Question about Panasonic NN-P295SF Microwave Oven
Steam comes out from bottom of the door when OTR unit is on for more than 5 minutes on high. I can feel warm air underneath microwave especially near the handle. Help!
  • Panasonic Master
  • 9,098 Answers
You should make sure your filters and ductwork are clean and clear and that your microwave's fan is running while cooking.
Posted on Nov 23, 2011
Tip
Microwave cleaning
<span>Place a bowl of water in the microwave (with a non-metal object such as a wooden spoon or stir stick in the water*) and heat for 3 - 5 minutes, depending how hard the crud is really stuck on. When microwave stops, keep the door closed to give the moisture and steam the heated bowl of water generated to have time to work. Remove bowl (careful, it's hot) and take a moist, warm cloth to the inside of the microwave. The crud bits should wipe off easily</span>
on Apr 02, 2011 | Microwave Ovens
My microwave shuts off, black no power when ever I cook tv dinners, potatoes etc. after 2.5 or 3 minutes. After 10 minutes or so, power comes back on and it displays PF. lots of steam inside after.
Hi Kerry,
"PF" is power falure if you didn't aready know this. It sounds to me like the coolig fan might be running slow or there is blocked or restricted air flow through the unit. This cooling fan is only for the HV transformer and magnetron. Sometimes you may get air flow around the door but this is incidental. The PF tells me that the power is being interrupted either at the power source (wall outlet or circuit breaker) or the magnetron TCO is cutting out. It also could be a bad magnetron running too hot. As far as the steam goes, I usually just leave the door open on my microwave for 10 or 15 minutes to let the condensation evaporate.
Jun 25, 2015 | Hotpoint RVM1435 Microwave Oven
Spontaneously stops working and then comes on after 5 minutes. Why?
Sounds like the magnetron is overheating. There is an automatically-resetable thermal circuit breaker attached to the magnetron. Most likely your problem is caused by either a cooling fan that is not running, or is running too slow (caused by gummed-up bearings). In some over-the-range (OTR) microwave ovens, the exhaust fan is run at a slow speed to cool the magnetron, and if it's bearings get gummed up, it won't run on the slow speed. But if it's a new OTR microwave, then the exhaust fan may be pointing the wrong way. (It is rotatable, depending on the installation). For example, if it is pointing up, but you don't have an exhaust vent over the microwave, then the air has nowhere to go, and the magnetron will overheat.
Oct 16, 2014 | Microwave Ovens
Can a Kenmore Microwave oven Model 401.8504*, 85143 be put on a counter top and used?
Most over-the-range (OTR) microwave ovens have the exhaust fan funning at low speed when the microwave oven is working. This is to keep the magnetron and electronics cool. And it sucks air in from the bottom, so if you just place this microwave flat on the countertop, it won't be able to suck air in, and it could overheat if you use it for more than just a few minutes. But if you can put it on some boards or some sort of grill so air can get to the bottom, then you should be okay to use it as a counter-top model.
Jul 02, 2014 | Kenmore Microwave Ovens
Microwave exhaust fan doesn't really exhause any steam out. Model 721.80042700
The fan is for cooling the magnetron, nothing else. Steam remains in the cavity which is why the door should be left open after cooking to allow the steam to evaporate.
May 30, 2017 | Kenmore 30" Microwave Combination...
Keypad does not work after steam hits it
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
Keypad failure can cause it to come on by itself, which can lead to a fire.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 24, 2010 | General Electric Microwave Oven
Overheating bottom Kenmore 66560652000
I would suspect that when the microwave oven was on the table the vent or air openings were restricted by the table. Without free flowing air the control and other components could build up heat. It is doubtful that you built up enough heat to damage anything as this unit has more than one over temperature safety devices built into it.
That being said, the excess heat could weaken something internally especially on the control that would cause it to fail sooner than later in life.
My advice would be to leave it unplugged until it is mounted back on the wall per the instructions and use it then as normal. If it fails in the next year or so replace it at that time.
May 03, 2010 | Kenmore Microwave Ovens
Is there a piece I can install on the bottom of my over-the-range microwave that will help keep the front of the microwave from being covered in steam when cooking on my stovetop?
Every over the range microwave has a vent on it that should be venting that steam. I don't know of anything you could put under there that would solve your problem as that is where then vents are and they would be blocked. It sounds to me as though your steam is not being vented properly, and this could also happen if the steam is being vented back into the room instead of outside as many OTR microwaves allow you to do. Its a little bit of work to vent it outside but I myself did that with my microwave and have never had a steam accumulation problem.
May 03, 2010 | Maytag Appliances Over-the-Range Microwave...
Steams
It could be a problem with your cooling fan or hood fan not venting the cavity enough.
To help you most effectively, it's better to post your full actual model number. But I'll give you the general info for now.
If this is a countertop model, you should feel strong air flow coming out from the back.
If it's an over the range model, you should hear the internal fan blowing when you hit Start and see the steam moving around while it's heating.
If the fan is not blowing and air is not blowing or if the next system is not working or blocked, you will get more steam than usual and the magnetron will likely end up being damaged.
Some steam buildup inside is normal, but not too much. It's kind of subjective, but it's dependent to a lagre degree on that air flow.
Most newer models don't have any gaskets to worry about, but older models may have deteriorated gaskets which limit the air flow.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer once we pose a final solution.
Nov 29, 2007 | Kenmore 62702 Microwave Oven
Panasonic NN-P295SF Microwave Oven Logo
97 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
