Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Does not dispense the soap. Uses almost none.
  • Anonymous Aug 07, 2008
    no solution dispensed
  • Anonymous Aug 27, 2008
    I had the same problem for quite a while then realized the washer was missing on the soap container. I went to a pluming supply house and got a washer that fit and all is well now
    President:
  • 1,673 Answers
Is the gasket on the bottom of the tank and not sitting in the hole. If it is on, there is a gasket to seal the cap, it may be missing. Usually replacing the soap dispenser, it comes with a new valve, will solve the problem.
Posted on Sep 18, 2008
My Hoover F7452900 uses up the detergent in about 30 seconds and doesn't use any water. What can I fix?
The water and the soap are supposed to mix as they are dispensed. Check for a leak or crack anywhere in the water line. Any crack would make the vacuum-operated delivery of water quit working!
Apr 23, 2017 | Hoover Vacuums
Steam Vac Is Not Dispensing Soap
Try using a rubber tipped air nozzle and compressed air at the end of the soap dispenser line. Brief intermittent blasts of air should take care of it.
Nov 16, 2013 | Hoover F6212-900 / F6215-900 SteamVac...
We have an Emerson hands-free soap dispenser that won't work. We've installed brand new batteries and it still won't dispense soap. The red light comes on to indicate it' s working but no soap will come...
We have 5 Emerson hands-free soap dispensers that don't work. Tried new batteries, light comes on, but no soap comes out. How can we get our money back?
May 20, 2010 | Vacuums
The water is not coming out to clean the floor
Your unit uses water, correct? I have a Proheat 2X and it wouldn't dispense water. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 21, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Soap is not dispensing out of the soap dispenser on the bissell
Pour some hot water in the machine and see if the hose is clogged. Is the pump making any noise when you hit the switch like it is trying to pump?
Feb 11, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View uses very little soap.
The valve at the bottom of the soap tank may have gone bad, Also try running a mix of water and vinegar(not on carpet) to see if it will clean the system out. The system may just need cleaning out.
Jun 06, 2008 | Bissell 1699 ProHeat Clear View Upright...
Model F7441980 Hoover Dual Action Spin Scrub Wide Path
You will have to replace the tank, and it will come with the soap dispenser attached.
Mar 30, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Soap dispenser
Probably plugged with soap. Try to clean the hole under the shampoo dispenser. Put plain water in the dispenser and hope it gradually cleans it out.
Jun 14, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
59 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
