Question about Whirlpool Dryers
Whirlpool 6 cycle dryer keeps shutting off. it will start back up and run, sometimes it will finish the load and most times it will shut back off in 5 to 20 min.
    President:
  • 3,074 Answers
Vent is restricted, disconnect vent tube run dryer. Clean out your restricted vent tube with a leaf blower and make sure it is not kinked or too long, this should help Tim:
http://www.applianceaid.com/general.html#vent
Posted on Mar 11, 2011
Permanent press cycle keeps shutting down and doesn't finish.
Hello. I don't know what make/model dryer you have but the problem could be with load size and type of clothing. The sensor bars are usually located on the front of the lint screen housing(you have to put your head in the dryer and look back to see them--they are 2 metal strips, approx 1/2" apart and at least several inches long). The damp/wet clothing keeps shorting across the strips, telling the main board to keep the dryer running. If there isn't enough of a load, the dryer may think that the clothes are dry prematurely and count down too quickly. The sensor bar technology *is not* an exact science--it works best on large loads with like clothing. For smaller loads, use time dry and adjust the temp setting accordingly. I hope I helped you.
Aug 22, 2015 | Dryers
Why does my whirlpool senseon dryer start when i disconnect the thermistor wire but then shuts off after a minute?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Apr 08, 2015 | Whirlpool Dryers
How to shut off dryer end of cycle beep. Can u run
If the model number is correct, the dryer End of Cycle signal cannot be adjusted or turned off. The informatrion is listed on page 11 of the Owner's Manual:
http://www.managemylife.com/mmh/owner_manuals/16695/WHIRLPOOL-Laundry-Centers-L0710382?brand_name_search=LTE5243D
The only way to turn the signal off, is to remove the operator console, locate the signal (buzzer) module and disconnect the wire(s). The buzzer is listed as item 32 under the "Washer/Dryer Control Panel" parts listing:
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-YLTE5243DQ2/1198/0152000/W0702346/00001?blt=06&prst=&shdMod=
CAUTION: If you choose this option, make sure you UNPLUG the washer/dryer before servicing anything inside. If you disconnect any wires, make sure you cover them with heat shrink or electrical tape to keep them from coming into contact with anything else.
The washer and dryer use a common power source, but the rest of the functions operate independently of each other. You can safely run both units at the same time.
If need further assistance, please let me know. I hope this helps you.
Aug 09, 2011 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool ggw9868kq .Ducts are clean, airflow is good. Drum rotates. Dryer warms up then heating stops. happens in both auto and timed cycles.
My whirlpool dryer Model GGW9896KQ2 seems to run ok but it doesn't seem to heat up properly and takes several cycles to dry clothes. I checked the exhaust vent and it seems to be blowing air out ok. Also, it appears the dryer goes to the cool down cycle way to early. In addition, the dryer will sometimes shut off before the time is acutally done. help--I don't want to spend money for a tech or even a new dryer. It's only 8 years old.
Aug 06, 2011 | Whirlpool GGW9868K Gas Dryer
Have a 90 series kenmore dryer, won't always run. replaced the motor about 6 months ago, and now it will sometimes run, sometimes not. It gets hot, and will run for a bit then shut down, then start up...
If the timer is not advancing but is ticking that could be the problem. A dryer achieves a set temperature and stays there for a certain amount of time during a cycle. If the time never changes it may just keep heating up until the heat sensor shuts it down. If it is starting and shutting down its likely still related to the heat sensor.
Dec 07, 2009 | Dryers
After a few loads the dryer shuts off before the time cycle is finished. The lent screen is clean and the lent exhaust is clear. My dryer is whirlpool mod. GEQ9858JQ8.
the motor is over heating cutting out on the thermal overload inside the motor replace the motor 279787 part number
Apr 17, 2008 | Dryers
Whirlpool Electric dryer E1
An E1 Code is a thermistor fault TEST #3a Thermistor Test
The machine control electronics monitors the
exhaust temperature using the thermistor, and
cycles the heater relay on and off to maintain
the desired temperature.
Begin with an empty dryer and a clean lint
screen.
1. Plug in dryer or reconnect power.
2. Set the following configuration:
➔ Door – must be firmly closed
➔ Press Control On
➔ Press End Of Cycle Signal (Louder)
➔ Press Start
3. If after 60 seconds, E1 or E2 flashes in the
display and the dryer shuts off, the thermistor
or wire harness is either shorted or open.
➔ Unplug dryer or disconnect power
➔ Check wire connections at the machine
control electronics and thermistor.
To access the Thermistor you will need to open the bottom front panel 2 screws the thermistor is on the exh duct (Center) check it there let me know if you need futher help
Dec 09, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer (5yrs old)
screen.
➔ Press Control On
➔ Press Start
Nov 10, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
89 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
