Question about Whirlpool AWOE8748 Front Load Washer
My Whirlpool AWO/D6720 washermaskin has a F23 code and it dont start. What does it mean and how can i fix the problem
4 Suggested Answers
  • 1550 Answers
SOURCE: the error F23
This error occurs when heater fails in the unit .
Try this
  1. Unplug power chord to the washing machine .
  2. Check connection to water heater .
  3. Check resistance of heating element .
  4. Check the water temperature sensor and connection to it.
Hope this helps .
Posted on Feb 21, 2009
  • 6 Answers
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Posted on Sep 09, 2009
SOURCE: Whirlpool AWO/D 7740 error code F23
error code f23
Posted on Oct 17, 2010
My brand new Whirlpool AWO/D 7740 shows error code f23 5 seconds after starting any program and won't do anything.
don't touch it
as it is still under warranty , call in a service technician for a warranty repair
Jan 28, 2016 | Whirlpool Washing Machines
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
I am having a problem with my Whirlpool AWO/D 43135 washing machine.It stops when starting any program and shows error code F23.What should I do?
The fault F23 could be linked to the water temperature not reaching the right temperature. If your model uses hot water inlet connection then check if your hot water unit is providing the correct inlet water temperature. Otherwise it is likely the temperature sensor or heater element maybe failing.
See description
HEATER FAILURE
If the temperature increase during the first 40 minutes is less than 86degF (30degC).
1. Unplug washer or disconnect power.
2. Check connection to water heater.
3. Check resistance of heating element, if present on this model. (abnormal = infinity)
Jul 31, 2014 | Whirlpool Washing Machines
Code f23 for whirlpool washing machine
Hope this helps.
jenni.
Sep 09, 2009 | Washing Machines
My Kenmore dryer is flashing a code F23 what does this mean?
F33 Possible Cause / Procedure 1.-Unplug washer or disconect power  2.- Check for wire harness condition to the pump and Central Contral Unit (CCU). 3.-Plug in the
http://www.scribd.com/doc/7075573/Whirlpool-Kenmore-HE2-Plus-Troubleshooting-Tech-Sheet-8540259
Was this helpful?
May 12, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
The error F23
Try this
Hope this helps .
Feb 21, 2009 | Whirlpool Washing Machines
F-23 error code
HOW TO FIX WHIRLPOOL WASHER F23 ERROR CODE What does F23 mean on whirlpool washer? It means there is a heater failure. If the water temperature in the washer fails to reach 86 degrees or higher then the washer will give the F23 error code. To fix the whirlpool washer f23 error follow the steps listed below.
Note: Some models do not have a heater as shown below, some models just have a temperature sensor. If your model does not have a heater just skip to checking the temperature sensor.
  1. First unplug the washer.
  2. Check the wiring to the heating element make sure its not burned, broken or corroded.
  3. Check the heating element for continuity of course if it does not have continuity then replace the element.
  4. Check the water temperature sensor wiring for corrosion or breaks.
  5. Remove the wiring harness from the temperature sensor and measure the resistance of the sensor. Refer to the chart below and if its out of range replace the sensor.
see link below for details and where to buy the part which is under $80 and fairly easy to replace
How To Fix Whirlpool Washer F23 Error Code Appliance Repair Guides
Jan 02, 2018 | Washing Machines
Error Code
I don't have a manual on the newest dryer like you have, but one of the models just older than yours has a F23 code that indicates a shorted thermistor.( temp sensor )
Since it is new you need to call for service. They will usually look up the code and tell you if it is anything you need to check but most likely you will need a repairman to repair it in warranty.
Post back if you have any questions.
Nov 08, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool AWOE8748 Front Load Washer Logo
112 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
