press 1 to confirm
Printer will now power cycle itself
Posted on Mar 12, 2011
  • HP Master
  • 1,915 Answers
1. Turn off the all-in-one.
2. Press and hold down the * and buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. Allow the all-in-one to return to Ready before using it.
After following these instructions, when you restart, unit should prompt you to select a language. Use the left right arrow keys to select proper langauge and press checkmark to accept.
  • jimbeb Mar 25, 2011
    03-24-2011 07:54 AM
    Just had the same problem. Dispaly in German after selecting English-Europe. Hp support had no answer after 25 mins on the phone. Finally solved it myself. This is for a Deskjet 3050
    1) Remove power cord.
    2) Press and hold together Cancel button and OK button ( OK button is the one at the very bottom).
    3) Reinsert power cord to rear of printer while holding in both of these buttons for about 20-30 seconds.
    4) The HP sign should come onto the dispaly.
    This should reset the dispaly screen back to factory settings. You will have to reconnect your wifi again.
    This worked for me. Good luck.
Accidently set the printer HP deskjet 3050 to wrong language how do i reset?
The way was hidden somewhere in the HP solution center:
1. Press the cancel and power buttons at the same time, while the printer is on.
2. Press the blue, green and gray buttons (in this order)
3. Change the menu options with grey button until you get to the "Resets" menu.
4. Press OK. "Country and Language reset" displays.
5. Press and hold OK for approx 2 seconds, then release. The printer will turn off.
6. Start the printer again - it should ask you to select language.
May 05, 2011 | HP LaserJet 3050 All-In-One Printer
My printer language has been changed accidentally, pls help me to change it to english language. send me how to change using the control panel.
Hi vivekchat18,
The instruction below will help you put back the display language you desire for your printer. You may use the procedure below to print out reports or to show messages on the all-in-one control panel. Here's how:
1.First you need to press MENU.
2.Then, select SYSTEM SET UP.
3.Afterward, select LANGUAGE.
4.Now, choose the language that you prefer. In your case, ENGLISH.
5.You have to SAVE your settings.
6.Finally, wait until your system automatically restarts.
Hope it helps.
Thank you for using Fixya.
Mar 29, 2011 | HP LaserJet 3050 All-In-One Printer
Hi, I have bought HP Deskjet 3050 all in one printer and it's not in English how can i change the language display? Thankyou.
You will need to perform a reset on the machine.
Once it resets it will prompt you to set the language, use the arrow keys to select English and then press the checkmark. Unit will restart in English mode.
Mar 11, 2011 | HP LaserJet 3050 All-In-One Printer
Need to change language from german to english on my hp deskjet 3050 printer??
Hi deejaynickos
Try this :
Delete driver/software . Disconnect printer .
Download new english driver/software from http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=1140778&lang=en&cc=us&prodTypeId=18972&prodSeriesId=1140783&taskId=135
Make sure you ' ve selected the compatible OS and complete software .
Reboot , install downloaded software and connect the printer . Wait untill full operation is successfull .
regards ,
fanaudi .
Feb 28, 2011 | HP LaserJet 3050 All-In-One Printer
I want to cold reset my hp deskjet 3050 all in one J610 series so I can get my printer off Japanese and into english on the menu display. Can you help me with this?
After following these steps the printer should ask for language when it restarts. Keep in mind you will lose all other settings you may have put in.
Feb 21, 2011 | HP LaserJet 3050 All-In-One Printer
Printer in german not english
Changing the all-in-one control-panel display language
Use this procedure to print reports or to show messages on the all-in-one control-panel display in a
language other than the default for your country/region.
To change the all-in-one control-panel display language
1. Press Menu.
2. Use the button to select System setup, and then press .
3. Use the button to select Language, and then press .
4. Use the button to select the language that you want.
5. Press to save your selection.
The all-in-one automatically restarts.
Jan 26, 2011 | HP LaserJet 3050 All-In-One Printer
I have just brought the HP DESKJET 3050 all-in-one J610 SERIES and the language setting is in german on the display of the printer. How do i turn it back to english?
Hi amandajane30,
Here's how:
Hope it helps.
Jan 01, 2011 | HP LaserJet 3050 All-In-One Printer
I just bought an HP Deskjet 3050 printer and for some reason the language on the printer is in French and I have no idea how to change it to English. If you could help me that would be great. Thank you
Press < or > to select location and then press the check mark
When location appears, press check mark. Press 1 to confirm new location.
The printer should now automatically power cycle
Dec 04, 2010 | HP LaserJet 3050 All-In-One Printer
The Printing Services of my printer hp deskjet D2460 is in arabic
what do you call for the installer so that i can print to my printer an arabic font? because every time i print, the printer cannot print the arabic font?
Aug 03, 2010 | HP Deskjet D2430 Printer
how do I change the language? everything is in German.
Nov 11, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
76 people viewed this question
Seeker5211
Seeker5211
